Problem with Instance Settings and Scripts category
Alfost
Operating System: Linux
SinusBot Version: 0.9.21-87a90ce
TeamSpeak Version: No idea but TeamSpeak is not the problem Discord is not functionaly too
Hello, I have a problem with 2 category of the control panel, I have tested on 2 servers I have the same problem, watch video.
INSTANCE LOG LEVEL 10 FOR DISCORD :
2017-07-06T14:13:06+02:00 identifying to discord
2017-07-06T14:13:06+02:00 hello: {"op":10,"d":{"heartbeat_interval":41250,"_trace":["discord-gateway-prd-1-29"]},"s":0,"t":""}
2017-07-06T14:13:05+02:00 Discord bot account valid (id: 332271989601468426, name: Alfost BOT)
2017-07-06T14:13:04+02:00 Auto-Starting d154ea76-6c24-4c36-8677-38d0761ec196/37218a73-87d4-43a8-96dd-b60b157231d9 in 1000 ms...
2017-07-06T14:13:04+02:00 Initialization complete
INSTANCE LOG LEVEL 10 FOR TEAMSPEAK 3 :
2017-07-06T14:15:13+02:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2017-07-06T14:15:12+02:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2017-07-06T14:15:11+02:00 2568/insufficient client permissions/b_virtualserver_servergroup_client_list
2017-07-06T14:15:11+02:00 TS |INFO | | |Statistics report: Not yet, next report on Tue Jul 11 13:27:00 2017
2017-07-06T14:15:11+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-07-06T14:15:11+02:00 New connection status 4; Error 0
2017-07-06T14:15:11+02:00 TS |INFO |PermManager | |Loading permissions from cache
2017-07-06T14:15:11+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2017-07-06T14:15:11+02:00 TeamSpeakUser joined the channel
2017-07-06T14:15:11+02:00 New connection status 3; Error 0
2017-07-06T14:15:11+02:00 New connection status 2; Error 0
2017-07-06T14:15:11+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2017-07-06T14:15:11+02:00 TS |INFO |EncodeCelt |1 |CELT bitstream version: 0x80000010
2017-07-06T14:15:11+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2017-07-06T14:15:11+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 2
2017-07-06T14:15:11+02:00 New connection status 1; Error 0
2017-07-06T14:15:11+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-07-06T14:15:11+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-07-06T14:15:11+02:00 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987 127.0.0.1
2017-07-06T14:15:11+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-07-06T14:15:11+02:00 TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2017-07-06T14:15:11+02:00 TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-07-06T14:15:10+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/d154ea76-6c24-4c36-8677-38d0761ec196/c60073f4-3aec-4855-bc5f-6dfc011f2ee4/settings.db
2017-07-06T14:15:10+02:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-07-06T14:15:10+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-07-06T14:15:10+02:00 TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2017-07-06T14:15:10+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-07-06T14:15:10+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-07-06T14:15:10+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-07-06T14:15:10+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-07-06T14:15:10+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-07-06T14:15:10+02:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2017-07-06T14:15:10+02:00 TS |ERROR |PulseAudio | |pa_context_connect failed
2017-07-06T14:15:10+02:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2017-07-06T14:15:10+02:00 TS |INFO | | |Using hardware aes
2017-07-06T14:15:10+02:00 TS |INFO | | |SystemInformation: Linux 2.6.32-44-pve #1 SMP Sun Mar 13 17:00:54 CET 2016 x86_64 Binary: 64bit
2017-07-06T14:15:10+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-07-06T14:15:10+02:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/d154ea76-6c24-4c36-8677-38d0761ec196/c60073f4-3aec-4855-bc5f-6dfc011f2ee4/crashdumps
2017-07-06T14:15:10+02:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/d154ea76-6c24-4c36-8677-38d0761ec196/c60073f4-3aec-4855-bc5f-6dfc011f2ee4/crashdumps
2017-07-06T14:15:10+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-07-06T14:15:10+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2017-07-06T14:15:10+02:00 Could not delete from FileTransferno such table: FileTransfer
2017-07-06T14:15:10+02:00 Could not create Notifications-Tabletable Notifications already exists
2017-07-06T14:15:10+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2017-07-06T14:15:10+02:00 Could not create Chat-Tabletable Chat already exists
2017-07-06T14:15:10+02:00 About to run.
2017-07-06T14:15:10+02:00 Prespawn.
2017-07-06T14:14:53+02:00 Initialization complete
Please rerecord this video with opened developer tools in the console tab (you can open them by pressing F12 or Ctrl+Shift+I). Thanks! ;)
That's definitely a issue of your browser or http proxy? Are you using cloudflare or something like that? No one had this issue before.
Have you tried to test it with another browser? Firefox, Edge e.g.
Nope, Edge is really stable. I don't know on which Windows 10 build your System is running but I like him as chrome alternative. :)
Alfost
Find the solution !!!
1. type dpkg-reconfigure locales
-> select en_GB.UTF-8 with Space!
-> then press Enter
-> select en_GB.UTF-8 with Enter!
2. Type service sinusbot stop and service sinusbot start
if you don't use the automatic installer just restart sinusbot
