Need Help | Brauche Hilfe
I got this message when i want to start the Sinusbot + I can't login in my Sinusbot Webinterface. Can someone help me?
sinusbot@vm276:/opt/ts3soundboard$ ./sinusbot
2017/12/26 16:19:42 X [MAIN] Starting up fake x-server...
Version: 0.10.8-71ba94b
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin AFK_Mover_(AwayMuteDeafIdle).js
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin Support.js
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin YT-search.js
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin ZTSupport_-_SupportChannel_With_ServerGroup_Support.js
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2017/12/26 16:19:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
2017/12/26 16:19:43 f1e672b5 INFO Loading instances
2017/12/26 16:19:43 f1e672b5 INFO Loading instance://2edffb0d-90ef-4a85-9ed7-2d6d417dcd9a
2017/12/26 16:19:43 f1e672b5 2edffb0d INFO Initialization complete
2017/12/26 16:19:43 f1e672b5 2edffb0d INFO Auto-Starting f1e672b5-278a-4a23-b13b-f8ad0fe4c2d5/2edffb0d-90ef-4a85-9ed7-2d6d417dcd9a in 500 ms...
2017/12/26 16:19:43 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2017/12/26 16:19:43 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2017/12/26 16:19:43 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://5.135.214.32:8087
error starting up: listen tcp 5.135.214.32:8087: bind: address already in usesinusbot@vm276:/opt/ts3soundboard$
OmG-Network
Dein Server ist voll mit Sicherheitslücken, aber um auf dein Problem einzugehen entweder suchst du nach dem Socket und killst diesen oder startest den Server neu.
