How to find URL for other users to use web control panel?
DespairGiver
I'm very new to music bots let alone this one and kind of confused. Where do I find the URL to give other users so that they can access the bot via the web control panel instead of using commands in TS3?
Patschi
You just need to point the users on the same webinterface as you are using. Usually http://Sinusbot-IP:8087.
The further steps depends on your IT-environment.
  • If the bot is running on a rent public server, mostly it works just out-of-the-box. Just give them the URL. In some case you may need to open the port on the servers´ firewall, if the server has further firewall restrictions.
  • If the bot is running on any machine at your home, like your own computer, it is usually not that simple. You need to forward the port TCP/8087 through your router to your machine, where the Sinusbot is running on. You may also need to configure your machines´ firewall to let the traffic on that port passing by. Lastly you need to give your users the URL with your public IP address - you can see the public one (for example) on myip.is. On most internet plans for private people the IP also may change every few hours or days.
