Log level
ich habe den bot instaliert ca 24 stunden danach startet er nicht mehr und es kommt das :
2019-03-31T18:26:37+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-03-31T18:26:37+02:00 Closed.
2019-03-31T18:26:37+02:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2019-03-31T18:26:37+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-03-31T18:26:37+02:00 Starting instance ts3server://Antivaze.de?port=9987&nickname=LobbyBOT&password=&channel=&channelpassword=
2019-03-31T18:26:37+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-03-31T18:26:37+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-03-31T18:26:37+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-03-31T18:26:37+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-03-31T18:26:37+02:00 Could not create Chat-Tabletable Chat already exists
2019-03-31T18:26:37+02:00 About to run.
2019-03-31T18:26:37+02:00 Prespawn.
2019-03-31T18:26:36+02:00 Storing configuration.
2019-03-31T18:26:34+02:00 New channel 0b1fe879-19e1-4c23-9833-237e8c49b99d () ID 83431a0e-369f-42e3-bc4f-fec20e0450bc (cc 0)
2019-03-31T18:26:34+02:00 Playing idle tracktrack://0b1fe879-19e1-4c23-9833-237e8c49b99d
2019-03-31T18:26:33+02:00 Done playing
2019-03-31T18:26:33+02:00 Channels now zero
2019-03-31T18:26:33+02:00 Deleting channel 0b1fe879-19e1-4c23-9833-237e8c49b99d () ID faef7e2c-572d-4cdb-b941-da2fbf0b936b (cc 1)
2019-03-31T18:26:33+02:00 Removing closed channel 0b1fe879-19e1-4c23-9833-237e8c49b99d () ID faef7e2c-572d-4cdb-b941-da2fbf0b936b
2019-03-31T18:26:23+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-03-31T18:26:23+02:00 Closed.
2019-03-31T18:26:23+02:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2019-03-31T18:26:23+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-03-31T18:26:23+02:00 Starting instance ts3server://Antivaze.de?port=9987&nickname=LobbyBOT&password=&channel=&channelpassword=
ich bitte um hilfe
ich habe den fehler nei behoben bekommen ich habe debian 8 neuste version om bot und mit sinusbot-installer.de istaliert
Bitte nimm dir doch bitte wenigstens mehr als 10 Sekunden Zeit, um hier zu antworten. Dann haben wir die Informationen, und können DIR helfen, DEIN Problem zu lösen.
Lese dir nochmal das hier durch, setzte LogLevel = 10, und poste bitte die Ausgabe. (gerne auch in einem Code-Block, der Übersichtlichkeit wegen)
https://forum.sinusbot.com/threads/lies-mich-bevor-du-schreibst.116/
Des weiteren helfen uns auch folgende Informationen, die ganze einfach über das Diagnostik Skript zusammen getragen werden können.
https://forum.sinusbot.com/threads/diagsinusbot-sh-sinusbot-diagnostik-script.832/#post-4419
SINUSBOT Version : Neuste
Teamspeak Version : 3.2.3 (zu 10% sicher) xD
betriebsystem : debian 8 jessi
hardware : dedicated Server 2x Intel Xeon E5-2630V4 Ram 128GB RAM
Browser : chrome und firefox
freier specher : 73Gb Ram frei 274 Gb ssd frei
Config.ini
TS3Path = "TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64"
DataDir = "/opt/SinusPort-8088/data/"
ListenPort = 8088
LicenseKey = "WEGESTRICHEN"
V1 = ""
V2 = ""
log :
2019-04-01T20:07:44+02:00 Storing configuration.
2019-04-01T20:07:43+02:00 New channel 0b1fe879-19e1-4c23-9833-237e8c49b99d () ID 273a69c7-907d-40a1-8ceb-3a478eea1e99 (cc 0)
2019-04-01T20:07:43+02:00 Playing idle tracktrack://0b1fe879-19e1-4c23-9833-237e8c49b99d
2019-04-01T20:07:42+02:00 Done playing
2019-04-01T20:07:42+02:00 Channels now zero
2019-04-01T20:07:42+02:00 Deleting channel 0b1fe879-19e1-4c23-9833-237e8c49b99d () ID eedbd484-d545-4357-a72d-750c9e95cc6a (cc 1)
2019-04-01T20:07:42+02:00 Removing closed channel 0b1fe879-19e1-4c23-9833-237e8c49b99d () ID eedbd484-d545-4357-a72d-750c9e95cc6a
2019-04-01T20:07:17+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-04-01T20:07:17+02:00 Closed.
2019-04-01T20:07:17+02:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2019-04-01T20:07:17+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-04-01T20:07:17+02:00 Starting instance ts3server://Antivaze.de?port=9987&nickname=LobbyBOT&password=&channel=&channelpassword=
2019-04-01T20:07:17+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-04-01T20:07:17+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-04-01T20:07:17+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-04-01T20:07:17+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-04-01T20:07:17+02:00 Could not create Chat-Tabletable Chat already exists
2019-04-01T20:07:17+02:00 About to run.
2019-04-01T20:07:17+02:00 Prespawn.
2019-04-01T20:06:44+02:00 Storing configuration.
2019-04-01T20:06:37+02:00 TSClient quit.
2019-04-01T20:06:37+02:00 Closed.
2019-04-01T20:06:37+02:00 TS>The X11 connection broke (error 1). Did the X11 server die?
2019-04-01T20:06:37+02:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2019-04-01T20:06:37+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-04-01T20:06:37+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-04-01T20:06:37+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/SinusPort-8088/data/ts3/7598d9b8-87e0-4a7c-b0c1-d426f19d89aa/67dbe450-1bf1-4ca5-a1fc-3daec7b5a6e1/settings.db
2019-04-01T20:06:37+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2019-04-01T20:06:37+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2019-04-01T20:06:37+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/SinusPort-8088/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019-04-01T20:06:37+02:00 TS |INFO | | |*** Time [INIT]: 173
2019-04-01T20:06:37+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 172
2019-04-01T20:06:37+02:00 TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2019-04-01T20:06:37+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2019-04-01T20:06:37+02:00 Could not send var command: HTTP returned an error: Error; Code: 500; Message: Error
2019-04-01T20:06:37+02:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2019-04-01T20:06:37+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2019-04-01T20:06:37+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-04-01T20:06:37+02:00 TS |INFO |Addons | |Checking for addon updates...
2019-04-01T20:06:37+02:00 TS |INFO | | |successfully downloaded revocation list
2019-04-01T20:06:37+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-04-01T20:06:37+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-04-01T20:06:36+02:00 TS |INFO | | |Using hardware aes
2019-04-01T20:06:36+02:00 TS |INFO | | |SystemInformation: Linux 3.16.0-8-amd64 #1 SMP Debian 3.16.64-1 (2019-03-25) x86_64 Binary: 64bit
2019-04-01T20:06:36+02:00 TS |INFO | | |TeamSpeak 3 Client 3.1.8 (2018-01-22 09:50:07)
2019-04-01T20:06:36+02:00 TS>DUMP defined! Dumpdir is: /opt/SinusPort-8088/data/ts3/7598d9b8-87e0-4a7c-b0c1-d426f19d89aa/67dbe450-1bf1-4ca5-a1fc-3daec7b5a6e1/crashdumps
2019-04-01T20:06:36+02:00 TS>Crashdump ENABLED, directory is: /opt/SinusPort-8088/data/ts3/7598d9b8-87e0-4a7c-b0c1-d426f19d89aa/67dbe450-1bf1-4ca5-a1fc-3daec7b5a6e1/crashdumps
2019-04-01T20:06:34+02:00 Starting instance ts3server://Antivaze.de?port=9987&nickname=LobbyBOT&password=&channel=&channelpassword=
2019-04-01T20:06:34+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-04-01T20:06:34+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-04-01T20:06:34+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-04-01T20:06:34+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-04-01T20:06:34+02:00 Could not create Chat-Tabletable Chat already exists
2019-04-01T20:06:34+02:00 About to run.
2019-04-01T20:06:34+02:00 Prespawn.
2019-04-01T20:06:15+02:00 new track info: Antivaze.de - LobbyMusik (416e746976617a652e6465202d204c6f6262794d7573696b)
2019-04-01T20:06:15+02:00 New channel 0b1fe879-19e1-4c23-9833-237e8c49b99d () ID eedbd484-d545-4357-a72d-750c9e95cc6a (cc 0)
2019-04-01T20:06:15+02:00 Auto-Playing last track
2019-04-01T20:06:14+02:00 Last track was 0b1fe879-19e1-4c23-9833-237e8c49b99d, will auto-play soon
2019-04-01T20:06:14+02:00 Initialization complete
2019-04-01T20:06:14+02:00 Loading script Reconnect
"Neueste" gibt es nicht! Es gibt nur exakte Versionsnummern wie zB. 1.0.0-alpha.6-a47ac17
Bitte im Webinterface die Version überprüfen, die unter Settings -> Info -> About steht!
Teamspeak Version : 3.2.3 (zu 90% sicher)
Zu 100% sicher, dass dies nicht korrekt ist!
DataDir = "/opt/SinusBOT/data/"
Das passt einfach hinten und vorne nicht. Betreibst du mehrere Installationen des Sinusbots auf einem Server?
Die config.ini stimmt in den Pfaden nicht mit dem überein, was du ausführst!
Kurzum ... hier sind so viele Ungereimtheiten, dass es mich nicht wundert, dass hier nichts geht. Mache ein Backup der Daten, fang nochmal bei Null an, und starte eine saubere Installation.
habe ich mehrmals versucht ich habe gestern das nicht geschreiben das war mein 2 owner ich weiss nicht wieso er in der config hier das anders geschrieben hat alls es ist aber hier ist mal die RICHTIGE config :
ListenPort = 8088
LicenseKey = "Io6in4Vp9JQmOf5e5oLdVdJKIbn5VLq1KfB/+termVk="
V1 = ""
V2 = ""
Himsel
Folgende Fragen sind aber immernoch unbeantwortet.
Deine Sinusbot Version?
Hast du mal in den vorgeschlagenen Threads geschaut und probiert ob sinusbot manuell startet?
(deshalb die Frage gewesen, wie du Sinusbot startest)
Merkwürdig auch, dass der Bot 24 std gelaufen ist und plötzlich garnicht mehr. Hast du nicht zufällig, irgendwelche Änderungen getätigt?
Und den Bot hast du wirklich von Null an neu installiert, wie @TwentyFour vorgeschlagen hat? Auch wenn die jetzige config besser passt.
Hilfe Plus
Moin,
sollte nach einem Server neustart wieder gehen. Schaue das Du die neuste SinusBot Version besitzt (1.0.0). Auch einmal den SinusBot Manuell starten.
Kurz tut ->
Sicherheitshalber:
rm /tmp/.sinusbot.lock && rm -R /tmp/.X11-unix
Gehe in den SinusBot Ordner, meist findbar unter:
/opt/sinusbot/
Wechsel zu den SinusBot Benutzer:
z. B. su sinusbot
Starte den SinusBot mit
./sinusbot &
Den Screen kann man dann mit
STRG + C
verlassen!
Mehr kann ich dazu auch nicht schreiben, da wie hier schon geschrieben noch Informationen fehlen...
MfG Tom
