Hilfe bei der Installation des Bot's
silverlp
Hallo zusammen.
Um es schon zu sagen, ich bin ein kompletter Linux anfänger!
Ich wollte denn Bot auf meinem 64bit Ubuntu 14.04 installieren aber irgendwie klappt es nicht ganz.
Ich habe das hier als Tutorial benutzt: https://www.ts-coach.com/blog/teamspeak-musik-bot-auf-linux-installieren/
Jedes mal wenn ich dann
xinit /opt/ts3soundboard/ts3bot -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac benutze kommt nur das:
bot@Server:/opt/ts3soundboard$ xinit /opt/ts3soundboard/ts3bot -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension Present
Initializing built-in extension DRI3
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension SELinux
Initializing built-in extension GLX
2015/11/28 22:41:18 104fab6b INFO Initializing bot://104fab6b-e688-4b91-9899-38a0d7a51c3e
2015/11/28 22:41:18 104fab6b f334fe99 INFO Loaded
2015/11/28 22:41:18 Auto-Starting 104fab6b-e688-4b91-9899-38a0d7a51c3e/f334fe99-460e-41f2-a4f1-6c330761496d in 2500 ms...
2015/11/28 22:41:18 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/11/28 22:41:18 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/11/28 22:41:18 RadioStation data loaded
2015/11/28 22:41:19 Imported radio stations
2015/11/28 22:41:21 104fab6b f334fe99 DEBUG Could not delete from Notificationsno such table: Notifications
2015/11/28 22:41:21 104fab6b f334fe99 DEBUG Could not insert into Notifications-Tableno such table: Notifications
2015/11/28 22:41:21 104fab6b f334fe99 INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
Qt: Session management error: None of the authentication protocols specified are supported
Crashdump ENABLED, directory is: /opt/ts3soundboard/data/ts3/104fab6b-e688-4b91-9899-38a0d7a51c3e/f334fe99-460e-41f2-a4f1-6c330761496d/crashdumps
DUMP defined! Dumpdir is: /opt/ts3soundboard/data/ts3/104fab6b-e688-4b91-9899-38a0d7a51c3e/f334fe99-460e-41f2-a4f1-6c330761496d/crashdumps
2015-11-28 21:41:21.770176|INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2015-11-28 21:41:21.770422|INFO | | |SystemInformation: Linux 3.19.0-31-generic #36~14.04.1-Ubuntu SMP Thu Oct 8 10:21:08 UTC 2015 x86_64 Binary: 64bit
Failed to create secure directory (/run/user/1000/pulse): Permission denied
2015-11-28 21:41:21.801907|ERROR |PulseAudio | |failed to connect to pulse audio server
2015-11-28 21:41:21.802575|ERROR |PulseAudio | |pa_context_connect failed
2015-11-28 21:41:21.802808|ERROR |SoundBckndIntf| |/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2015-11-28 21:41:21.826985|INFO | | |Loading plugin: libclientquery_plugin
2015-11-28 21:41:21.827133|INFO | | |Loading plugin: liblua_plugin
2015-11-28 21:41:21.827223|INFO | | |Loading plugin: libsoundbot_plugin
2015-11-28 21:41:21.827295|INFO | | |Loading plugin: libtest_plugin
2015-11-28 21:41:21.830541|INFO |Query | |listening on 127.0.0.1:25639
libpng warning: iCCP: known incorrect sRGB profile
2015-11-28 21:41:22.280049|INFO | | |*** Time [MAINWINDOW]: 183
2015-11-28 21:41:22.280276|INFO | | |*** Time [INIT]: 183
2015-11-28 21:41:22.284796|INFO |ClientUI | |Failed to init text to speech engine
2015-11-28 21:41:22.284991|INFO |ClientUI | |Qt version: 5.5.0
2015-11-28 21:41:22.285061|INFO |ClientUI | |Using configuration location: /opt/ts3soundboard/data/ts3/104fab6b-e688-4b91-9899-38a0d7a51c3e/f334fe99-460e-41f2-a4f1-6c330761496d/settings.db
2015-11-28 21:41:22.580538|INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2015-11-28 21:41:22.583023|INFO |ClientUI |1 |Connect to server: 127.0.0.1
2015-11-28 21:41:22.584883|INFO |ClientUI |1 |Blacklist check ok
2015-11-28 21:41:22.585095|INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987 127.0.0.1
2015-11-28 21:41:23.121107|INFO |PreProSpeex |1 |Speex version: 1.2rc1
2015-11-28 21:41:23.279830|INFO |ClientUI |1 |Connect status: Connecting
2015-11-28 21:41:23.286751|INFO |ClientUI | |Last update check was: So. Jan. 1 00:00:01 2017
2015-11-28 21:41:23.287151|INFO |ClientUI | |Checking for update
2015-11-28 21:41:23.435020|INFO |Update | |Checking for updates...
qt.network.ssl: QSslSocket: cannot resolve SSLv2_client_method
qt.network.ssl: QSslSocket: cannot resolve SSLv2_server_method
2015-11-28 21:41:23.602828|INFO |Newsticker | |Newsticker next check: Sa. Nov. 28 22:54:50 2015
2015-11-28 21:41:23.746938|INFO |Update | |Check license version: 1
2015-11-28 21:41:23.748928|INFO |LicenseViewer | |License language: en
2015-11-28 21:41:23.749243|INFO |LicenseViewer | |Found cached license for version 1 and language en
2015-11-28 21:41:28.300830|INFO |ClientUI |1 |Connect status: Disconnected
2015-11-28 21:41:28.302731|INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2015/11/28 22:41:48 104fab6b f334fe99 DEBUG Storing configuration.
Ich hab 0 Plan was falsch ist.
Meine Config ist die:
ListenHost = "Censored :p"
SecretKey = [237, 2, 46, 15, 200, 148, 143, 127, 1, 157, 74, 254, 92, 207, 113, 124, 47, 67, 134, 77, 151, 184, 133, 108, 125, 132, 50, 240, 170, 10, 65, 183]
MTU = 1500
SampleInterval = 100
Ja würde mich über Hilfe freuen
Raphraph
Zum Tutorial von Ts-Coach:
1. Das ist ein Tutorial für die SinusBot Version 0.9.8. Es gibt jedoch schon neuere Versionen (die sind aber in der BETA) die schon besser funktionieren. (Installation: https://forum.sinusbot.com/threads/installation-debian-ubuntu-sinusbot-beta-versions.610/ )
Zur config.ini:
1. "ListenHost" sollte man nicht verändern. Einfach auf "0.0.0.0" lassen
2. "SampleInterval" -> warum steht das auf 100? Sollte auf 60 stehen
Zum Bot:
-> ich sehe gar keine Fehler ;) Was ist denn das Problem?
silverlp
Okay ich dachte bei ListenHost muss die Ip rein fail.
Und wenn ich ihn starte welche ip brauch ich um ins Interface zu kommen.
Und kann ich dann dort die Ts ip eintragen?
GetMeOutOfHere
ListenHost setzt man nur, wenn man mehrere IPs mit einem Server verwendet.
Das Interface erreichst du über die IP/Domain deines Servers mit Angabe des Ports.
zB. http://meineIP:8087
Im Webinterface kannst du dann einzelne Bot Instanzen konfigurieren und angeben, auf welchen TS Server der Bot joinen soll.
silverlp
Der bot ist jetzt zwar an aber, ich komm beim Interface nicht ins Login.
Was muss da für ein Login rein? Hab alle Daten probiert wo genau muss ich mich da registrieren?
