Issue when trying to run bot
ygtripps
So I recently encountered an issue where my bot randomly stopped working. It was working previously, but after I was doing some work with my box I guess one of the apt-get update's messed with something. Now whenever I run the xinit command I get this:
sinusbot@vengyn:/opt/ts3soundboard$ LC_ALL="en_US.UTF-8" ./sinusbot
sinusbot@vengyn:/opt/ts3soundboard$ xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension Present
Initializing built-in extension DRI3
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension SELinux
Initializing built-in extension GLX
/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: symbol lookup error: /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: undefined symbol: _ZN9QMetaType22registerNormalizedTypeERK10QByteArrayPFvPvEPFS3_S3_PKvEi6QFlagsINS_8TypeFlagEEPK11QMetaObject
Needed info:
 - Operating System: Ubuntu 14.04.4 LTS
 - Kernel: Linux 3.14.32-xxxx-grs-ipv6-64 x86_64
 - Load Average: 0.00 0.03 0.10
 - Uptime: 10 days, 8 hours, 50 minutes, 24 seconds
 - OS Updates: 61 (updates available!)
 - OS APT Last Update: 15.09.2016 23:47:21 EDT -04:00:00
    CPU(s):                4
    Thread(s) per core:    1
    Core(s) per socket:    4
    Socket(s):             1
    CPU MHz:               2957.109
 - RAM: 814.45 MB/15.56 GB in use (5%)
 - SWAP: 0 B/510.99 MB in use (0%)
 - DISK: 47.44 GB/1.65 TB in use (2%)
   > libglib: 2.40.2-0ubuntu1
 - Binary: /opt/ts3soundboard/sinusbot (MD5 Hash: 8b94daaaf3ffd829669e70a3c6a5843d)
 - Version: 0.9.12-58b509d
   - Bot Plugin: 2c207af25e3000543d85b5f4275ef053
   - TS3 Client: 2c207af25e3000543d85b5f4275ef053
   - YoutubeDLPath = not set (does exist anyway, version: 2016.07.16)
 - Report date: 16.09.2016 00:09:24 EDT -04:00:00 (timezone: America/Toronto)
 - youtube-dl Version: 2016.07.16
 - DiagScript version: 0.4.6
P.S. If you need anything else just tell me.
ygtripps
Well apparently I was missing a lot of dependencies: "apt-get install dbus-x11 xfonts-100dpi xfonts-75dpi xfonts-cyrillic libasound2:i386 libasound2 libarchive-dev libpulse-dev pulseaudio libxext-dev". Those which weren't mentioned in the github page or I don't think in the FAQ. Please lock.
Thats completely non-sense, just start the sinusbot with
./sinusbot
You have nothing to do with the ts3client :)
Ui, if no output appears, then just update to the latest beta ;)
