Solved problem
krasser88
2019-03-02T19:55:12+01:00 Could not create Notifications-Tabletable Notifications already exists
2019-03-02T19:55:12+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-03-02T19:55:12+01:00 Could not create Chat-Tabletable Chat already exists
2019-03-02T19:54:38+01:00 TSClient quit.
2019-03-02T19:54:38+01:00 KILL [admin] OK
2019-03-02T19:54:37+01:00 Could not request shutdown. Please make sure that the plugin is installed correctly; HTTP returned an error: Timeout; Code: 500; Message: Timeout
krasser88
- Kernel: Linux 3.16.0-7-amd64 x86_64
- Load Average: 0.49 0.25 0.24
- Uptime: 0 days, 19 hours, 10 minutes, 55 seconds
- OS APT Last Update: 02.03.2019 19:44:53 CET +01:00:00
CPU(s): 10
Thread(s) per core: 1
Core(s) per socket: 10
Socket(s): 1
Model name: Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz
CPU MHz: 2199.998
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 1007.10 MB/59.10 GB in use (1%)
- DISK: 16.49 GB/1.53 TB in use (1%)
+ libglib: 2.42.1-1+b12.42.1-1+b1
- Status: running (PIDs: 8252 8251, User: Bot)
- Binary: /opt/bot/sinusbot
- Binary Info: MD5 Hash: 457224ee75d8a25d64eab6fc7465cd48, Perms: 755, User: Bot
- Version: 0.14.3-0e747fd
- TS3Path = /opt/bot/teamspeak3-client/ts3client_linux_amd64 (Version 3.2.3)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.03.01)
- Installed scripts: advertising.js; AFK_Mover.js; alonemode.js; bookmark.js; CountOnlineUsers.js; facebook.js; followme.js; norecording.js; rememberChannel.js; Server_Join_Alert.js; Server_Rules.js; welcome.js; ZTSupport_-_SupportChannel_With_ServerGroup_Support.js
- Time (local): 02.03.2019 20:17:13 CET +01:00:00
- Time (remote): 02.03.2019 20:17:13 CET +01:00:00
- TeamSpeak 3 Version: 3.2.3
- youtube-dl Version: 2019.03.01
- DiagScript Version: 0.7.1
[/CODE]
in the forum within a CODE-tag
Did you seriously just submit two posts, without a single word of you own? 😵
Since you don't seem to like to use the search function on you own ... short sum-up:
Known problem! Get newest version! Enjoy!
https://forum.sinusbot.com/resources/internal-alpha.1/
Important, afterwards ... Post more topics with new problems resulting from you old scripts not working anymore with the new version ;)
krasser88
is das richtig was er macht
[email protected]:/opt/sinusbot# cp plugin/libsoundbot_plugin.so
cp: missing destination file operand after ‘plugin/libsoundbot_plugin.so’
Try 'cp --help' for more information.
Ich will dir ja nicht zu Nahe treten, aber vielleicht wäre es besser, wenn du jemanden aus deinem Freundeskreis beauftragst, sich dem Bot anzunehmen, der etwas ... nunja ... IT-affiner ist. :rolleyes:
Dennoch zu deiner Frage:
Nein, ist es nicht, da du die Hälfte des Commands vergessen hast!
Bash:
# copy the plugin
cp plugin/libsoundbot_plugin.so TeamSpeak3-Client-linux_amd64/plugins/
# or, if you've used the sinusbot installer:
# cp plugin/libsoundbot_plugin.so teamspeak3-client/plugins/
