My Bot Was Bugged
Beast Awaken
My Sinusbot i think he is bugged , He is playing the music but We can't hear the music because he is lagging like a reboot speak like the music was bugged or its like someone he have a bad connection and he is lagging .
i think a probleme from the bot
please help
Best regards and Thanks,
I'm experiencing the same thing. Yes, i'm using a cheap/bad VPS but I am trying different setups ranging 1 to 4 CPU cores and 1 to 4 GB RAM, and still sometimes it lags like those.
The server does not have bad ping, what could be? Packet loss? How can I measure/log this?
Everlike
You can check the paketloss by right click on your bot (in Teamspeak) and then click on client-information.
But I rather think that it’s caused by your vps.
You’re not the only one on a Node when you have an vps. And if you have a bad provider you probably have performance issues.
