Solved No commands after uploading licenses and updates
madej164
Hello.
After updating and uploading the license, the commands have stopped working.
The bot can only be operated through the panel.
yt-dl works.
Wersions: ts3client 3.2.3 / server 3.5.1
Plugins: Not enabled
- Operating System: Debian GNU/Linux 9.6 (stretch) (OpenVZ)
- Kernel: Linux 2.6.32-042stab131.1 x86_64
- Load Average: 0.42 0.45 0.49
- Uptime: 0 days, 1 hours, 22 minutes, 31 seconds
- OS APT Last Update: 02.01.2019 16:05:07 CET +01:00:00
- CPU: 2x2.4 GHz
- RAM:  B/4.00 GB in use (%)
- SWAP:  B/ B in use (%)
- DISK: 7.70 GB/80.00 GB in use (9%)
   + libglib: 2.50.3-2
- Status: running (PIDs: 28400 28399, User: sinusbot)
- Binary: /home/sinusbot/sinusbot
- Version: 0.14.3-0e747fd
   - TS3Path = /home/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.2.3)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2018.12.31)
- Installed scripts: advertising.js; alonemode.js; bookmark.js; followme.js; norecording.js; rememberChannel.js; wel
- Time (local): 02.01.2019 19:09:14 CET +01:00:00
- Timezone: Europe/Warsaw
- TeamSpeak 3 Version: 3.2.3
- youtube-dl Version: 2018.12.31
- DiagScript Version: 0.7.1
Logs
2019/01/02 19:07:29 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2019/01/02 19:07:29 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin alonemode.js
2019/01/02 19:07:29 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2019/01/02 19:07:29 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2019/01/02 19:07:29 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2019/01/02 19:07:29 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2019/01/02 19:07:29 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcome.js
2019/01/02 19:07:30 a2ba3717          INFO   Loading instances
2019/01/02 19:07:31 a2ba3717          INFO   Loading instance://224e105c-81be-1e8a-69a2-f1f56404eb31
2019/01/02 19:07:31 a2ba3717 224e105c INFO   Initialization complete
2019/01/02 19:07:31 a2ba3717          INFO   Loading instance://c751ebf0-4dc1-0d08-b64d-45cba903e385
2019/01/02 19:07:31 a2ba3717 c751ebf0 INFO   Initialization complete
2019/01/02 19:07:31 a2ba3717          INFO   Loading instance://c8cfd176-bb26-9145-3652-3cf420d0284e
2019/01/02 19:07:31 a2ba3717 c8cfd176 INFO   Initialization complete
2019/01/02 19:07:31 a2ba3717          INFO   Loading instance://3cb1a41e-4f8a-478b-931d-18fd3ea6f5a8
2019/01/02 19:07:31 a2ba3717 3cb1a41e INFO   Initialization complete
2019/01/02 19:07:31 a2ba3717 3cb1a41e INFO   Auto-Starting a2ba3717-0c01-45f1-ba31-547f03d63e95/3cb1a41e-4f8a-478b-931d-18fd3ea6f5a8 in 2000 ms...
2019/01/02 19:07:31 a2ba3717          INFO   Loading instance://ccdaa37a-a8db-48ec-a0dc-c37afc8ebb49
2019/01/02 19:07:31 a2ba3717 ccdaa37a INFO   Initialization complete
2019/01/02 19:07:31 a2ba3717 ccdaa37a INFO   Auto-Starting a2ba3717-0c01-45f1-ba31-547f03d63e95/ccdaa37a-a8db-48ec-a0dc-c37afc8ebb49 in 2500 ms...
2019/01/02 19:07:31 a2ba3717          INFO   Loading instance://86e55d86-2b31-f962-f19e-4556033aed91
2019/01/02 19:07:31 a2ba3717 86e55d86 INFO   Initialization complete
2019/01/02 19:07:31 a2ba3717 86e55d86 INFO   Auto-Starting a2ba3717-0c01-45f1-ba31-547f03d63e95/86e55d86-2b31-f962-f19e-4556033aed91 in 3000 ms...
2019/01/02 19:07:31 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/01/02 19:07:31 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/01/02 19:07:31 [GENERAL/YTDL   ] INFO   youtube-dl checking...
2019/01/02 19:07:31 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, support enabled
2019/01/02 19:07:31 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2019/01/02 19:07:31 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2019/01/02 19:07:31 [GENERAL/RADIO  ] INFO   Imported radio stations
2019/01/02 19:07:33 a2ba3717 3cb1a41e DEBUG  Prespawn.
2019/01/02 19:07:33 a2ba3717 3cb1a41e DEBUG  About to run.
2019/01/02 19:07:33 a2ba3717 3cb1a41e WARN   Could not create Chat-Tabletable Chat already exists
2019/01/02 19:07:33 a2ba3717 3cb1a41e WARN   Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019/01/02 19:07:33 a2ba3717 3cb1a41e WARN   Could not create Notifications-Tabletable Notifications already exists
2019/01/02 19:07:33 a2ba3717 3cb1a41e DEBUG  Could not delete from FileTransferno such table: FileTransfer
2019/01/02 19:07:33 a2ba3717 3cb1a41e DEBUG  Could not insert into FileTransfer-Tableno such table: FileTransfer
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=Poczekalnia&password=&channel=&channelpassword=
2019/01/02 19:07:33 X [MAIN] New connection
2019/01/02 19:07:33 a2ba3717 3cb1a41e DEBUG  TS>Crashdump ENABLED,  directory is: /home/sinusbot/data/ts3/a2ba3717-0c01-45f1-ba31-547f03d63e95/3cb1a41e-4f8a-478b-931d-18fd3ea6f5a8/crashdumps
2019/01/02 19:07:33 a2ba3717 3cb1a41e DEBUG  TS>DUMP defined! Dumpdir is: /home/sinusbot/data/ts3/a2ba3717-0c01-45f1-ba31-547f03d63e95/3cb1a41e-4f8a-478b-931d-18fd3ea6f5a8/crashdumps
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |              |   |SystemInformation: Linux 2.6.32-042stab131.1 #1 SMP Wed Jun 20 16:32:07 MSK 2018 x86_64 Binary: 64bit
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |              |   |Using hardware aes
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |Addons        |   |Checking for addon updates...
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |Plugins       |   |Loading plugin: libclientquery_plugin_linux_amd64.so
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |              |   |successfully downloaded revocation list for myteamspeak id
2019/01/02 19:07:33 a2ba3717 3cb1a41e DEBUG  TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 187
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |              |   |*** Time [INIT]: 187
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /home/sinusbot/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |              |   |successfully downloaded revocation list for accounting
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |   |Qt version: 5.6.1
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |   |Using configuration location: /home/sinusbot/data/ts3/a2ba3717-0c01-45f1-ba31-547f03d63e95/3cb1a41e-4f8a-478b-931d-18fd3ea6f5a8/settings.db
2019/01/02 19:07:33 a2ba3717 ccdaa37a DEBUG  Prespawn.
2019/01/02 19:07:33 a2ba3717 ccdaa37a DEBUG  About to run.
2019/01/02 19:07:33 a2ba3717 ccdaa37a WARN   Could not create Chat-Tabletable Chat already exists
2019/01/02 19:07:33 a2ba3717 ccdaa37a WARN   Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019/01/02 19:07:33 a2ba3717 ccdaa37a WARN   Could not create Notifications-Tabletable Notifications already exists
2019/01/02 19:07:33 a2ba3717 ccdaa37a DEBUG  Could not delete from FileTransferno such table: FileTransfer
2019/01/02 19:07:33 a2ba3717 ccdaa37a DEBUG  Could not insert into FileTransfer-Tableno such table: FileTransfer
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=SuperHype%20%E2%96%AA%20LiveHelp&password=&cid=204&channelpassword=
2019/01/02 19:07:33 a2ba3717 ccdaa37a DEBUG  TS>Crashdump ENABLED,  directory is: /home/sinusbot/data/ts3/a2ba3717-0c01-45f1-ba31-547f03d63e95/ccdaa37a-a8db-48ec-a0dc-c37afc8ebb49/crashdumps
2019/01/02 19:07:33 a2ba3717 ccdaa37a DEBUG  TS>DUMP defined! Dumpdir is: /home/sinusbot/data/ts3/a2ba3717-0c01-45f1-ba31-547f03d63e95/ccdaa37a-a8db-48ec-a0dc-c37afc8ebb49/crashdumps
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |INFO    |              |   |SystemInformation: Linux 2.6.32-042stab131.1 #1 SMP Wed Jun 20 16:32:07 MSK 2018 x86_64 Binary: 64bit
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |INFO    |              |   |Using hardware aes
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=Poczekalnia&password=&channel=&channelpassword=
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |INFO    |Addons        |   |Checking for addon updates...
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |INFO    |Plugins       |   |Loading plugin: libclientquery_plugin_linux_amd64.so
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |ERROR   |Query         |   |bind failed on 127.0.0.1:25639
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |INFO    |              |   |successfully downloaded revocation list for accounting
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2019/01/02 19:07:33 a2ba3717 ccdaa37a INFO   TS |INFO    |              |   |successfully downloaded revocation list for myteamspeak id
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   New connection status 1; Error 0
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |DEVELOP |PktHandler    |   |Puzzle solve time: 5
2019/01/02 19:07:33 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |1  |Connect status: Connected
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 176
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |              |   |*** Time [INIT]: 176
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /home/sinusbot/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |   |Qt version: 5.6.1
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |   |Using configuration location: /home/sinusbot/data/ts3/a2ba3717-0c01-45f1-ba31-547f03d63e95/ccdaa37a-a8db-48ec-a0dc-c37afc8ebb49/settings.db
2019/01/02 19:07:34 a2ba3717 86e55d86 DEBUG  Prespawn.
2019/01/02 19:07:34 a2ba3717 86e55d86 DEBUG  About to run.
2019/01/02 19:07:34 a2ba3717 86e55d86 WARN   Could not create Chat-Tabletable Chat already exists
2019/01/02 19:07:34 a2ba3717 86e55d86 WARN   Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019/01/02 19:07:34 a2ba3717 86e55d86 WARN   Could not create Notifications-Tabletable Notifications already exists
2019/01/02 19:07:34 a2ba3717 86e55d86 DEBUG  Could not delete from FileTransferno such table: FileTransfer
2019/01/02 19:07:34 a2ba3717 86e55d86 DEBUG  Could not insert into FileTransfer-Tableno such table: FileTransfer
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   New connection status 2; Error 0
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   New connection status 3; Error 0
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=PaXa&password=&cid=203&channelpassword=
2019/01/02 19:07:34 X [MAIN] New connection
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |1  |Connect status: Connection established
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   TS |INFO    |PermManager   |   |Loading permissions from cache
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   New connection status 4; Error 0
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |   |Last update check was: Tue Jan 1 00:00:01 2019
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   TS |INFO    |ClientUI      |   |Checking for update
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   TS |INFO    |Update        |   |Checking for updates...
2019/01/02 19:07:34 a2ba3717 86e55d86 DEBUG  TS>Crashdump ENABLED,  directory is: /home/sinusbot/data/ts3/a2ba3717-0c01-45f1-ba31-547f03d63e95/86e55d86-2b31-f962-f19e-4556033aed91/crashdumps
2019/01/02 19:07:34 a2ba3717 86e55d86 DEBUG  TS>DUMP defined! Dumpdir is: /home/sinusbot/data/ts3/a2ba3717-0c01-45f1-ba31-547f03d63e95/86e55d86-2b31-f962-f19e-4556033aed91/crashdumps
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |              |   |SystemInformation: Linux 2.6.32-042stab131.1 #1 SMP Wed Jun 20 16:32:07 MSK 2018 x86_64 Binary: 64bit
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |              |   |Using hardware aes
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=SuperHype%20%E2%96%AA%20LiveHelp&password=&cid=204&channelpassword=
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2019/01/02 19:07:34 a2ba3717 3cb1a41e DEBUG  2568/insufficient client permissions/i_channel_needed_description_view_power
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |Addons        |   |Checking for addon updates...
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |              |   |successfully downloaded revocation list for accounting
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |              |   |successfully downloaded revocation list for myteamspeak id
2019/01/02 19:07:34 a2ba3717 3cb1a41e INFO   TS |INFO    |Update        |   |Check license: version=4, min_version=4, my_license_version=4, my_license_min_version=1
2019/01/02 19:07:34 An error has occurred: Please report this on the official forums. Guru Meditation #004-711-10
2019/01/02 19:07:34 An error has occurred: Please report this on the official forums. Guru Meditation #004-711-40
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   New connection status 1; Error 0
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |DEVELOP |PktHandler    |   |Puzzle solve time: 3
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |1  |Connect status: Connected
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 178
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |              |   |*** Time [INIT]: 178
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /home/sinusbot/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   New connection status 2; Error 0
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   New connection status 3; Error 0
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |   |Qt version: 5.6.1
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |   |Using configuration location: /home/sinusbot/data/ts3/a2ba3717-0c01-45f1-ba31-547f03d63e95/86e55d86-2b31-f962-f19e-4556033aed91/settings.db
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |1  |Connect status: Connection established
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |PermManager   |   |Loading permissions from cache
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   New connection status 4; Error 0
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |   |Last update check was: Tue Jan 1 00:00:01 2019
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |ClientUI      |   |Checking for update
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |Update        |   |Checking for updates...
2019/01/02 19:07:34 a2ba3717 ccdaa37a DEBUG  2568/insufficient client permissions/i_channel_needed_description_view_power
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=PaXa&password=&cid=203&channelpassword=
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2019/01/02 19:07:34 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987
2019/01/02 19:07:34 a2ba3717 ccdaa37a INFO   TS |INFO    |Update        |   |Check license: version=4, min_version=4, my_license_version=4, my_license_min_version=1
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |DEVELOP |PktHandler    |   |Puzzle solve time: 4
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   New connection status 1; Error 0
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connected
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   New connection status 2; Error 0
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   New connection status 3; Error 0
2019/01/02 19:07:35 a2ba3717 86e55d86 DEBUG  Madej164 joined the channel
2019/01/02 19:07:35 a2ba3717 86e55d86 DEBUG  PaXu joined the channel
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connection established
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |PermManager   |   |Loading permissions from cache
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   New connection status 4; Error 0
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |   |Last update check was: Tue Jan 1 00:00:01 2019
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |ClientUI      |   |Checking for update
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |Update        |   |Checking for updates...
2019/01/02 19:07:35 a2ba3717 86e55d86 DEBUG  2568/insufficient client permissions/i_channel_needed_description_view_power
2019/01/02 19:07:35 a2ba3717 86e55d86 INFO   TS |INFO    |Update        |   |Check license: version=4, min_version=4, my_license_version=4, my_license_min_version=1
2019/01/02 19:07:35 An error has occurred: Please report this on the official forums. Guru Meditation #004-711-10
2019/01/02 19:07:35 An error has occurred: Please report this on the official forums. Guru Meditation #004-711-40
2019/01/02 19:08:01 a2ba3717 3cb1a41e DEBUG  Storing configuration.
2019/01/02 19:08:01 a2ba3717 ccdaa37a DEBUG  Storing configuration.
2019/01/02 19:08:01 a2ba3717 86e55d86 DEBUG  Storing configuration.
Config
DataDir = "/home/sinusbot/data/"
UseSSL = true
SSLKeyFile = "/home/sinusbot/ssl/key.key"
SSLCertFile = "/home/sinusbot/ssl/crt.crt"
Hostname = "superhype.pl"
LogFile = "/home/sinusbot/log.txt"
LicenseKey = "kXBob+HtS6pDsEUJaoZ/m1vEftKfSA/tkSHD1oDJZjc="
  V1 = ""
  V2 = ""
DrWarpMan
Hello.
yt-dl works.
- CPU: 2x2.4 GHz
   + libglib: 2.50.3-2
Logs
Config
UseSSL = true
  V1 = ""
  V2 = ""
I have the same problem, the bot doesn't even recognize that I said something. Nothing in the log.
And I get this "Guru Meditation #004-711-40" error too.
No DMs please - Currently inactive
@madej164 What's the output of la -ls /opt/sinusbot/TeamSpeak3-Client-linux_amd64/xcbglintegrations/?
(change the path to fit your installation)
[email protected]:/home/sinusbot# ls /home/sinusbot/TeamSpeak3-Client-linux_amd64/xcbglintegrations/
libqxcb-egl-integration.so
Then execute the following commands:
Bash:
# go into the bot directory
cd /home/sinusbot
# and delete the old ts3 data and libqxcb-glx-integration.so
# as mentioned in https://wiki.sinusbot.com/en:guides:installation:linux#update
rm -rf data/ts3
rm TeamSpeak3-Client-linux_amd64/xcbglintegrations/libqxcb-glx-integration.so
restart the bot afterwards and check if the issue still occurs
madej164
Bash:
cd /home/sinusbot
rm -rf data/ts3
this file is not named libqxcb-glx-integration.so
I had libqxcb-egl-integration.so
When I finish the game, I will write or make it work
ah, you're right - then you shouldn't need to delete it actually...
madej164
Can someone test if completely reinstalling the bot fixes it? (aka: make a backup of /opt/sinusbot/data, delete everything, reinstall the bot and check if it works)
Alternatively: Can you also do step 2 of Troubleshooting: https://wiki.sinusbot.com/en:guides:installation:linux#troubleshooting
After entering the command I get this information
[email protected]:~$ xinit /home/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
/home/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: error while loading shared libraries: libquazip.so: cannot open shared object file: No such file or directory
but after starting sinusbot, bots normally enter the server only do not accept any commands and do not even appear in the logs.
The required file is in the specified folder
Yeah I know. That won't fix anything, it's just for troubleshooting to check for errors.
Would be nice if someone can try reinstalling everything.
madej164
Maybe I will do re-installations tomorrow because I already have a pure sinusbot with a license. In the meantime I am going to sleep because midnight is at my country.
DrWarpMan
Completely reinstalled sinusbot.. not working :(
// EDIT
- But this error was again there:
madej164
This is the log after a fresh installation of the bot.
The problem still occurs.
2019/01/03 19:46:01 X [MAIN] Starting up fake x-server...
2019/01/03 19:46:01 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2019/01/03 19:46:01 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin alonemode.js
2019/01/03 19:46:01 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2019/01/03 19:46:01 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2019/01/03 19:46:01 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2019/01/03 19:46:01 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2019/01/03 19:46:01 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcome.js
2019/01/03 19:46:01 ef851df0          INFO   Loading instances
2019/01/03 19:46:01 ef851df0          INFO   Loading instance://c6261b2d-ff4f-4a9b-ae57-209a2f348273
2019/01/03 19:46:01 ef851df0 c6261b2d INFO   Initialization complete
2019/01/03 19:46:01 ef851df0 c6261b2d INFO   Auto-Starting ef851df0-0f29-4689-a4ff-b2c043d23c3f/c6261b2d-ff4f-4a9b-ae57-209a2f348273 in 500 ms...
2019/01/03 19:46:01 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/01/03 19:46:01 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/01/03 19:46:01 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2019/01/03 19:46:01 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2019/01/03 19:46:01 [GENERAL/RADIO  ] INFO   Imported radio stations
2019/01/03 19:46:01 ef851df0 c6261b2d DEBUG  Prespawn.
2019/01/03 19:46:01 ef851df0 c6261b2d DEBUG  About to run.
2019/01/03 19:46:01 ef851df0 c6261b2d WARN   Could not create Chat-Tabletable Chat already exists
2019/01/03 19:46:01 ef851df0 c6261b2d WARN   Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019/01/03 19:46:01 ef851df0 c6261b2d WARN   Could not create Notifications-Tabletable Notifications already exists
2019/01/03 19:46:01 ef851df0 c6261b2d DEBUG  Could not delete from FileTransferno such table: FileTransfer
2019/01/03 19:46:01 ef851df0 c6261b2d DEBUG  Could not insert into FileTransfer-Tableno such table: FileTransfer
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=Poczekalnia&password=&channel=&channelpassword=
2019/01/03 19:46:02 X [MAIN] New connection
2019/01/03 19:46:02 ef851df0 c6261b2d DEBUG  TS>Crashdump ENABLED,  directory is: /home/sinusbot/data/ts3/ef851df0-0f29-4689-a4ff-b2c043d23c3f/c6261b2d-ff4f-4a9b-ae57-209a2f348273/crashdumps
2019/01/03 19:46:02 ef851df0 c6261b2d DEBUG  TS>DUMP defined! Dumpdir is: /home/sinusbot/data/ts3/ef851df0-0f29-4689-a4ff-b2c043d23c3f/c6261b2d-ff4f-4a9b-ae57-209a2f348273/crashdumps
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |              |   |SystemInformation: Linux 2.6.32-042stab131.1 #1 SMP Wed Jun 20 16:32:07 MSK 2018 x86_64 Binary: 64bit
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |              |   |Using hardware aes
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |Addons        |   |Checking for addon updates...
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |Plugins       |   |Loading plugin: libclientquery_plugin_linux_amd64.so
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |              |   |successfully downloaded revocation list for accounting
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |              |   |successfully downloaded revocation list for myteamspeak id
2019/01/03 19:46:02 ef851df0 c6261b2d DEBUG  TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 197
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |              |   |*** Time [INIT]: 197
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /home/sinusbot/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |   |Qt version: 5.6.1
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |   |Using configuration location: /home/sinusbot/data/ts3/ef851df0-0f29-4689-a4ff-b2c043d23c3f/c6261b2d-ff4f-4a9b-ae57-209a2f348273/settings.db
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=Poczekalnia&password=&channel=&channelpassword=
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2019/01/03 19:46:02 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |   |Last update check was: Tue Jan 1 00:00:01 2019
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |   |Checking for update
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   New connection status 1; Error 0
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |DEVELOP |PktHandler    |   |Puzzle solve time: 3
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |Update        |   |Checking for updates...
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |1  |Connect status: Connected
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   New connection status 2; Error 0
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   New connection status 3; Error 0
2019/01/03 19:46:04 ef851df0 c6261b2d DEBUG  Madej164 joined the channel
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |ClientUI      |1  |Connect status: Connection established
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |PermManager   |   |Loading permissions from cache
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   New connection status 4; Error 0
2019/01/03 19:46:04 ef851df0 c6261b2d INFO   TS |INFO    |Update        |   |Check license: version=4, min_version=4, my_license_version=4, my_license_min_version=1
2019/01/03 19:46:04 An error has occurred: Please report this on the official forums. Guru Meditation #004-711-10
2019/01/03 19:46:04 An error has occurred: Please report this on the official forums. Guru Meditation #004-711-40
2019/01/03 19:46:31 ef851df0 c6261b2d DEBUG  Storing configuration.
ITElite
I have exact the same problem but your problem does not come from the licence update it comes from sinsubot self so i mean you have restartet you bot right? yes i have it also do it and then. no cmd works i have the same guru error code its in the scripts problem why the bot does not react
PS: Nexus have the same problem
