Solved Playlist not displaying correctly
keepsix
When i launch everything seems fine, the bot logs on server ok. then I go to my music playlist that still says it has 416 songs in the playlist, but it shows this
{{name || 'All Music'|t}}
and now there is no music listed in my playlist. When i go to all music, i can see my songs YAY. So i hit play but my bot does not stream it, its like the music is playing but not Airing through the open mic of Sinusbot.
I also get " insufficient client permissions (failed on b_serverinstance_modify_templates) " as soon as my bot logs onto TS3.
Please help. It was working fine last night.
keepsix
i just downloaded it yesterday so its the new version.
Windows 10 64bit
hardware specs sigh its not the hardware.
Browser = chrome
im not sure what you want. I dont know the issue I just got this yesterday and it worked fine all day for us. log on today and all my playlist is gone and bot will not play any music.
It's just really tedious to always have to ask for more information...
Yeah, but there are a dozen of links out there, so that's, well... I guess you're using 0.9.8, then.
That bug with the {{name || 'All Music'|t}} might already have been fixed (although not in a Windows release), I'm not quite sure. Your browser console can probably tell us more about the bug.
About the other issue: we need the logs, just as it says in that "Read me first" post, so...
Windows 10 64bit
Browser = chrome
We need that you configure your bot to LogLevel = 10 in your config.ini
Then screen or poste your Console Output.
keepsix
ok i restarted pc and it seems to be playing my "all music" and radio now; however the playlist is still blank, i have to play through the All music tab.
My bot still has " insufficient client permissions (failed on b_serverinstance_modify_templates) "
P.S i would like to thank you guys for being amazingly fast at responding
Version: 0.9.8
2015/09/25 12:12:56 00543e64 INFO Initializing bot://00543e64-b712-411b-bc23-723838122a88
2015/09/25 12:12:56 00543e64 4e6f21c9 INFO Loaded
2015/09/25 12:12:56 Auto-Starting 00543e64-b712-411b-bc23-723838122a88/4e6f21c9-02d3-444c-a2e6-8530107f6fea in 2500 ms...
2015/09/25 12:12:56 FFmpeg/avcodec v3673444; license: LGPL version 2.1 or later; 493 codecs
2015/09/25 12:12:56 FFmpeg/avformat v3673958; license: LGPL version 2.1 or later; 138 formats
2015/09/25 12:12:56 RadioStation data loaded
2015/09/25 12:12:56 Imported radio stations
2015/09/25 12:12:59 00543e64 4e6f21c9 INFO Starting instance ts3server://209.15.226.35?port=11217&nickname=TS3-MusicBot&password=&channel=The%20Lounge&channelpassword=
2015/09/25 12:13:01 00543e64 4e6f21c9 INFO New connection status 1; Error 0
2015/09/25 12:13:01 00543e64 4e6f21c9 DEBUG Client-Count is now 2
2015/09/25 12:13:01 00543e64 4e6f21c9 INFO New connection status 2; Error 0
2015/09/25 12:13:01 00543e64 4e6f21c9 INFO New connection status 3; Error 0
2015/09/25 12:13:01 00543e64 4e6f21c9 INFO Could not move back (sticky): Channel-Id not numeric
2015/09/25 12:13:01 00543e64 4e6f21c9 INFO New connection status 4; Error 0
2015/09/25 12:13:26 00543e64 4e6f21c9 DEBUG Storing configuration.
2015/09/25 12:13:42 00543e64 4e6f21c9 INFO BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE ANNOUNCESTR DUCKING DUCKINGVOLUME STICKY TTSLOCALE CHATIGNSRV CHATIGNPRIV CHATIGNCHAN CC OK
2015/09/25 12:14:33 00543e64 4e6f21c9 INFO PLAY [admin] 05936da9-311b-495b-b157-e6a92fbf9ab8 OK
2015/09/25 12:14:33 00543e64 4e6f21c9 DEBUG New channel
2015/09/25 12:14:56 00543e64 4e6f21c9 DEBUG Storing configuration.
2015/09/25 12:15:26 00543e64 4e6f21c9 INFO STOP [admin] OK
2015/09/25 12:15:26 00543e64 4e6f21c9 DEBUG Deleting channel
2015/09/25 12:15:26 00543e64 4e6f21c9 DEBUG Channels now zero
2015/09/25 12:15:26 00543e64 4e6f21c9 DEBUG Done playing
2015/09/25 12:15:26 00543e64 4e6f21c9 DEBUG Storing configuration.
2015/09/25 12:17:13 00543e64 4e6f21c9 INFO BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE ANNOUNCESTR DUCKING DUCKINGVOLUME STICKY TTSLOCALE CHATIGNSRV CHATIGNPRIV CHATIGNCHAN CC OK
This should be only a warning.
The problem with your playlist:
Version: 0.9.8
keepsix
excuse my ignorance, but i'm not sure exactly what that is. Do you mean the Instance log from the web browser console?
This?
2015-09-25T12:12:56-04:00 Loaded
2015-09-25T12:12:59-04:00 Starting instance ts3server://209.15.226.35?port=11217&nickname=TS3-MusicBot&password=&channel=The%20Lounge&channelpassword=
2015-09-25T12:13:01-04:00 New connection status 1; Error 0
2015-09-25T12:13:01-04:00 Client-Count is now 2
2015-09-25T12:13:01-04:00 New connection status 2; Error 0
2015-09-25T12:13:01-04:00 New connection status 3; Error 0
2015-09-25T12:13:01-04:00 Could not move back (sticky): Channel-Id not numeric
2015-09-25T12:13:01-04:00 New connection status 4; Error 0
2015-09-25T12:13:26-04:00 Storing configuration.
2015-09-25T12:13:42-04:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE ANNOUNCESTR DUCKING DUCKINGVOLUME STICKY TTSLOCALE CHATIGNSRV CHATIGNPRIV CHATIGNCHAN CC OK
2015-09-25T12:14:33-04:00 PLAY [admin] 05936da9-311b-495b-b157-e6a92fbf9ab8 OK
2015-09-25T12:14:33-04:00 New channel
2015-09-25T12:14:56-04:00 Storing configuration.
2015-09-25T12:15:26-04:00 STOP [admin] OK
2015-09-25T12:15:26-04:00 Deleting channel
2015-09-25T12:15:26-04:00 Channels now zero
2015-09-25T12:15:26-04:00 Done playing
2015-09-25T12:15:26-04:00 Storing configuration.
2015-09-25T12:17:13-04:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE ANNOUNCESTR DUCKING DUCKINGVOLUME STICKY TTSLOCALE CHATIGNSRV CHATIGNPRIV CHATIGNCHAN CC OK
2015-09-25T12:22:50-04:00 PLAY [admin] e7582cdc-65fe-4b34-91ef-e55e6a4a1c29 OK
2015-09-25T12:22:50-04:00 New channel
2015-09-25T12:22:56-04:00 Storing configuration.
2015-09-25T12:23:58-04:00 PLAY-NEXT [admin] OK
2015-09-25T12:23:59-04:00 Deleting channel
2015-09-25T12:23:59-04:00 Channels now zero
2015-09-25T12:23:59-04:00 Done playing
2015-09-25T12:24:10-04:00 PLAY [admin] e7582cdc-65fe-4b34-91ef-e55e6a4a1c29 OK
2015-09-25T12:24:10-04:00 New channel
2015-09-25T12:24:11-04:00 PLAY-NEXT [admin] OK
2015-09-25T12:24:12-04:00 Deleting channel
2015-09-25T12:24:12-04:00 Channels now zero
2015-09-25T12:24:12-04:00 Done playing
2015-09-25T12:24:26-04:00 Storing configuration.
2015-09-25T12:24:28-04:00 Reseeding PRNG
2015-09-25T12:24:28-04:00 CHAT 3 [keepsix @ Keepsix] < !playlist Music > / OK
2015-09-25T12:24:29-04:00 New channel
2015-09-25T12:24:33-04:00 PLAY-NEXT [admin] OK
2015-09-25T12:24:34-04:00 Deleting channel
2015-09-25T12:24:34-04:00 Channels now zero
2015-09-25T12:24:34-04:00 Done playing
2015-09-25T12:24:34-04:00 Playing next from playlist: 1e448453-9984-4ab3-8985-e60cfcc0cab5
2015-09-25T12:24:34-04:00 New channel
This?
Go to your Webinterface - Press F12 and chooes the Tab named "console".
Then go to your playlist and browse there and make a screenshot of the Output in the Console.
keepsix
IT seems to be able to play the playlist by !playlist Music (my playlist name is music) but in thwe web browser i still cant see the songs in the playlist, unless i go to all music which is odd.... i also dont know how to enititate playing the Playlist via the web browser without seeing the songs... i have to enitiate it via cmd in TS3 !playlist Music
keepsix
Im still new to this, but I originally dragged all my music to the playlist "Music" to get it on Sinusbot. So i was afraid of deleting that playlist thinking all music would go with it.
I just made a new playlist titled "all" and successfully dragged all music to that playlist. and it is all visible.. So i guess i could just ignore or delete the playlist "Music" IDK how it got bugged
Can you help me with another question somewhat unrelated?
I really like my local radio, and want to air it for my friends on TS3.
How can I add http://player.chez106.com/ to my Radio stream? it will not recognise it.
