Need help - Bot wont connect to server
FaLLeNNN
Hello all and happy new year !
In the last week i was trying to install sinus bot for my Ts3 server but it seems like the bot is connecting to some servers and decline to connect to others including mine !
I tryed installing it manually but the same issue so realy i have no idea what to do and that`s why i am asking for community help
i will include de log aswell!
Jan 06 11:51:24 udp sinusbot[389]: 2021/01/06 11:51:24 X [MAIN] New connection
Jan 06 11:51:24 udp sinusbot[389]: 2021/01/06 11:51:24 c0b3b4bb 614fbbf3 INFO   TS |INFO    |              |   |TeamSpeak Client 3.5.3 (2020-05-06 09:07:50)
Jan 06 11:51:24 udp sinusbot[389]: 2021/01/06 11:51:24 c0b3b4bb 614fbbf3 INFO   TS |INFO    |              |   |SystemInformation: Linux 4.19.0-8-cloud-amd64 #1 SMP Debian 4.19.98-1+deb10u1 (2020-04-27) x86_64 Binary: 64bit
Jan 06 11:51:24 udp sinusbot[389]: 2021/01/06 11:51:24 c0b3b4bb 614fbbf3 INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
Jan 06 11:51:24 udp sinusbot[389]: 2021/01/06 11:51:24 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
Jan 06 11:51:24 udp sinusbot[389]: 2021/01/06 11:51:24 c0b3b4bb 614fbbf3 INFO   TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |              |   |*** Time [ICONMANGER]: 308
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |Addons        |   |Checking for addon updates...
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 436
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |              |   |*** Time [INIT]: 436
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |   |Qt version: 5.12.1
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data/ts3/c0b3b4bb-790d-474e-b8ae-f0fed0e77679/614fbbf3-0e70-469b-a65b-ab92e25fc325/settings.db
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |   |ts3server: 89.40.105.157?port=9987&nickname=Udp%20Guard&password=&channel=&channelpassword=
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |1  |Connect to server: 89.40.105.157
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 89.40.105.157:9987
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   New connection status 1; Error 0
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |   |Last update check was: Sat Jan 1 00:00:01 2022
Jan 06 11:51:25 udp sinusbot[389]: 2021/01/06 11:51:25 c0b3b4bb 614fbbf3 INFO   TS |INFO    |              |   |Statistics report: Not yet, next report on Mon Jan 25 11:41:54 2021
Jan 06 11:51:26 udp sinusbot[389]: 2021/01/06 11:51:26 c0b3b4bb 614fbbf3 DEBUG  Storing configuration.
Jan 06 11:51:30 udp sinusbot[389]: 2021/01/06 11:51:30 c0b3b4bb 614fbbf3 INFO   TS |INFO    |              |   |successfully downloaded revocation list for accounting
Jan 06 11:51:30 udp sinusbot[389]: 2021/01/06 11:51:30 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |1  |Connect status: Disconnected
Jan 06 11:51:30 udp sinusbot[389]: 2021/01/06 11:51:30 c0b3b4bb 614fbbf3 INFO   TS |INFO    |ClientUI      |1  |Failed to connect to server, want autoreconnect = 0
Jan 06 11:51:30 udp sinusbot[389]: 2021/01/06 11:51:30 c0b3b4bb 614fbbf3 INFO   The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation, the password is wrong, the security level of your identity is too low, the nickname is too short or too long or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
Jan 06 11:51:30 udp sinusbot[389]: 2021/01/06 11:51:30 c0b3b4bb 614fbbf3 INFO   New connection status 0; Error 1797
Jan 06 11:51:31 udp sinusbot[389]: 2021/01/06 11:51:31 c0b3b4bb 614fbbf3 DEBUG  TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
Jan 06 11:51:31 udp sinusbot[389]: 2021/01/06 11:51:31 c0b3b4bb 614fbbf3 DEBUG  TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
Jan 06 11:51:31 udp sinusbot[389]: 2021/01/06 11:51:31 c0b3b4bb 614fbbf3 DEBUG  TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
Jan 06 11:51:31 udp sinusbot[389]: 2021/01/06 11:51:31 c0b3b4bb 614fbbf3 DEBUG  TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
Jan 06 11:51:31 udp sinusbot[389]: 2021/01/06 11:51:31 c0b3b4bb 614fbbf3 DEBUG  TS>libpng warning: iCCP: known incorrect sRGB profile
Jan 06 11:51:31 udp sinusbot[389]: 2021/01/06 11:51:31 c0b3b4bb 614fbbf3 DEBUG  Closed.
Jan 06 11:51:31 udp sinusbot[389]: 2021/01/06 11:51:31 c0b3b4bb 614fbbf3 INFO   TSClient quit.
Jan 06 11:51:32 udp sinusbot[389]: 2021/01/06 11:51:32 c0b3b4bb 614fbbf3 DEBUG  eof from voice
Jan 06 11:51:32 udp sinusbot[389]: 2021/01/06 11:51:32 c0b3b4bb 614fbbf3 DEBUG  closing channels
Jan 06 11:51:32 udp sinusbot[389]: 2021/01/06 11:51:32 c0b3b4bb 614fbbf3 DEBUG  eof from data
MauriceR
Maybe the security level of the bot's identity isn't high enough. In order to increase the security level, you need to import the bot's identity into your TeamSpeak client and increase the level via the identity menu.
