EmyzYT
2019-10-28T17:42:20+01:00 closing channels
2019-10-28T17:42:20+01:00 eof from voice
2019-10-28T17:42:19+01:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-10-28T17:42:19+01:00 Closed.
2019-10-28T17:42:19+01:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: symbol lookup error: /opt/sinusbot/teamspeak3-client/libQt5XcbQpa.so.5: undefined symbol: FT_Get_Font_Format
2019-10-28T17:42:19+01:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-10-28T17:42:19+01:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019-10-28T17:42:19+01:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-10-28T17:42:19+01:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-10-28T17:42:19+01:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5)
2019-10-28T17:42:19+01:00 TS |INFO |Addons | |Checking for addon updates...
2019-10-28T17:42:19+01:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-10-28T17:42:19+01:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-10-28T17:42:19+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-10-28T17:42:19+01:00 TS |INFO | | |Using hardware aes
2019-10-28T17:42:19+01:00 TS |INFO | | |SystemInformation: Linux 4.15.18-20-pve #1 SMP PVE 4.15.18-46 (Thu, 8 Aug 2019 10:42:06 +0200) x86_64 Binary: 64bit
2019-10-28T17:42:19+01:00 TS |INFO | | |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2019-10-28T17:42:19+01:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/4a15ada7-9b84-4e58-8e42-f78694921edc/5d4ff021-014c-453d-b130-125d3ac39545/crashdumps
2019-10-28T17:42:19+01:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/4a15ada7-9b84-4e58-8e42-f78694921edc/5d4ff021-014c-453d-b130-125d3ac39545/crashdumps
2019-10-28T17:42:19+01:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=Sergejs%20Musikbot&password=&channel=&channelpassword=
2019-10-28T17:42:19+01:00 Could not insert into News-Tableno such table: News
2019-10-28T17:42:19+01:00 Could not delete from Newsno such table: News
2019-10-28T17:42:19+01:00 Could not insert into Profiles-Tableno such table: Profiles
2019-10-28T17:42:19+01:00 Could not delete from Profilesno such table: Profiles
2019-10-28T17:42:19+01:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-10-28T17:42:19+01:00 Could not delete from FileTransferno such table: FileTransfer
2019-10-28T17:42:19+01:00 Could not create Notifications-Tabletable Notifications already exists
2019-10-28T17:42:19+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-10-28T17:42:19+01:00 Could not create Chat-Tabletable Chat already exists
2019-10-28T17:42:19+01:00 About to run.
2019-10-28T17:42:19+01:00 Prespawn.
2019-10-28T17:42:05+01:00 script command loaded
2019-10-28T17:42:05+01:00 module registered as command
2019-10-28T17:42:05+01:00 registered callback for event chat
2019-10-28T17:42:05+01:00 Initialization complete
2019-10-28T17:42:05+01:00 executing script command
Ich bitte um hilfe da es damals immer funktionierte
Daten vom Vserver:
Betriebssystem: Debian 8 amd64
Ram: 2GB
2019/10/28 16:42:05 4a15ada7 INFO Loading instances
2019/10/28 16:42:05 4a15ada7 INFO Loading instance://5d4ff021-014c-453d-b130-125d3ac39545
2019/10/28 16:42:05 4a15ada7 5d4ff021 DEBUG executing script command
2019/10/28 16:42:05 4a15ada7 5d4ff021 INFO Initialization complete
2019/10/28 16:42:05 4a15ada7 5d4ff021 DEBUG registered callback for event chat
2019/10/28 16:42:05 4a15ada7 5d4ff021 DEBUG module registered as command
2019/10/28 16:42:05 4a15ada7 5d4ff021 INFO script command loaded
2019/10/28 16:42:05 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/10/28 16:42:05 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/10/28 16:42:05 [GENERAL/YTDL ] INFO youtube-dl checking...
2019/10/28 16:42:06 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2019/10/28 16:42:06 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:27015
2019/10/28 16:42:06 [GENERAL/RADIO ] INFO RadioStation data loaded
2019/10/28 16:42:07 [GENERAL/RADIO ] INFO Imported radio stations
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG Prespawn.
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG About to run.
2019/10/28 16:42:19 4a15ada7 5d4ff021 WARN Could not create Chat-Tabletable Chat already exists
2019/10/28 16:42:19 4a15ada7 5d4ff021 WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019/10/28 16:42:19 4a15ada7 5d4ff021 WARN Could not create Notifications-Tabletable Notifications already exists
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG Could not delete from FileTransferno such table: FileTransfer
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2019/10/28 16:42:19 4a15ada7 5d4ff021 WARN Could not delete from Profilesno such table: Profiles
2019/10/28 16:42:19 4a15ada7 5d4ff021 WARN Could not insert into Profiles-Tableno such table: Profiles
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG Could not delete from Newsno such table: News
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG Could not insert into News-Tableno such table: News
2019/10/28 16:42:19 4a15ada7 5d4ff021 INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=Sergejs%20Musikbot&password=&channel=&channelpassword=
2019/10/28 16:42:19 X [MAIN] New connection
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/4a15ada7-9b84-4e58-8e42-f78694921edc/5d4ff021-014c-453d-b130-125d3ac39545/crashdumps
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/4a15ada7-9b84-4e58-8e42-f78694921edc/5d4ff021-014c-453d-b130-125d3ac39545/crashdumps
2019/10/28 16:42:19 4a15ada7 5d4ff021 INFO TS |INFO | | |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2019/10/28 16:42:19 4a15ada7 5d4ff021 INFO TS |INFO | | |SystemInformation: Linux 4.15.18-20-pve #1 SMP PVE 4.15.18-46 (Thu, 8 Aug 2019 10:42:06 +0200) x86_64 Binary: 64bit
2019/10/28 16:42:19 4a15ada7 5d4ff021 INFO TS |INFO | | |Using hardware aes
2019/10/28 16:42:19 4a15ada7 5d4ff021 INFO TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019/10/28 16:42:19 4a15ada7 5d4ff021 INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
2019/10/28 16:42:19 4a15ada7 5d4ff021 INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019/10/28 16:42:19 4a15ada7 5d4ff021 INFO TS |INFO |Addons | |Checking for addon updates...
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5)
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: symbol lookup error: /opt/sinusbot/teamspeak3-client/libQt5XcbQpa.so.5: undefined symbol: FT_Get_Font_Format
2019/10/28 16:42:19 4a15ada7 5d4ff021 DEBUG Closed.
2019/10/28 16:42:19 4a15ada7 5d4ff021 INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/10/28 16:42:20 4a15ada7 5d4ff021 DEBUG eof from voice
2019/10/28 16:42:20 4a15ada7 5d4ff021 DEBUG closing channels
2019/10/28 16:42:35 4a15ada7 5d4ff021 DEBUG Storing configuration.
