Licence bots can't connect (mount directory with nfs)
Floflobel
I open a new thread because I try to solve my problem with the advice of @Xuxe.
Last Topic: https://forum.sinusbot.com/threads/...t-mount-directory-with-sshfs.3871/#post-20965
I try to mount a NFS Server and it's work but I can't connect my other bots, is the same problem..
Parameters of NFS Server: "rw,sync,all_squash,no_subtree_check,anonuid=1003,anongid=1004"
1003 and 1004 egal to user and group sinusbot
Anyone have a solution ?
as already said in the last topic, we don't support NFS/SSHFS. It isn't a bot issue.
This is a question for a linux forum and not for sinusbot.
Any way just a little recommendation, please don't use NFS over insecure connections without VPN for critical data. It is not encrypted.
Back to topic, you don't provide any information what you try to achieve...
Do you want to store the music on a external system/share? Maybe you just change the DataFolder Path in your config.ini to point to your nfs share. So it should not have a affect on the client or bot.
Floflobel
thank's for your return Xuxe.
I did not understand that NFS was not supported either..
If follow your recommendation for insecure connection and use a secure protocol.
Yes, I try to export the storage of data to another disk because is verry expensive to buy a storage for a VPS.
I'm stupid I had not thought of exporting just the data instead of exporting the bot with.
But my bot connect and diconnect after fiew minutes have you got an idea for solve the problem ?
Log:
2017-07-10T20:30:16+02:00 Storing configuration.
2017-07-10T20:30:14+02:00 TSClient quit.
2017-07-10T20:30:14+02:00 Closed.
2017-07-10T20:30:14+02:00 TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2017-07-10T20:30:14+02:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2017-07-10T20:30:13+02:00 New connection status 3; Error 0
2017-07-10T20:30:13+02:00 New connection status 2; Error 0
2017-07-10T20:30:13+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2017-07-10T20:30:12+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2017-07-10T20:30:12+02:00 New connection status 1; Error 0
2017-07-10T20:30:12+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-07-10T20:30:12+02:00 TS |INFO | | |Statistics report: Not yet, next report on Thu Jul 13 22:11:38 2017
2017-07-10T20:30:12+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-07-10T20:30:12+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 5
2017-07-10T20:30:12+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-07-10T20:30:10+02:00 TS |INFO |ClientUI |1 |Initiating connection: IP:9987 IP
2017-07-10T20:30:10+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-07-10T20:30:10+02:00 TS |INFO |ClientUI |1 |Connect to server: IP
2017-07-10T20:30:10+02:00 TS |INFO |ClientUI | |ts3server: IP?port=9987&nickname=.%C4%B1l%C4%B1.l%C4%B1.%20Musique%203%20.%C4%B1l%C4%B1..&password=&cid=98&channelpassword=
2017-07-10T20:30:10+02:00 TS |INFO |ClientUI | |Using configuration location: /mnt/nfs/sinusbot1/data/ts3/1aff5687-bd9d-4df4-a9ef-6e32edf5d30d/fd101804-610e-da0f-2334-9b03d366b7f2/settings.db
2017-07-10T20:30:10+02:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-07-10T20:30:10+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-07-10T20:30:09+02:00 TS |INFO | | |*** Time [INIT]: 547
2017-07-10T20:30:09+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 547
2017-07-10T20:30:08+02:00 TS |INFO | | |*** Time [CONTACTS]: 379
2017-07-10T20:29:46+02:00 Storing configuration.
2017-07-10T20:29:36+02:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2017-07-10T20:29:35+02:00 TS |ERROR |Query | |bind failed on 127.0.0.1:25639
2017-07-10T20:29:35+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-07-10T20:29:35+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-07-10T20:29:35+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-07-10T20:29:35+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-07-10T20:29:35+02:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2017-07-10T20:29:35+02:00 TS |ERROR |PulseAudio | |pa_context_connect failed
2017-07-10T20:29:35+02:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2017-07-10T20:29:35+02:00 TS |INFO | | |Using hardware aes
2017-07-10T20:29:35+02:00 TS |INFO | | |SystemInformation: Linux 4.4.0-81-generic #104-Ubuntu SMP Wed Jun 14 08:17:06 UTC 2017 x86_64 Binary: 64bit
2017-07-10T20:29:35+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-07-10T20:29:35+02:00 TS>DUMP defined! Dumpdir is: /mnt/nfs/sinusbot1/data/ts3/1aff5687-bd9d-4df4-a9ef-6e32edf5d30d/fd101804-610e-da0f-2334-9b03d366b7f2/crashdumps
2017-07-10T20:29:35+02:00 TS>Crashdump ENABLED, directory is: /mnt/nfs/sinusbot1/data/ts3/1aff5687-bd9d-4df4-a9ef-6e32edf5d30d/fd101804-610e-da0f-2334-9b03d366b7f2/crashdumps
2017-07-10T20:29:33+02:00 Starting instance ts3server://IP?port=9987&nickname=.%C4%B1l%C4%B1.l%C4%B1.%20Musique%203%20.%C4%B1l%C4%B1..&password=&cid=98&channelpassword=
2017-07-10T20:29:33+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2017-07-10T20:29:33+02:00 Could not delete from FileTransferno such table: FileTransfer
2017-07-10T20:29:33+02:00 Could not create Notifications-Tabletable Notifications already exists
2017-07-10T20:29:33+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017-07-10T20:29:33+02:00 Could not create Chat-Tabletable Chat already exists
2017-07-10T20:29:33+02:00 About to run.
2017-07-10T20:29:33+02:00 Prespawn.
