D
Deleted member 6348
Guest
I have just install the sinusbot with the installer and (on first launch) it logged tp my localhost server, and after is wasn't able to restart it. When i launch it with the sinusbot user there is an error
And when I start it as root (with the argument -RunningAsRootIsEvilAndIKnowThat) the bot start but don't log on TS3 Server and i try to log in MYSERVERIP:8087 with the default password and username the server says that i'm unauthorized
sinusbot@MYSERVER:/opt/sinusbot$ ./sinusbot
Version: 0.9.11-d20ec68
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2016/04/14 03:38:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2016/04/14 03:38:29 fdad7481 INFO Loading instances
2016/04/14 03:38:29 X [MAIN] Starting up fake x-server...
2016/04/14 03:38:29 x [MAIN] ERROR: listen unix /tmp/.X11-unix/X40: bind: address already in use
root@MYSERVER:/opt/sinusbot# ./sinusbot -RunningAsRootIsEvilAndIKnowThat
2016/04/14 03:40:54 [GENERAL/!!!!!!!] WARN !!!!!!! YOU ARE RUNNING THE BOT AS UID 0 (ROOT) WITHOUT HAVING SET ANOTHER UID. THIS IS A SERIOUS SECURITY VIOLATION !!!!!!!!
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2016/04/14 03:40:54 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2016/04/14 03:40:54 fdad7481 INFO Loading instances
2016/04/14 03:40:54 fdad7481 INFO Loading instance://1216009a-ebbc-4123-a050-e930ebb847c1
2016/04/14 03:40:54 fdad7481 1216009a INFO Initialization complete
2016/04/14 03:40:54 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2016/04/14 03:40:54 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2016/04/14 03:40:54 [GENERAL/YTDL ] INFO youtube-dl checking...
2016/04/14 03:40:54 X [MAIN] Starting up fake x-server...
2016/04/14 03:40:55 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2016/04/14 03:40:55 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2016/04/14 03:40:55 [GENERAL/RADIO ] INFO RadioStation data loaded
2016/04/14 03:40:55 [GENERAL/RADIO ] INFO Imported radio stations
2016/04/14 03:41:15 fdad7481 INFO LOGIN [admin] FAIL [IP:MYIP:63406]
