Issues with Bot Start
Alligatoras
Hello everyone!
I am using sinusbot for a while, i am just getting an unknonw error (from my side)
Yesterday i did reset my vps andi i installed Centos.
So i did use the following guide to install it: https://forum.sinusbot.com/threads/centos-6-install-guide.388/
Sinusbot Version: 0.10.8-71ba94b
I can start the instance and i can login to the panel. The issue is that the teamspeak client doesn't connect.
I am sending the logfile bellow.
Thank you in responce,
Alligatoras
2017-11-22T18:23:07+02:00 Storing configuration.
2017-11-22T18:22:50+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-11-22T18:22:50+02:00 TS |INFO |ClientUI |1 |Connect to server: 217.***.***.***
2017-11-22T18:22:50+02:00 TS |INFO |ClientUI | |ts3server: 217.***.***.***?port=9987&nickname=Dance.FM&password=&channel=&channelpassword=
2017-11-22T18:22:50+02:00 TS |INFO |ClientUI | |Using configuration location: /home/music/sinusbot8087/data/ts3/acae9362-3eeb-47bc-86a9-0ec2df53a989/20a8cced-658c-435f-8cef-31ec2646d0f5/settings.db
2017-11-22T18:22:50+02:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-11-22T18:22:50+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-11-22T18:22:50+02:00 TS |INFO | | |*** Time [INIT]: 140
2017-11-22T18:22:50+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 140
2017-11-22T18:22:50+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-11-22T18:22:50+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-11-22T18:22:50+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-11-22T18:22:50+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-11-22T18:22:50+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-11-22T18:22:50+02:00 TS |ERROR |SoundBckndIntf| |/home/music/sinusbot8087/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2017-11-22T18:22:50+02:00 TS |ERROR |PulseAudio | |pa_context_connect failed
2017-11-22T18:22:50+02:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2017-11-22T18:22:50+02:00 TS |INFO | | |Using hardware aes
2017-11-22T18:22:50+02:00 TS |INFO | | |SystemInformation: Linux 3.10.0-693.5.2.el7.x86_64 #1 SMP Fri Oct 20 20:32:50 UTC 2017 x86_64 Binary: 64bit
2017-11-22T18:22:50+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-11-22T18:22:50+02:00 Starting instance ts3server://217.***.***.***?port=9987&nickname=Dance.FM&password=&channel=&channelpassword=
2017-11-22T18:22:50+02:00 Could not insert into Profiles-Tableno such table: Profiles
2017-11-22T18:22:50+02:00 Could not delete from Profilesno such table: Profiles
2017-11-22T18:22:50+02:00 Could not create Notifications-Tabletable Notifications already exists
2017-11-22T18:22:50+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017-11-22T18:22:50+02:00 Could not create Chat-Tabletable Chat already exists
2017-11-22T18:22:37+02:00 Initialization complete
CentOS is not officially supported
