granatelbart
Debian jessie VM
I downloaded the latest versions of TS3, TSServer and Sinusbot
After the GUI is started and I want to start the bot, I get this output in the Syslog
If I only try to start the TS3 client I get this output
root@vmd17060:/opt/sinusbot# tail -f /var//log/syslog
Mar 29 16:44:40 vmd17060 sinusbot[19837]: 2020/03/29 16:44:40 ffd2407b f590698c INFO script command loaded
Mar 29 16:44:40 vmd17060 sinusbot[19837]: 2020/03/29 16:44:40 ffd2407b f590698c INFO Initialization complete
Mar 29 16:44:40 vmd17060 sinusbot[19837]: 2020/03/29 16:44:40 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
Mar 29 16:44:40 vmd17060 sinusbot[19837]: 2020/03/29 16:44:40 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
Mar 29 16:44:40 vmd17060 sinusbot[19837]: 2020/03/29 16:44:40 [GENERAL/YTDL ] INFO youtube-dl checking...
Mar 29 16:44:40 vmd17060 sinusbot[19837]: 2020/03/29 16:44:40 ffd2407b f590698c PLUGIN [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
Mar 29 16:44:40 vmd17060 sinusbot[19837]: 2020/03/29 16:44:40 ffd2407b f590698c INFO script sinusbot-commands loaded
Mar 29 16:44:41 vmd17060 sinusbot[19837]: 2020/03/29 16:44:41 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
Mar 29 16:44:41 vmd17060 sinusbot[19837]: 2020/03/29 16:44:41 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
Mar 29 16:44:41 vmd17060 sinusbot[19837]: 2020/03/29 16:44:41 [GENERAL/RADIO ] INFO RadioStation data loaded
Mar 29 16:44:41 vmd17060 sinusbot[19837]: 2020/03/29 16:44:41 [GENERAL/RADIO ] INFO Imported radio stations
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c WARN Could not create Chat-Tabletable Chat already exists
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c WARN Could not create Notifications-Tabletable Notifications already exists
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c WARN Could not delete from Profilesno such table: Profiles
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c WARN Could not insert into Profiles-Tableno such table: Profiles
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=bots&channel=&channelpassword=
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 X [MAIN] New connection
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO TS |INFO | | |TeamSpeak Client 3.5.1 (2020-03-23 09:33:16)
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO TS |INFO | | |SystemInformation: Linux 3.16.0-10-amd64 #1 SMP Debian 3.16.70-1 (2019-07-22) x86_64 Binary: 64bit
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO TS |INFO | | |Using hardware aes
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO TS |ERROR |PulseAudio | |failed to connect to pulse audio server -
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO TS |ERROR |PulseAudio | |pa_context_connect failed -
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO TS |ERROR |SoundBckndIntf| |/opt/sinusbot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO TS |INFO |Addons | |Checking for addon updates...
Mar 29 16:44:49 vmd17060 sinusbot[19837]: 2020/03/29 16:44:49 ffd2407b f590698c INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
Mar 29 16:44:50 vmd17060 sinusbot[19837]: 2020/03/29 16:44:50 ffd2407b f590698c DEBUG closing channels
Mar 29 16:44:50 vmd17060 sinusbot[19837]: 2020/03/29 16:44:50 ffd2407b f590698c DEBUG eof from voice
Mar 29 16:44:50 vmd17060 sinusbot[19837]: 2020/03/29 16:44:50 ffd2407b f590698c DEBUG eof from data
Mar 29 16:45:09 vmd17060 sinusbot[19837]: 2020/03/29 16:45:09 ffd2407b f590698c DEBUG Storing configuration.
root@vmd17060:/opt/sinusbot/TeamSpeak3-Client-linux_amd64# ./ts3client_linux_amd64
./ts3client_linux_amd64: error while loading shared libraries: libquazip.so: cannot open shared object file: No such file or directory
