Problem with SinusBot
Hello, i have problem, when i start bot:
xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
I have:
SS: http://screenshot.sh/mMiYuy0twveW7
Or
xinit: connection to X server lost/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: error while loading shared libraries: libquazip.so: cannot open shared object file: No such file or directoryxinit: XFree86_VT property unexpectedly has 0 items instead of 1[dix] Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, removing from list![dix] Could not init font path element /usr/share/fonts/X11/75dpi, removing from list![dix] Could not init font path element /usr/share/fonts/X11/100dpi, removing from list![dix] Could not init font path element /usr/share/fonts/X11/Type1, removing from list![dix] Could not init font path element /usr/share/fonts/X11/75dpi/:unscaled, removing from list![dix] Could not init font path element /usr/share/fonts/X11/100dpi/:unscaled, removing from list![dix] Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!root@vz38880:/opt/ts3soundboard# xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -acroot@vz38880:/opt/ts3soundboard# xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac^C-bash: x: command not foundroot@vz38880:/opt/ts3soundboard# xwaiting for X server to shut downxinit: connection to X server lost/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: error while loading shared libraries: libquazip.so: cannot open shared object file: No such file or directoryxinit: XFree86_VT property unexpectedly has 0 items instead of 1[dix] Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, removing from list![dix] Could not init font path element /usr/share/fonts/X11/75dpi, removing from list![dix] Could not init font path element /usr/share/fonts/X11/100dpi, removing from list![dix] Could not init font path element /usr/share/fonts/X11/Type1, removing from list![dix] Could not init font path element /usr/share/fonts/X11/75dpi/:unscaled, removing from list![dix] Could not init font path element /usr/share/fonts/X11/100dpi/:unscaled, removing from list![dix] Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
========================================================== - Installed Scripts: README.md TeamSpeak3-Client-linux_amd64 TeamSpeak3-Client-linux_amd64-3.0.18.2.run config.ini config.ini.dist data diagSinusbot.sh libavcodec.so.56 libavformat.so.56 libavutil.so.54 libswresample.so.1 plugin sinusbot-0.9.8.tar.bz2 ts3bot - YoutubeDLPath = not set - TS3Path = /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.18.2) - LogLevel = - Config: - TS3 Client: db9ca817116ad2a1d5f1efa4aabae409 - Bot Plugin: db9ca817116ad2a1d5f1efa4aabae409 - TS3 Plugin: installed (md5 hash match) - Version: unknown - Binary: /opt/ts3soundboard/ts3bot (Hash: 3b2c7f99a3b0a358e7d328079c4fa8b8) - Webinterface: port locally reachable (Port: 8087) - Status: not runningBOT INFORMATION - Report date: 16.01.2016 06:31:14 EST -05:00:00 (timezone: America/New_York) - DISK: 1.25 GB/48.74 GB in use (2%) - SWAP: 104.00 KB/512.00 MB in use (0%) - RAM: 71.30 MB/3.00 GB in use (2%) Virtualization: VT-x CPU MHz: 3192.950 CPU(s): 4 Architecture: x86_64 - CPU: - DNS resolution check: google.com -> OK - Bot Start Script: not found - OS APT Last Update: 16.01.2016 06:04:56 EST -05:00:00 - OS Missing Packages: None (v1) - OS Updates: 3 (updates available!) - Uptime: 0 days, 20 hours, 47 minutes, 25 seconds - Load Average: 0.80 0.73 0.58 - Kernel: Linux 2.6.32-042stab108.3 x86_64 - OS x64 check: OK - Operating System: Debian GNU/Linux 7.9 (wheezy) (OpenVZ)SYSTEM INFORMATIONSINUSBOT RELATED==========================================================
Zento
is the botuser the owner of the botfolder?
type as root: chown -R username /opt/ts3soundboard/
Zento
with this command you dont start the bot
this ist the teamspeak client.
use
xinit /opt/ts3soundboard/sinusbot -RunningAsRootIsEvilAndIKnowThat -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
SS: http://screenshot.sh/oBDyMkMfrPpsd
waiting for X server to shut downxinit: connection to X server lostis in your path.Specify a program on the command line or make sure that /usr/binxinit: Unable to run program "/opt/ts3soundboard/sinusbot": No such file or directoryxinit: XFree86_VT property unexpectedly has 0 items instead of 1[dix] Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, removing from list![dix] Could not init font path element /usr/share/fonts/X11/75dpi, removing from list![dix] Could not init font path element /usr/share/fonts/X11/100dpi, removing from list![dix] Could not init font path element /usr/share/fonts/X11/Type1, removing from list![dix] Could not init font path element /usr/share/fonts/X11/75dpi/:unscaled, removing from list![dix] Could not init font path element /usr/share/fonts/X11/100dpi/:unscaled, removing from list![dix] Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
Zento
Inside the folder /opt/ts3soundboard/ is there a file called "sinusbot"? And is this file executable?
I install 9.9 Version and:
SS: http://screenshot.sh/m2aQtlvZrmNFv
2016/01/16 08:28:08 x [MAIN] ERROR: listen unix /tmp/.X11-unix/X40: bind: address already in use2016/01/16 08:28:08 X [MAIN] Starting up fake x-server...2016/01/16 08:28:08 5def94e1 WARN Could not save bot configuration-------------------------------------------------------------------------------PLEASE MAKE SURE TO CHANGE THE PASSWORD DIRECTLY AFTER YOUR FIRST LOGIN!!!Generating new bot instance with account 'admin' and password 'foobar'-------------------------------------------------------------------------------2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js2016/01/16 08:28:08 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
