Lieder werden übersprungen
Kamikaze
Betriebssystem: Windows Server 2012 R2
SinusBot Version: 0.9.16-34aebc2
TS3 Version: 3.0.19.4
Config.ini:
PHP:
ListenHost = "******"
DataDir = "C:\\SinusBot\\data\\"
YoutubeDLPath = "youtube-dl.exe"
EnableDebugConsole = true
UploadLimit = 262144000
EnableWebStream = true
LogFile = "mylogfile.log"
LicenseKey = "********"
  BufferSize = 1048576
  MaxDownloadRate = 1073741824
  AllowReload = true
  UserAgent = "SinusBot (0.9.13-d80beba)"
Harware:
- CPU: Intel Xeon E5-2683 v3 2GHz (2 Prozessoren)
- RAM: 2GB
CPU ist kaum ausgelastet, RAM liegt meist bei 70-80%
Instanz-Log:
2017-01-09T13:33:30+01:00 Storing configuration.
2017-01-09T13:33:30+01:00 New channel
2017-01-09T13:33:28+01:00 Playing next from playlist: ytdl://ytdl/?url=frZsJx77qiA&album=Cathode&title=Don%27t+Stop
2017-01-09T13:33:28+01:00 Channels now zero
2017-01-09T13:33:28+01:00 Deleting channel
2017-01-09T13:33:28+01:00 SAMPLEX 4800 60
2017-01-09T13:33:28+01:00 Done playing
2017-01-09T13:29:40+01:00 Storing configuration.
2017-01-09T13:29:38+01:00 New channel
2017-01-09T13:29:36+01:00 Playing next from playlist: ytdl://ytdl/?url=3ehpdaGVlKo&album=Big+Wild&title=Invincible+%28feat.+iDA+HAWK%29+%5BManila+Killa+Remix%5D
2017-01-09T13:29:36+01:00 Channels now zero
2017-01-09T13:29:36+01:00 Deleting channel
2017-01-09T13:29:36+01:00 SAMPLEX 3840 60
2017-01-09T13:29:36+01:00 Done playing
2017-01-09T13:26:47+01:00 Storing configuration.
2017-01-09T13:26:38+01:00 Deleting channel
2017-01-09T13:26:37+01:00 New channel
2017-01-09T13:26:34+01:00 PLAY-LIST [admin] 9cf5803a-ae78-4336-8991-49492c72fdb1 / 13 OK
2017-01-09T13:26:34+01:00 Reseeding PRNG
2017-01-09T13:26:21+01:00 Deleting channel
2017-01-09T13:26:21+01:00 New channel
2017-01-09T13:26:20+01:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2017-01-09T13:26:20+01:00 2568/insufficient client permissions/b_channel_modify_codec
2017-01-09T13:26:19+01:00 New connection status 4; Error 0
2017-01-09T13:26:19+01:00 Loni joined the channel
2017-01-09T13:26:19+01:00 New connection status 3; Error 0
2017-01-09T13:26:19+01:00 New connection status 2; Error 0
2017-01-09T13:26:19+01:00 New connection status 1; Error 0
2017-01-09T13:26:18+01:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2017-01-09T13:26:18+01:00 TS>DUMP defined! Dumpdir is: C:\SinusBot\data\/ts3/7a822722-b4d6-4946-b815-5191e2532651/77227ffc-a191-46dd-8cda-7e12f4a0b5d3/\crashdumps
2017-01-09T13:26:18+01:00 TS>Crashdump ENABLED, directory is: C:\SinusBot\data\/ts3/7a822722-b4d6-4946-b815-5191e2532651/77227ffc-a191-46dd-8cda-7e12f4a0b5d3/\crashdumps
2017-01-09T13:26:18+01:00 New channel
2017-01-09T13:26:18+01:00 Starting instance ts3server://213.165.89.6?port=8888&nickname=Puhb%C3%A4r%20%7C%20Winnie%20%5BBOT%5D&password=&cid=1929&channelpassword=
2017-01-09T13:26:18+01:00 Reseeding PRNG
2017-01-09T13:26:18+01:00 Auto-Playing last track
2017-01-09T13:26:17+01:00 Last track was , will auto-play soon
2017-01-09T13:26:17+01:00 Auto-Starting 7a822722-b4d6-4946-b815-5191e2532651/77227ffc-a191-46dd-8cda-7e12f4a0b5d3 in 500 ms...
2017-01-09T13:26:17+01:00 Initialization complete
2017-01-09T13:26:17+01:00 [Next Track Please] The percentage has to be a number between 0 and 100
2017-01-09T13:26:17+01:00 [Next Track Please] Error: Stopping the script.
2017-01-09T13:26:17+01:00 [Next Track Please] No command defined ... using the default one: ".next"
2017-01-09T13:26:17+01:00 [Next Track Please] Next track please! v1.4 by good_live & Raphael Touet for SinusBot v0.9.9-50e8ba1 (and above)
2017-01-09T13:26:17+01:00 [Next Track Please] Loading...
2017-01-09T13:26:17+01:00 Loading script Next Track Please
2017-01-09T13:26:17+01:00 Loading script ShowPlaylists
2017-01-09T13:26:17+01:00 Loading script aloneMode
2017-01-09T13:26:17+01:00 Loading script Reconnect
2017-01-09T13:26:17+01:00 [Changecodec] Change Codec Load v1.4
2017-01-09T13:26:17+01:00 Loading script Changecodec
Problembeschreibung
Bei meinem Bot sind mehrer Playlists vorhande die per Youtube runtergeladen wurden. Auch mehrere einzelne Lieder im allgm. Ordner von Youtube. Bei knapp 95-99% steht bei Dauer überall 0:00.
Das aktuelle Problem ist das alle Lieder die von YouTube runtergeladen wurden nicht bis zum Ende abgespielt werden manchmal auch nur bis zur hälfte.
Was ich schon versucht habe:
- Bot grundauf neuinstalliert
- Playlists / Lieder gelöscht und nochmal neu runter geladen
- Forum nach ähnlichen Threads durchsucht
Habe im Forum gelesen das es helfen sollte den SampleInterval zu ändern. Wäre das in meinem Fall hoch- oder runterschrauben?
Falls dies keine Lösung ist, gibt es noch eine andere oder alternativen?
Danke im Vorraus für die Zeit :)
I'm having a related issue but the songs play but half way through they keep skipping. It is rather frustrating and never had this before.
