Problem
Zereax
Hey immer wenn ich den Bot starten will kommt das
2017-12-27T16:54:14+01:00 reconnecting soon
2017-12-27T16:54:14+01:00 disconnected from discord
2017-12-27T16:54:14+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:54:13+01:00 disconnected from discord
2017-12-27T16:54:13+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:54:07+01:00 reconnecting soon
2017-12-27T16:54:07+01:00 disconnected from discord
2017-12-27T16:54:07+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:54:06+01:00 disconnected from discord
2017-12-27T16:54:06+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:54:00+01:00 reconnecting soon
2017-12-27T16:54:00+01:00 disconnected from discord
2017-12-27T16:54:00+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:59+01:00 disconnected from discord
2017-12-27T16:53:59+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:57+01:00 disconnected from discord
2017-12-27T16:53:57+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:51+01:00 reconnecting soon
2017-12-27T16:53:51+01:00 disconnected from discord
2017-12-27T16:53:51+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:50+01:00 disconnected from discord
2017-12-27T16:53:50+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:44+01:00 reconnecting soon
2017-12-27T16:53:44+01:00 disconnected from discord
2017-12-27T16:53:44+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:43+01:00 disconnected from discord
2017-12-27T16:53:43+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:37+01:00 reconnecting soon
2017-12-27T16:53:37+01:00 disconnected from discord
2017-12-27T16:53:37+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:36+01:00 disconnected from discord
2017-12-27T16:53:36+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:30+01:00 reconnecting soon
2017-12-27T16:53:30+01:00 disconnected from discord
2017-12-27T16:53:30+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:29+01:00 disconnected from discord
2017-12-27T16:53:29+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:24+01:00 reconnecting soon
2017-12-27T16:53:24+01:00 disconnected from discord
2017-12-27T16:53:24+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:23+01:00 disconnected from discord
2017-12-27T16:53:23+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:22+01:00 disconnected from discord
2017-12-27T16:53:22+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
2017-12-27T16:53:17+01:00 reconnecting soon
2017-12-27T16:53:17+01:00 disconnected from discord
2017-12-27T16:53:17+01:00 error from conn reader: websocket: close 4012: Requested gateway version is no longer supported or invalid
Was ist das wie behebe ich das?
2017-12-27T16:29:45+01:00 LOGIN [admin] OK
2017-12-27T16:28:03+01:00 INSTANCE-CREATE [admin] (Ranjid) OK
2017-12-27T16:28:03+01:00 Discord bot credentials for bot Ranjid / client 395598262301753356 valid. Yay.
2017-12-27T16:25:35+01:00 LOGIN [admin] OK
2017-12-27T16:25:29+01:00 Adding new user admin
2017-12-27T16:25:29+01:00 Promoting instance to main instance
2017-12-27T16:25:29+01:00 Creating default instance
2017-12-27T16:25:29+01:00 Loading instances
Ich zitiere aus dem LIES MICH BEVOR DU SCHREIBST thread:
  • die benutzte Version
  • das Betriebssystem (z.B. Windows, 64bit)
  • verwendete Hardware (z.B. VPS, Core i7, 8 GB RAM)
  • verwendeter Browser (ggf. vorhandene Plugins)
  • freier Speicher (RAM + HDD)
  • deine config.ini
