Installation Error
Root Oneon
2019/01/06 01:29:41 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2019/01/06 01:29:41 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2019/01/06 01:29:41 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2019/01/06 01:29:41 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2019/01/06 01:29:41 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2019/01/06 01:29:41 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2019/01/06 01:29:41 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
a manual update is required
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 1097.
