flynns82
hello to all,
I have a problem with the musicbot, I updated the sinusbot to the latest version, and I also tried to install it from the beginning but the problem remains, simply do not work playlists, I load a playlist of songs but when I try to start them, some work, some not, and I get the error:
the strange thing is that then, casually, a song that initially had this error, starts to work, and instead it stops working, a song that had no problems before.
Then I noticed that when I reinstall the bot from the beginning, the config file is practically empty, instead of filling as it did before, only these writings appear:
nothing else, obviously even after logging the client on ts, dont appear all other entries.
what is the problem? what can i try to do for solve?
Thanks so much
Error Could not playback the selected file / stream.
TS3Path = "/opt/botWonder/teamspeak3-client/ts3client_linux_amd64"
Thanks so much
