Nicolazon
I have a problem :
My bot not to connect in my teamspeak :
Can you help me please ?
I have a problem :
2018-08-30T14:42:52+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-08-30T14:42:52+02:00 TS |INFO | | |Statistics report: Not yet, next report on Sat Sep 22 14:41:02 2018
2018-08-30T14:42:52+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-08-30T14:42:52+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-08-30T14:42:52+02:00 TS |ERROR |SoundBckndIntf| |/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libalsa_linux_amd64.so error: ALSA
2018-08-30T14:42:52+02:00 TS |ERROR |ALSA | |snd_pcm_open: No such file or directory
2018-08-30T14:42:52+02:00 TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device 'ts3.alsa.dummy.capturedefault
2018-08-30T14:42:51+02:00 TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device 'ts3.alsa.dummy.playbackdefault
2018-08-30T14:42:51+02:00 TS |INFO |ClientUI |1 |Initiating connection: 51.254.59.2:9987 51.254.59.2
2018-08-30T14:42:51+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2018-08-30T14:42:51+02:00 TS |INFO |ClientUI |1 |Connect to server: 51.254.59.2
2018-08-30T14:42:51+02:00 TS |INFO |ClientUI | |ts3server: 51.254.59.2?port=9987&nickname=Bot%20Musique&password=&channel=&channelpassword=
2018-08-30T14:42:51+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/dda5923c-9a5c-4198-9349-bd4220722c3f/1de62295-1946-4b89-80b6-ef3f0ab7c833/settings.db
2018-08-30T14:42:51+02:00 TS |INFO |ClientUI | |Qt version: 5.5.0
2018-08-30T14:42:51+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-08-30T14:42:51+02:00 TS |INFO | | |Api version is not compatible for plugin: /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/plugins/libsoundbot_plugin.so
2018-08-30T14:42:51+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2018-08-30T14:42:51+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2018-08-30T14:42:51+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2018-08-30T14:42:51+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2018-08-30T14:42:51+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2018-08-30T14:42:51+02:00 TS |ERROR |SoundBckndIntf| |/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2018-08-30T14:42:51+02:00 TS |ERROR |PulseAudio | |pa_context_connect failed
2018-08-30T14:42:51+02:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2018-08-30T14:42:51+02:00 TS |INFO | | |Using hardware aes
2018-08-30T14:42:51+02:00 TS |INFO | | |SystemInformation: Linux 2.6.32-042stab128.2 #1 SMP Thu Mar 22 10:58:36 MSK 2018 x86_64 Binary: 64bit
2018-08-30T14:42:51+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2018-08-30T14:42:51+02:00 Starting instance ts3server://51.254.59.2?port=9987&nickname=Bot%20Musique&password=&channel=&channelpassword=
