Instanz-Fehler beim Starten
W0nd3r
Hallo, wenn ich eine Instanz starten möchte, was er aber nicht macht, steht im Instanz-Log:
2016-08-26T02:57:49+02:00 Storing configuration.
2016-08-26T02:57:49+02:00 Closed.
2016-08-26T02:57:49+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2016-08-26T02:57:49+02:00 Starting instance ts3server://meinedomain.de?port=9987&nickname=MusikBot&password=&channel=&channelpassword=
2016-08-26T02:57:42+02:00 Closed.
2016-08-26T02:57:42+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2016-08-26T02:57:42+02:00 Starting instance ts3server://meinedomain..de?port=9987&nickname=MusikBot&password=&channel=&channelpassword=
2016-08-26T02:56:22+02:00 Storing configuration.
2016-08-26T02:56:14+02:00 Closed.
2016-08-26T02:56:14+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2016-08-26T02:56:14+02:00 Starting instance ts3server://meinedomain..de?port=9987&nickname=MusikBot&password=&channel=&channelpassword=
2016-08-26T02:55:55+02:00 Closed.
2016-08-26T02:55:55+02:00 Fail from data reader: EOF
2016-08-26T02:55:55+02:00 Fail from voice reader: EOF
2016-08-26T02:55:55+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2016-08-26T02:55:55+02:00 Starting instance ts3server://meinedomain..de?port=9987&nickname=MusikBot&password=&channel=&channelpassword=
2016-08-26T02:55:54+02:00 Auto-Starting aa219178-fa84-4e02-b53e-0e418cb6a47b/e1a957d0-7bc8-43d7-876b-xxxxxx in 500 ms...
2016-08-26T02:55:54+02:00 Initialization complete
2016-08-26T02:55:54+02:00 Closed.
2016-08-26T02:55:54+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2016-08-26T02:55:54+02:00 Starting instance ts3server://meinedomain..de?port=9987&nickname=MusikBot&password=&channel=&channelpassword=
Es kommt auch noch folgende Meldung:
2016-08-26T03:11:57+02:00 Storing configuration.
2016-08-26T03:11:55+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2016-08-26T03:11:55+02:00 Closed.
2016-08-26T03:11:55+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++abi.so.1)
2016-08-26T03:11:55+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++.so.1)
2016-08-26T03:11:55+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Sql.so.5)
2016-08-26T03:11:55+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Widgets.so.5)
2016-08-26T03:11:55+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Network.so.5)
2016-08-26T03:11:55+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Gui.so.5)
2016-08-26T03:11:55+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Core.so.5)
2016-08-26T03:11:55+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libquazip.so)
2016-08-26T03:11:55+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64)
Habe auch schon die Lösungsvorschläge aus folgendem Thread versucht: https://forum.sinusbot.com/threads/glibc_2-14-not-found.1594/
hat aber leider nicht geholfen.
Habe das Sinusbot Installer Script 1.2.6 verwendet.
W0nd3r
So habe jetzt noch ein wenig rum probiert...
Jetzt spuckt der Log nur noch folgendes aus:
2016-08-26T04:09:56+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2016-08-26T04:09:56+02:00 Closed.
2016-08-26T04:09:56+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++abi.so.1)
2016-08-26T04:09:56+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++.so.1)
2016-08-26T04:09:56+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Sql.so.5)
2016-08-26T04:09:56+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Widgets.so.5)
2016-08-26T04:09:56+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Network.so.5)
2016-08-26T04:09:56+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Gui.so.5)
2016-08-26T04:09:56+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Core.so.5)
2016-08-26T04:09:56+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libquazip.so)
2016-08-26T04:09:56+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64)
2016-08-26T04:09:56+02:00 Starting instance ts3server://gamedcom.de?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2016-08-26T04:09:56+02:00 Initialization complete
2016-08-26T04:09:56+02:00 Spawning instance shortly due to missing configuration file.
libc6 ist auf meinem System installiert.
~# sudo apt-get install libc6
Reading package lists... Done
Building dependency tree
libc6 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 56 not upgraded.
Hi, welches OS, Infos ? ... wir haben hier keine Glaskugeln.
Und libc6 wird immer installiert sein, nur ebend in ner Steinalten version. - Alles unter Debian 8, Centos 7 und Ubuntu 14.04 wird nicht mehr funktionieren.
apt-get update && apt-get upgrade
Patschi
Nur aufgrund der Vollständigkeit: Das Problem liegt hier seitens TeamSpeak GmbH bezüglich deren offiziellen TS3Client, und nicht am Sinusbot! Ab TS3Client 3.0.19 sind die Abhängigkeiten von glibc zu einer aktuelleren Version erhöht worden...
W0nd3r
Oh, sorry ich benutze Debian 7.
Also das Problem könnte gelöst werden, wenn ich auf einen älteren Teamspeak-Clienten wechsle?
Patschi
Theoretisch, ja. Empfohlen, nein. In den älteren Versionen lauern diverse Crash-Bugs, wenn nicht auch noch unbekannte etwaige andere Sicherheitslücken. Die Empfehlung wäre hier eher, auf Debian 8 zu upgraden. Irgendwann wird es sowieso notwendig werden, da Debian 9 bald erscheinen wird und Debian 7 in einigen Monaten (?) sowieso nicht mehr gepflegt werden wird.
iTaskmanager
Tier II
Tier I
Theoretisch hat @Patschi vollkommen recht. Debian 7.x hat zwar noch bis 04/18 Support, aber mit der Zeit kommen immer wieder Abhängigkeiten/Pakete, die nur mit Debian 8.x funktionieren. In diesem Falle auch mit TeamSpeak (da Glibc).
Ein Workaround wäre, wie du bereits schon geschrieben hast, eine ältere TeamSpeak-Client-Version zu benutzen, aber davon ist dringend abzuraten. Update einfach Debian und gut ist. Wie das funktioniert, siehe letzten Post von mir. Es ist sehr einfach und der Thread von mir erklärt alles sehr ausführlich.
