How to fix this?
Maz.b
How do I fix this problem?
ts3bot@ns303569:~/TeamSpeak3-Client-linux_amd64$ xinit /home/ts3bot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
Cannot mix incompatible Qt library (version 0x50500) with this library (version 0x50601)
2016/08/30 19:18:27 f4c7fb6d 5c0e69f5 INFO Starting instance ts3server://ts.***.de?port=9987&nickname=EmmaWatson&password=&cid=215&channelpassword=
2016/08/30 19:18:27 f4c7fb6d 5c0e69f5 INFO TSClient quit.
Maz.b
 - Operating System: Debian GNU/Linux 8.5 (jessie)
 - Load Average: 0.76 0.56 0.58
 - Uptime: 35 days, 1 hours, 4 minutes, 3 seconds
 - OS Updates: 732 (updates available!)
 - OS APT Last Update: 30.08.2016 18:54:30 CEST +02:00:00
  Architecture:  x86_64
  CPU(s):  8
  Thread(s) per core:  2
  Core(s) per socket:  4
  Socket(s):  1
  Model name:  Intel(R) Xeon(R) CPU  W3520  @ 2.67GHz
  CPU MHz:  2668.000
  Virtualization:  VT-x
 - RAM: 1.97 GB/15.69 GB in use (12%)
 - SWAP: 24.17 MB/1021.99 MB in use (2%)
 - DISK: 209.30 GB/1.49 TB in use (13%)
 - Report date: 30.08.2016 19:40:23 CEST +02:00:00 (timezone: Europe/Paris)
 - Status: running (PIDs: 954, User: ts3bot)
 - Binary: /home/ts3bot/ts3bot (Hash: 3b2c7f99a3b0a358e7d328079c4fa8b8)
 - Version:
  - TS3Path = /home/ts3bot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.18.2)
  - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2016.08.28)
 - DiagScript version: v0.4.3
Raphraph
!! You should update your TeamSpeak Client. The version you currently have is outedated and has shown some security issues. Newest version is 3.0.19.4
