problem restarting sinusbot
frospr
# service sinusbot start
Job for sinusbot.service failed because the control process exited with error code.
See "systemctl status sinusbot.service" and "journalctl -xe" for details
Active: failed (Result: exit-code) since Sat 2021-04-17 09:50:43 UTC; 35s ago
Process: 23678 ExecStartPre=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=200/CHDIR)
Process: 23679 ExecStopPost=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=200/CHDIR)
Apr 17 09:50:43 instance-1 systemd[1]: Starting Sinusbot, the Teamspeak 3 and Discord music bot....
Apr 17 09:50:43 instance-1 systemd[23678]: sinusbot.service: Changing to the requested working directory failed: Permission denied
Apr 17 09:50:43 instance-1 systemd[23678]: sinusbot.service: Failed at step CHDIR spawning /bin/rm: Permission denied
Apr 17 09:50:43 instance-1 systemd[1]: sinusbot.service: Control process exited, code=exited, status=200/CHDIR
Apr 17 09:50:43 instance-1 systemd[23679]: sinusbot.service: Changing to the requested working directory failed: Permission denied
Apr 17 09:50:43 instance-1 systemd[23679]: sinusbot.service: Failed at step CHDIR spawning /bin/rm: Permission denied
Apr 17 09:50:43 instance-1 systemd[1]: sinusbot.service: Failed with result 'exit-code'.
Apr 17 09:50:43 instance-1 systemd[1]: Failed to start Sinusbot, the Teamspeak 3 and Discord music bot..
