Problems when i start the bot
Dovahkiin
When i want to start the bot, the bot dont want to connect to the TS3 server.
In the "Instance Settings" i have no problems with the settings. (All perfect.)
When i press the button, it turn to Green, after 3-4 sec again Orange.
When i open the "Bot log" there no more logs, than the basic logs.
Bot log:
"Start bot" button Green:
"Start bot" button, after 3-4 sec
Instance Log:
2020-04-26T18:41:46+02:00 closing channels
2020-04-26T18:41:45+02:00 Storing configuration.
2020-04-26T18:41:40+02:00 Closed.
2020-04-26T18:41:40+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-26T18:41:40+02:00 Error spawning instancefork/exec C:\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: A kért művelethez magasabb felhasználói szint szükséges.
2020-04-26T18:41:40+02:00 Starting instance ts3server://173.249.42.15?port=9988&nickname=Avarosa%20from%20Freljord&password=&channel=&channelpassword=
2020-04-26T18:41:40+02:00 About to run.
2020-04-26T18:41:40+02:00 Prespawn.
2020-04-26T18:41:36+02:00 BOT-CONFIG [admin] CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2020-04-26T18:34:15+02:00 Storing configuration.
2020-04-26T18:34:14+02:00 closing channels
2020-04-26T18:34:12+02:00 Closed.
2020-04-26T18:34:12+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-26T18:34:12+02:00 Error spawning instancefork/exec C:\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: A kért művelethez magasabb felhasználói szint szükséges.
2020-04-26T18:34:11+02:00 Starting instance ts3server://173.249.42.15?port=9988&nickname=Avarosa%20from%20Freljord&password=&channel=&channelpassword=
2020-04-26T18:34:11+02:00 About to run.
2020-04-26T18:34:11+02:00 Prespawn.
2020-04-26T18:23:46+02:00 Storing configuration.
2020-04-26T18:23:25+02:00 closing channels
2020-04-26T18:23:24+02:00 Closed.
2020-04-26T18:23:23+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-26T18:23:23+02:00 Error spawning instancefork/exec C:\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: A kért művelethez magasabb felhasználói szint szükséges.
2020-04-26T18:23:23+02:00 Starting instance ts3server://173.249.42.15?port=9988&nickname=Avarosa%20from%20Freljord&password=&channel=&channelpassword=
2020-04-26T18:23:23+02:00 About to run.
2020-04-26T18:23:23+02:00 Prespawn.
2020-04-26T18:22:46+02:00 Storing configuration.
2020-04-26T18:22:44+02:00 closing channels
2020-04-26T18:22:42+02:00 Closed.
2020-04-26T18:22:42+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-26T18:22:42+02:00 Error spawning instancefork/exec C:\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: A kért művelethez magasabb felhasználói szint szükséges.
2020-04-26T18:22:42+02:00 Starting instance ts3server://173.249.42.15?port=9988&nickname=Avarosa%20from%20Freljord&password=&channel=&channelpassword=
2020-04-26T18:22:42+02:00 About to run.
2020-04-26T18:22:42+02:00 Prespawn.
2020-04-26T18:22:35+02:00 closing channels
2020-04-26T18:22:33+02:00 Closed.
2020-04-26T18:22:33+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-26T18:22:33+02:00 Error spawning instancefork/exec C:\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: A kért művelethez magasabb felhasználói szint szükséges.
2020-04-26T18:22:33+02:00 Starting instance ts3server://173.249.42.15?port=9988&nickname=Avarosa%20from%20Freljord&password=&channel=&channelpassword=
2020-04-26T18:22:33+02:00 About to run.
2020-04-26T18:22:33+02:00 Prespawn.
2020-04-26T18:22:28+02:00 BOT-CONFIG [admin] NICK CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2020-04-26T18:21:15+02:00 Storing configuration.
2020-04-26T18:21:02+02:00 closing channels
2020-04-26T18:21:00+02:00 Closed.
2020-04-26T18:21:00+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-26T18:21:00+02:00 Error spawning instancefork/exec C:\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: A kért művelethez magasabb felhasználói szint szükséges.
2020-04-26T18:21:00+02:00 Starting instance ts3server://173.249.42.15?port=9988&nickname=Avarosa&password=&channel=&channelpassword=
2020-04-26T18:21:00+02:00 About to run.
2020-04-26T18:21:00+02:00 Prespawn.
2020-04-26T18:20:48+02:00 unloaded instance
2020-04-26T18:20:48+02:00 > flush done
2020-04-26T18:20:44+02:00 imported module: command
2020-04-26T18:20:44+02:00 resolving module command
2020-04-26T18:20:44+02:00 script command loaded
2020-04-26T18:20:44+02:00 module registered as command
2020-04-26T18:20:44+02:00 registered callback for event chat
2020-04-26T18:20:44+02:00 script sinusbot-commands loaded
2020-04-26T18:20:44+02:00 registered callback for event load
2020-04-26T18:20:44+02:00 [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020-04-26T18:20:44+02:00 executing script command
2020-04-26T18:20:44+02:00 executing script sinusbot-commands
2020-04-26T18:20:33+02:00 unloaded instance
2020-04-26T18:20:33+02:00 > flush done
2020-04-26T18:20:31+02:00 imported module: command
2020-04-26T18:20:31+02:00 resolving module command
2020-04-26T18:20:31+02:00 script command loaded
2020-04-26T18:20:31+02:00 module registered as command
2020-04-26T18:20:31+02:00 registered callback for event chat
2020-04-26T18:20:30+02:00 script sinusbot-commands loaded
2020-04-26T18:20:30+02:00 registered callback for event load
2020-04-26T18:20:30+02:00 [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020-04-26T18:20:30+02:00 executing script command
2020-04-26T18:20:30+02:00 executing script sinusbot-commands
2020-04-26T18:19:15+02:00 Storing configuration.
2020-04-26T18:18:56+02:00 closing channels
2020-04-26T18:18:55+02:00 Closed.
2020-04-26T18:18:55+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-26T18:18:55+02:00 Error spawning instancefork/exec C:\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: A kért művelethez magasabb felhasználói szint szükséges.
2020-04-26T18:18:54+02:00 Starting instance ts3server://173.249.42.15?port=9988&nickname=Avarosa&password=&channel=&channelpassword=
2020-04-26T18:18:54+02:00 About to run.
2020-04-26T18:18:54+02:00 Prespawn.
2020-04-26T18:18:45+02:00 Storing configuration.
2020-04-26T18:18:37+02:00 closing channels
2020-04-26T18:18:36+02:00 Closed.
2020-04-26T18:18:36+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-26T18:18:36+02:00 Error spawning instancefork/exec C:\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: A kért művelethez magasabb felhasználói szint szükséges.
2020-04-26T18:18:35+02:00 Starting instance ts3server://173.249.42.15?port=9988&nickname=Avarosa&password=&channel=&channelpassword=
2020-04-26T18:18:35+02:00 About to run.
2020-04-26T18:18:35+02:00 Prespawn.
2020-04-26T18:18:29+02:00 closing channels
2020-04-26T18:18:27+02:00 Closed.
2020-04-26T18:18:27+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-04-26T18:18:27+02:00 Error spawning instancefork/exec C:\SinusBot\TeamSpeak 3 Client\ts3client_win64.exe: A kért művelethez magasabb felhasználói szint szükséges.
2020-04-26T18:18:27+02:00 Starting instance ts3server://173.249.42.15?port=9988&nickname=Avarosa&password=&channel=&channelpassword=
2020-04-26T18:18:27+02:00 About to run.
2020-04-26T18:18:27+02:00 Prespawn.
2020-04-26T18:18:24+02:00 BOT-CONFIG [admin] HOST PORT CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2020-04-26T18:17:45+02:00 Storing configuration.
2020-04-26T18:17:17+02:00 closing channels
2020-04-26T18:17:16+02:00 imported module: command
Thanks, and sorry for my english! :D
fabm3n
Tier II
Tier I
I send you the exactly part of fixing the error spawning problem.
