Licence Q & Radom question
kenshironanto
Hello everyone!
Well, we're in general Questions so! :D
Firstly my main question :
- I seriously thinking for a licence but 1 point block me : IP adress
- Actually, our bot server run on linux, with a ssl domain name, everything is working like charm, but IP is DyN - So i read somewhere that licence is for a "TeamSpeak-Server IP address and the unique ServerUID" - and if you need to change IP you should ask for another licence --
- How actually working the licence ask?
I mean, should i need to send a message or something else or it's like automatic renew? i hope so, cause the Ip change every 15 day or is that possible to have something like "your TeamSpeak-Server "domain name" and the unique ServerUID" Could it be possible?
If it's not, it can be very annoying to always distrub Sinusbot team for re-asking licence... (it can be but annoying for eatch others)
Ok, second question about Speech reconization :)
- Is actually working for licenced Sinusbot?
And my final question and i stop boring you :D
About some DSP "plugins" :
- I would like to know if it can be techniquely possible to add DSP plugins?
I mean for exemple "i would like to add" :)p:p) a PITCH DSP, for pitch / tempo modification while playing - So my question is : is that possible? or is it actually possible with plugins sections with a correct one?
Thanks for all you've done, great team! Hope best for years !!!
With the new version we actually support changing IPs, you can request a license with your current IP and then change ist yourself to your domain in the sinusbot webinterface.
There is a way to manipulate the sound with a ffmpeg compatible filter string: audio.setAudioFilter(...) => see documentation
There was also an example script that uses this feature (not sure if it comes with the bot per default)
kenshironanto
Thanks for fast reply !
Antoher question lead me there : When you obtain donator grade
- How you get a license file?
- How time it get?
I'm in SinusBot 0.10.8-71ba94b
As i understand you obtain a private.key file (but how?), Is webinterface change after putting private.key in folder? (Actually i don't see anywhere or any section where you can ask)
I wll loking in the manual for DSP, i bet this is pain and hell to understand :D
when you donate (you are a donator)
see faq/wiki
How time it get?
no ETA
you get this file on the same page you request the license after your request was approved
might be, I haven't used it yet ^^
