Mein Bot verbindet sich nicht!!!! Das kommt beim start brauche Hilfe!
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO | | |SystemInformation: Linux 2.6.32-48-pve #1 SMP Fri Dec 23 10:22:54 CET 2016 x86_64 Binary: 64bit
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO | | |Using hardware aes
2019/02/19 17:05:40 X [MAIN] New connection
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |ERROR |PulseAudio | |pa_context_connect failed
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |ERROR |SoundBckndIntf| |/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO | | |Loading plugin: libclientquery_plugin
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO | | |Loading plugin: liblua_plugin
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO | | |Loading plugin: libsoundbot_plugin
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO | | |Loading plugin: libtest_plugin
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |Query | |listening on 127.0.0.1:25639
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO | | |Api version is not compatible for plugin: /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/plugins/libsoundbot_plugin.so
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI | |Qt version: 5.5.0
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI | |Using configuration location: /opt/ts3soundboard/data/ts3/44ce7410-3a5e-46c2-83e3-d33d39f857da/a21925d4-976c-40e9-baf6-6928cc3eb576/settings.db
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI | |ts3server: 51.254.0.63?port=9987&nickname=Support%20Wartemusik&password=&cid=626&channelpassword=
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI |1 |Connect to server: 51.254.0.63
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI |1 |Blacklist check ok
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI |1 |Initiating connection: 51.254.0.63:9987 51.254.0.63
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device 'ts3.alsa.dummy.playbackdefault
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |ERROR |ALSA | |snd_pcm_open: Datei oder Verzeichnis nicht gefunden
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |ERROR |SoundBckndIntf| |/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libalsa_linux_amd64.so error: ALSA
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device 'ts3.alsa.dummy.capturedefault
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI |1 |Connect status: Disconnected
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI | |Last update check was: Di. Jan. 1 00:00:01 2019
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |ClientUI | |Checking for update
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |Update | |Checking for updates...
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |Update | |Check license version: 1
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |Update | |Check client version: 3.0.19.4 1468491418
2019/02/19 17:05:40 44ce7410 a21925d4 INFO TS |INFO |Update | |Update check, my version: 1445512488, latest version: 1468491418
Kir-à
Your installation is corrupted.
Do a fresh reinstall with the installer which you can find here.
3011
