Nach privat.dat install geht nix :c
gfgfd
Betriebssystem: Linux
SinusBot Version: 0.9.21
TS3 Version: 3.0.19.4
Ich habe heute meine Lizenz erhalten habe die privat.dat auch auf dem Server gezogen und neu gestartet. Wird auch alles erkannt etc. Was jetzt aber nicht geht ist das ich die 4 Neuen Instanzen der Lizenz nicht auf dem Server holen kann bekomme immer folgende fehler meldung.
2017/07/07 06:03:14 f47aca57 b5600db3 INFO  joined the channel
2017/07/07 06:03:14 f47aca57 b5600db3 INFO  TS |INFO  |ClientUI  |1  |Connect status: Disconnected
2017/07/07 06:03:14 f47aca57 b5600db3 INFO  TS |INFO  |ClientUI  |1  |Disconnected or forced to leave, want autoreconnect = 0
2017/07/07 06:03:14 f47aca57 b5600db3 INFO  New connection status 0; Error 0
2017/07/07 06:03:14 f47aca57 b5600db3 INFO  TS |INFO  |ClientUI  |  |Last update check was: Tue Jan 1 00:00:01 2019
2017/07/07 06:03:14 f47aca57 b5600db3 INFO  TS |INFO  |  |  |Statistics report: Not yet, next report on Sun Jul 9 05:07:21 2017
2017/07/07 06:03:14 f47aca57 b5600db3 INFO  TS |INFO  |  |  |Failed to download remote image: SSL handshake failed 6
2017/07/07 06:03:15 f47aca57 b5600db3 DEBUG  TS>libpng warning: iCCP: known incorrect sRGB profile
2017/07/07 06:03:15 f47aca57 b5600db3 DEBUG  TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2017/07/07 06:03:15 f47aca57 b5600db3 DEBUG  TS>QObject::connect: Cannot connect (null)::stateChanged(QNetworkSession::State) to QNetworkReplyHttpImpl::_q_networkSessionStateChanged(QNetworkSession::State)
2017/07/07 06:03:14 f47aca57 b5600db3 INFO TS |INFO | | |Failed to download remote image: SSL handshake failed 6 2017/07/07 06:03:15 f47aca57 b5600db3 DEBUG TS>libpng warning: iCCP: known incorrect sRGB profile 2017/07/07 06:03:15 f47aca57 b5600db3 DEBUG TS>warning: The VAD has been replaced by a hack pending a complete rewrite 2017/07/07 06:03:15 f47aca57 b5600db3 DEBUG TS>warning: The VAD has been replaced by a hack pending a complete rewrite 2017/07/07 06:03:15 f47aca57 b5600db3 DEBUG TS>QObject::connect: Cannot connect (null)::stateChanged(QNetworkSession::State) to QNetworkReplyHttpImpl::_q_networkSessionStateChanged(QNetworkSession::State)
einmal bitte:
apt-get install ca-certificates && update-ca-certificates
versuchen (als Root) !
Das ist immer das Zeichen vom TS Client, dass der Server ihn nicht mag - aus Gründen, die eigentlich auch angezeigt werden (gebannt, zu viele gleiche Identitäten, zu alter Client, usw.)
gfgfd
Ich habe den Bot heute morgen nochmal neu installiert. die beiden standart Instanzen gehen ja auch. Nur die 4 die durch lizenz freigeschaltet wurde gehen nicht. ich kann sie für 10 min auf dem Server holen dann timen sie aus nur die beiden standart bleiben. irgendwie komisch
gfgfd
Und nochwas was ich nicht verstehe. Die beiden standart instancen werden auch so wie ich es eingestellt habe channelcomannder die anderen nicht. Sie senden auch keine Chatnachricht. sie haben die gleichen rechte wie die standart.
Hast du vll. vor kurzem von root auf non-root geändert? Wenn ja, fixe mal die Permissions (siehe FAQ). Ansonsten schicke mal bitte noch mehr Logs.
gfgfd
ich starte niemals etwas mit root
Hier noch mal der log
2017-07-07T14:33:40+02:00 Ping failed.
2017-07-07T14:28:45+02:00 Storing configuration.
2017-07-07T14:28:31+02:00 TS |INFO | | |Failed to download remote image: SSL handshake failed 6
2017-07-07T14:28:31+02:00 TS |INFO | | |Statistics report: Not yet, next report on Fri Jul 21 14:26:56 2017
2017-07-07T14:28:31+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-07-07T14:28:31+02:00 TS |INFO |PermManager | |Requesting permissions from server
2017-07-07T14:28:31+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2017-07-07T14:28:31+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2017-07-07T14:28:31+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2017-07-07T14:28:31+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 2
2017-07-07T14:28:31+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-07-07T14:28:31+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-07-07T14:28:31+02:00 TS |INFO |ClientUI |1 |Initiating connection: 213.202.233.229:9987 213.202.233.229
2017-07-07T14:28:31+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-07-07T14:28:31+02:00 TS |INFO |ClientUI |1 |Connect to server: 213.202.233.229
2017-07-07T14:28:31+02:00 TS |INFO |ClientUI | |ts3server: 213.202.233.229?port=9987&nickname=ILoveRadio&password=&cid=67&channelpassword=
2017-07-07T14:28:30+02:00 TS |INFO |ClientUI | |Using configuration location: /home/spigot/sinusbot/data/ts3/f47aca57-336e-4ab7-b015-dc191526637d/b5600db3-7d23-5078-371b-962f7d840716/settings.db
2017-07-07T14:28:30+02:00 TS |INFO |ClientUI | |Qt version: 5.5.0
2017-07-07T14:28:30+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-07-07T14:28:30+02:00 TS>dataloop quit
2017-07-07T14:28:30+02:00 TS |ERROR |Query | |bind failed on 127.0.0.1:25639
2017-07-07T14:28:30+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-07-07T14:28:30+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-07-07T14:28:30+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-07-07T14:28:30+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-07-07T14:28:30+02:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-07-07T14:28:30+02:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2017-07-07T14:28:30+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2017-07-07T14:28:30+02:00 TS |INFO | | |Using hardware aes
2017-07-07T14:28:30+02:00 TS |INFO | | |SystemInformation: Linux 4.4.0-78-generic #99-Ubuntu SMP Thu Apr 27 15:29:09 UTC 2017 x86_64 Binary: 64bit
2017-07-07T14:28:30+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2017-07-07T14:28:30+02:00 TS>DUMP defined! Dumpdir is: /home/spigot/sinusbot/data/ts3/f47aca57-336e-4ab7-b015-dc191526637d/b5600db3-7d23-5078-371b-962f7d840716/crashdumps
2017-07-07T14:28:30+02:00 TS>Crashdump ENABLED, directory is: /home/spigot/sinusbot/data/ts3/f47aca57-336e-4ab7-b015-dc191526637d/b5600db3-7d23-5078-371b-962f7d840716/crashdumps
2017-07-07T14:28:30+02:00 Starting instance ts3server://213.202.233.229?port=9987&nickname=ILoveRadio&password=&cid=67&channelpassword=
2017-07-07T14:28:30+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2017-07-07T14:28:30+02:00 Could not delete from FileTransferno such table: FileTransfer
2017-07-07T14:28:30+02:00 Could not create Notifications-Tabletable Notifications already exists
2017-07-07T14:28:30+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017-07-07T14:28:30+02:00 Could not create Chat-Tabletable Chat already exists
2017-07-07T14:28:30+02:00 About to run.
2017-07-07T14:28:29+02:00 Prespawn.
2017-07-07T14:28:29+02:00 TSClient quit.
2017-07-07T14:28:29+02:00 Closed.
2017-07-07T14:28:29+02:00 TS>qt.network.ssl: QSslSocket: cannot resolve SSLv2_server_method
2017-07-07T14:28:29+02:00 TS>qt.network.ssl: QSslSocket: cannot resolve SSLv2_client_method
2017-07-07T14:28:29+02:00 TS>warning: The VAD has been replaced by a hack pending a complete rewrite
2017-07-07T14:28:29+02:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2017-07-07T14:28:28+02:00 TS |INFO | | |Failed to download remote image: SSL handshake failed 6
2017-07-07T14:28:28+02:00 TS |INFO | | |Statistics report: Not yet, next report on Fri Jul 21 14:26:56 2017
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-07-07T14:28:28+02:00 New connection status 0; Error 0
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-07-07T14:28:28+02:00 ILoveRadio joined the channel
2017-07-07T14:28:28+02:00 New connection status 4; Error 0
2017-07-07T14:28:28+02:00 TS |INFO |ChatTabWidget | |Prevented to set an empty chattab name in addNewTab
2017-07-07T14:28:28+02:00 TS |INFO |PermManager | |Requesting permissions from server
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2017-07-07T14:28:28+02:00 New connection status 3; Error 0
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2017-07-07T14:28:28+02:00 New connection status 2; Error 0
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2017-07-07T14:28:28+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 3
2017-07-07T14:28:28+02:00 New connection status 1; Error 0
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-07-07T14:28:28+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI |1 |Initiating connection: 213.202.233.229:9987 213.202.233.229
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI |1 |Connect to server: 213.202.233.229
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI | |ts3server: 213.202.233.229?port=9987&nickname=ILoveRadio&password=&cid=67&channelpassword=
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI | |Using configuration location: /home/spigot/sinusbot/data/ts3/f47aca57-336e-4ab7-b015-dc191526637d/b5600db3-7d23-5078-371b-962f7d840716/settings.db
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI | |Qt version: 5.5.0
2017-07-07T14:28:28+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-07-07T14:28:27+02:00 TS |ERROR |Query | |bind failed on 127.0.0.1:25639
2017-07-07T14:28:27+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-07-07T14:28:27+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-07-07T14:28:27+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-07-07T14:28:27+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-07-07T14:28:27+02:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-07-07T14:28:27+02:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2017-07-07T14:28:27+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2017-07-07T14:28:27+02:00 TS |INFO | | |Using hardware aes
2017-07-07T14:28:27+02:00 TS |INFO | | |SystemInformation: Linux 4.4.0-78-generic #99-Ubuntu SMP Thu Apr 27 15:29:09 UTC 2017 x86_64 Binary: 64bit
2017-07-07T14:28:27+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2017-07-07T14:28:27+02:00 TS>DUMP defined! Dumpdir is: /home/spigot/sinusbot/data/ts3/f47aca57-336e-4ab7-b015-dc191526637d/b5600db3-7d23-5078-371b-962f7d840716/crashdumps
2017-07-07T14:28:27+02:00 TS>Crashdump ENABLED, directory is: /home/spigot/sinusbot/data/ts3/f47aca57-336e-4ab7-b015-dc191526637d/b5600db3-7d23-5078-371b-962f7d840716/crashdumps
2017-07-07T14:28:27+02:00 Starting instance ts3server://213.202.233.229?port=9987&nickname=ILoveRadio&password=&cid=67&channelpassword=
2017-07-07T14:28:27+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2017-07-07T14:28:27+02:00 Could not delete from FileTransferno such table: FileTransfer
dirk
habe genau das gleiche Problem!
bots haben sich einmal verbunden nach 10 min waren sie wieder weg vom Server! gehen auch nicht mehr drauf!
kann das evt was mit der ip zu tun haben?
gfgfd
die IP ist ja richtig. Wenn ich die bots starte joinen sie und leaven gleich wieder. und wenn sie bleiben dann nur 10min
dirk
bei mir nur einmal danach nicht mehr
dirk
habe eben den sinusbot mit dem installerscript gelöscht! komisch war halt das die zwei bots auf dem Server geblieben sind!
dirk
- Status: running (PIDs: 3139 3137 3096 3090, User: sinusbot)
- Binary: /opt/sinusbot/sinusbot (MD5 Hash: f62c677c697c99ee7c4e624ae8822887)
- Version: 0.9.21-87a90ce
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.07.02)
- Report date: 08.07.2017 18:51:34 CEST +02:00:00 (timezone: Europe/Berlin)
- youtube-dl Version: 2017.07.02
- DiagScript version: 0.5.1
