My bot enters the server, and after a few seconds.... lost connection
MondoPlX
2019-01-04T21:58:04+01:00 TSClient quit.
2019-01-04T21:58:04+01:00 TS |DEVELOP |Addons | |Got addon download info for ClientQuery
2019-01-04T21:58:04+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/0bff44c6-008b-4346-a13c-472414a6705f/fef25d76-267b-407b-b7bb-b80f14ba3274/settings.db
2019-01-04T21:58:04+01:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2019-01-04T21:58:04+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2019-01-04T21:58:04+01:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/default
2019-01-04T21:58:04+01:00 TS |INFO | | |*** Time [INIT]: 577
2019-01-04T21:58:04+01:00 TS |INFO | | |*** Time [MAINWINDOW]: 576
2019-01-04T21:58:03+01:00 Could not request shutdown. Please make sure that the plugin is installed correctly; HTTP returned an error: Error; Code: 500; Message: Error
2019-01-04T21:58:01+01:00 TS |INFO |SyncImpl | |Creating default config in local storage
2019-01-04T21:58:01+01:00 TS |INFO |Addon | |Not available for this platform.
2019-01-04T21:58:01+01:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2019-01-04T21:58:01+01:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-01-04T21:58:01+01:00 TS |INFO |Addons | |Checking for addon updates...
2019-01-04T21:58:01+01:00 TS |DEVELOP |Addons | |Installation request for ClientQuery
2019-01-04T21:58:01+01:00 TS |DEVELOP |Addons | |Installation request for Gamepad and Joystick Hotkey Support
2019-01-04T21:58:01+01:00 TS |INFO | | |*** Time [ICONMANGER]: 103
2019-01-04T21:58:01+01:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019-01-04T21:58:01+01:00 TS |INFO | | |successfully downloaded revocation list for accounting
2019-01-04T21:58:01+01:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-01-04T21:58:01+01:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-01-04T21:58:01+01:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2019-01-04T21:58:01+01:00 TS |ERROR |PulseAudio | |pa_context_connect failed -
2019-01-04T21:58:01+01:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server -
2019-01-04T21:58:00+01:00 TS |INFO | | |SystemInformation: Linux 4.15.0-43-generic #46~16.04.1-Ubuntu SMP Fri Dec 7 13:31:08 UTC 2018 x86_64 Binary: 64bit
2019-01-04T21:58:00+01:00 TS |INFO | | |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
2019-01-04T21:57:58+01:00 Starting instance ts3server://?port=9987&nickname=SHISH-BOT&password=&channel=&channelpassword=
 - Operating System: Ubuntu 16.04.5 LTS
 - Kernel: Linux 4.15.0-43-generic x86_64
 - Load Average: 2.38 2.15 1.81
 - Uptime: 1 days, 10 hours, 20 minutes, 22 seconds
 - OS APT Last Update: 04.01.2019 12:09:58 CET +01:00:00
    CPU(s):                4
    Thread(s) per core:    1
    Core(s) per socket:    4
    Socket(s):             1
    Model name:            AMD Athlon(tm) II X4 635 Processor
    CPU MHz:               800.000
    Virtualization:        AMD-V
 - RAM: 952.80 MB/3.85 GB in use (24%)
 - SWAP: 46.50 MB/975.99 MB in use (4%)
 - DISK: 398.88 GB/915.82 GB in use (43%)
   + libglib: 2.48.2-0ubuntu4.1
 - Status: running (PIDs: 389 388, User: sinusbot)
 - Version: 0.14.3-0e747fd
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.01.02)
 - Installed scripts: Advanced_Display_Playback_Information.js; advertising.js; AFK_Mover_(AwayMuteDeafIdle).js; alonemode.js; Animated_Nickname.js; avatarbanner.js; bookmark.js; Change_Channelcodec_And_Quality_Automaticly.js; Default-Channel.js; followme.js; Jail.js; norecording.js; Now_Playing_[Cleans_Bad_Tags]_[Custom_Display_Formats]_[TTS_Announce].js; Reconnect.js; registerNotificator.js; rememberChannel.js; Volume_Keeper.js; welcome.js; youtube.js
 - Time (local): 04.01.2019 22:06:43 CET +01:00:00
 - Timezone: Europe/Rome
 - TeamSpeak 3 Version: 3.2.3
 - youtube-dl Version: 2019.01.02
 - DiagScript Version: 0.7.1
