Problem Anti-Proxy
RazvanGFX
I have this problem, and don't kick persons with VPN
2019-09-16T16:13:57+01:00 [ AntiProxy:382:24] [ERROR] API requests limit exceeded, please check www.xdefcon.com/anti-proxy-api-key or contact [email protected] or to remove this limitation.
2019-09-16T16:13:56+01:00 [ AntiProxy:382:24] [ERROR] API requests limit exceeded, please check www.xdefcon.com/anti-proxy-api-key or contact [email protected] or to remove this limitation.
2019-09-16T16:13:55+01:00 [ AntiProxy:382:24] [ERROR] API requests limit exceeded, please check www.xdefcon.com/anti-proxy-api-key or contact [email protected] or to remove this limitation.
2019-09-16T16:13:54+01:00 [ AntiProxy:382:24] [ERROR] API requests limit exceeded, please check www.xdefcon.com/anti-proxy-api-key or contact [email protected] or to remove this limitation.
2019-09-16T16:13:53+01:00 [ AntiProxy:382:24] [ERROR] API requests limit exceeded, please check www.xdefcon.com/anti-proxy-api-key or contact [email protected] or to remove this limitation.
2019-09-16T16:13:52+01:00 [ AntiProxy:382:24] [ERROR] API requests limit exceeded, please check www.xdefcon.com/anti-proxy-api-key or contact [email protected] or to remove this limitation.
2019-09-16T16:13:51+01:00 New connection status 4; Error 0
2019-09-16T16:13:51+01:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2019-09-16T16:13:51+01:00 New connection status 3; Error 0
2019-09-16T16:13:51+01:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2019-09-16T16:13:51+01:00 New connection status 2; Error 0
2019-09-16T16:13:51+01:00 TS |INFO |ClientUI |1 |Connect status: Connected
2019-09-16T16:13:51+01:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 4
2019-09-16T16:13:51+01:00 New connection status 1; Error 0
2019-09-16T16:13:51+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2019-09-16T16:13:51+01:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019-09-16T16:13:51+01:00 TS |INFO |ClientUI |1 |Initiating connection: 89.40.105.37:9987
2019-09-16T16:13:51+01:00 TS |INFO |ClientUI |1 |Resolve successful: 89.40.105.37:9987
2019-09-16T16:13:51+01:00 TS |INFO |ClientUI |1 |Lookup finished: ip=89.40.105.37 port=9987 query=ts.cspower.ro error=0
2019-09-16T16:13:51+01:00 TS |INFO |TSDNS | |No TSDNS found
2019-09-16T16:13:51+01:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully 89.44.139.84:41144
2019-09-16T16:13:51+01:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully 89.40.105.37:41144
2019-09-16T16:13:49+01:00 TS |INFO | | |Statistics report: Not yet, next report on Sun Oct 13 14:39:45 2019
2019-09-16T16:13:49+01:00 TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019-09-16T16:13:49+01:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019-09-16T16:13:49+01:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_ts3._udp.ts.cspower.ro" Domain name not found
2019-09-16T16:13:49+01:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.cspower.ro" Domain name not found
2019-09-16T16:13:49+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "cspower.ro" =(h: 89.44.139.84 p:0)
2019-09-16T16:13:49+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "ts.cspower.ro" =(h: 89.40.105.37 p:0)
2019-09-16T16:13:49+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "ts.cspower.ro" =(h: 89.40.105.37 p:0)
2019-09-16T16:13:49+01:00 TS |INFO |ClientUI |1 |Trying to resolve ts.cspower.ro
2019-09-16T16:13:49+01:00 TS |INFO |ClientUI |1 |Connect to server: ts.cspower.ro
2019-09-16T16:13:49+01:00 TS |INFO |ClientUI | |ts3server: ts.cspower.ro?port=9987&nickname=Guard%20CSPOWER&password=&cid=1&channelpassword=
2019-09-16T16:13:48+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/6fb352b0-9862-4da7-8266-05c2f432a77d/18167502-5371-4c93-bc8a-01cbd3ee209c/settings.db
2019-09-16T16:13:48+01:00 TS |INFO |ClientUI | |Qt version: 5.12.1
2019-09-16T16:13:48+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2019-09-16T16:13:48+01:00 TS |INFO | | |*** Time [INIT]: 169
2019-09-16T16:13:48+01:00 TS |INFO | | |*** Time [MAINWINDOW]: 169
2019-09-16T16:13:48+01:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019-09-16T16:13:48+01:00 TS |INFO | | |successfully downloaded revocation list for accounting
2019-09-16T16:13:48+01:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-09-16T16:13:48+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2019-09-16T16:13:48+01:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2019-09-16T16:13:48+01:00 TS |INFO |Addons | |Checking for addon updates...
2019-09-16T16:13:48+01:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-09-16T16:13:48+01:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-09-16T16:13:48+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-09-16T16:13:48+01:00 TS |INFO | | |Using hardware aes
2019-09-16T16:13:48+01:00 TS |INFO | | |SystemInformation: Linux 4.15.0-62-generic #69-Ubuntu SMP Wed Sep 4 20:55:53 UTC 2019 x86_64 Binary: 64bit
2019-09-16T16:13:48+01:00 TS |INFO | | |TeamSpeak Client 3.3.2 (2019-08-25 21:13:34)
2019-09-16T16:13:48+01:00 Starting instance ts3server://ts.cspower.ro?port=9987&nickname=Guard%20CSPOWER&password=&cid=1&channelpassword=
2019-09-16T16:13:48+01:00 Could not create Notifications-Tabletable Notifications already exists
2019-09-16T16:13:48+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-09-16T16:13:48+01:00 Could not create Chat-Tabletable Chat already exists
2019-09-16T16:13:42+01:00 TSClient quit.
2019-09-16T16:13:42+01:00 KILL [admin] OK
2019-09-16T16:13:27+01:00 New connection status 4; Error 0
2019-09-16T16:13:27+01:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2019-09-16T16:13:27+01:00 New connection status 3; Error 0
2019-09-16T16:13:27+01:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2019-09-16T16:13:27+01:00 New connection status 2; Error 0
2019-09-16T16:13:27+01:00 TS |INFO |ClientUI |1 |Connect status: Connected
2019-09-16T16:13:27+01:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 10
2019-09-16T16:13:27+01:00 New connection status 1; Error 0
2019-09-16T16:13:27+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2019-09-16T16:13:27+01:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019-09-16T16:13:27+01:00 TS |INFO |ClientUI |1 |Initiating connection: 89.40.105.37:9987
2019-09-16T16:13:27+01:00 TS |INFO |ClientUI |1 |Resolve successful: 89.40.105.37:9987
2019-09-16T16:13:27+01:00 TS |INFO |ClientUI |1 |Lookup finished: ip=89.40.105.37 port=9987 query=ts.cspower.ro error=0
I readed but i didn't understand, can you explain me to understand?
The API is limited to a maximum of 150 requests every hour per IP. This will usually mean that if you have a server with less than 150 users, you will get this fantastic service for free. If you exceed this limit, the script will continue to work with the local cached addresses until the next rate-limit reset (after 1 hour)!
If you have a bigger server, or you are exceeding this limit, you can consider contacting me via e-mail at [email protected] or via Private Message here on this forum @xDefcon and considering a really small donation to have an API key to access to whatever requests you need, as said before, the API is built to support a lot, lot of requests per second.
This part should bring you clarity. ;)
RazvanGFX
It's now 50 people on server, 10 minutes ago he works
DrWarpMan
The first statement is not really true, but the second part is true and you should follow it.
Request is sent more times, than the amount of clients you have on the server at one time.. people disconnect and connect and stuff..
And request is also sent whenever the IP address of a user changes, that I think includes when connecting to the server.. it does not matter, you can do nothing about it, only donating.
xDefcon
The clients online do not 100% of the times indicate the limit. It could be possible that in the last hour a lot of new clients connected while some disconnected, this triggered the limit of the API. Every hour you have 150 requests that you can make, if you exceed the limit the script will continue working with the local cache, this means that you won't get the detection for new proxies for the next hour.
Please note that if you used "!antiproxy checkall" command, it will exhaust pretty quickly the requests you have.
To remove that limitation and for further information: www.xdefcon.com/anti-proxy-api-key
