Missing permission to use module db
Trsak
so i have script using db module. On startup i get this error:
script AntiProxy is requesting missing permission to use module db, disabled
config.ini contains:
[Scripts.Privileges]
  AntiProxy = ["db"]
AntiProxy.js contains:
requiredModules: ['http', "db"]
So what am I missing?
Try removing the quoted text in your config.ini
It's not needed anymore as of 1.0.0, prolly a relic from a prior installation.
Permissions are granted by enabling the script on the web frontend and saving the settings. So whenever you add new requiredModules, you'll have to go through that process again.
