Not starting Bot
Gameplant
Hey guys!
Need some help here with my bot.
I can run the exe perfectly, get into the web interface, but as soon as I hit the start button it turns to green, then turns back into orange again. Any guess what could be the problem?
Instance log:
2017-08-09T19:34:58+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-08-09T19:34:58+02:00 Closed.
2017-08-09T19:34:57+02:00 Starting instance ts3server://ts.vgh.hu?port=12416&nickname=GameplantFM&password=&channel=&channelpassword=
2017-08-09T19:34:57+02:00 About to run.
2017-08-09T19:34:57+02:00 Prespawn.
2017-08-09T19:34:44+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2017-08-09T19:34:43+02:00 Starting instance ts3server://ts.vgh.hu?port=12416&nickname=GameplantFM&password=&channel=&channelpassword=
2017-08-09T19:34:43+02:00 Initialization complete
2017-08-09T19:34:43+02:00 You will see a client window pop up shortly and then disappear again. That is perfectly normal. To launch the bot, please use the webinterface.
P.S.: I have Win 10 (64-bit) and my bot is on LogLevel 10.
Mh, no clue what happens here. Tried to connect with your infos and it worked (even got my bot join the server), also 3.0.19.4 clients are allowed, because I saw 2 client with that version online.
Maybe some firewall issue if you are hosting the bots from home. But I guess the staff need to have a look on this.
