Installation problem
TeamStream
hello, my sinusbot is running TeamSpeak 3.2.3.
I would like to put it to you to the latest version of TeamSpeak, but I can not ...
I decided to totally uninstall the bot, and follow this tutorial to reinstall it to the latest version: https://wiki.sinusbot.com/en:guides:installation:linux
I only change the download link, to the latest version.
At the time of launching the bot, it does not launch, I have the message "TS3 CLIENT QUIT".
The bot is not compatible with this version?
How to use it with the latest version?
Thanks
Brini
Same problem here so it seems like the sinusbot isn't compatible with the newest teamspeak version, but no panic, just keep using 3.2.5 and wait for a sinusbot update. Compatibility issues are normal after a new client update...
Client Version 3.3.0 has quite some changes:
=== Client Release 3.3.0 - 18 Jun 2019
! Updated Qt framework to 5.12 LTS releases.
! Updated Opus codec to version 1.3 to introduce lots of quality improvements,
  new features, and bug fixes.
! This version of the TeamSpeak Client requires macOS 10.12 (Sierra) or later.
! The HTML style tag is no longer supported in infoframe templates. All addon
  authors should use the <stylename>_chat.qss file for CSS style definitions
  instead.
! Updated Plugin API version to 23.
* Increased size limit for text messages to 8 KiB.
* Updated easy-permission templates to use Opus instead of Speex/CELT codecs.
* Spacer tags in channel names will now be omitted in infoframe templates.
* Improved pagination support for banlist and clientdblist for plugin API.
+ Added additional variables to infoframe templates.
+ Implemented multi-select for clients in the servertree.
+ Implemented multi-track recording feature, to allow recording each client's
  audio stream independently.
+ Added support for signed badges to prevent usage of fake data. Note, that
  this feature requires TeamSpeak Server version 3.8.0 or later.
+ Added support for URL tagging in incoming text messages.
+ Added support for myTeamSpeak ID bans in virtual server banlist.
+ Added support for Windows tiles. Thanks to our user RandomHost for providing
  the material.
+ Added support for updated license types (Gamer, Commercial, Sponsorship).
+ Added invoker data for onPluginCommandEvent(). Note, that server-side support
  for this API change will be introduced with TeamSpeak Server version 3.9.0.
- Fixed a freeze in easy-permission settings when switching between different
  templates.
- Fixed a bug where default profiles could be deleted in settings.
- Fixed crashes reported by crashdumps.
Could be possible that one of these breaks Sinusbot, as it breaks lot of plugins.
3.2.5 works though and has the QT vulnerability from previous versions fixed.
Brini
Okay !
Bot work with 3.2.5 ?
how to know when it will be compatible with the latest version?
Yeah, 3.2.5 works fine for everyone.
Just look forward to a new sinusbot update, that is needed to fix this compatibility issue. Until then, just keep chilling, I think the new client version won't bring any improvements for the sinusbot...
TeamStream
Thanks.
Were i can see updates of the bot ?
