Required permission
DhrRob
Whenever my bot connects to the teamspeak I get the following error msg:
<17:19:51> insufficient client permissions (failed on b_virtualserver_servergroup_client_list)
It keeps spamming this untill the anti-spam disables the bot from issueing more commands. How can I disable the bot from issueing this command (if it's not a critical command)
My config.ini:
LogLevel = 3
MTU = 1500
SampleInterval = 100
LicenseKey = "xxx"
EnableAloneMode = false
version 0.9.8
Raphraph
This permission allows the bot to see who is online. You have to give this permnissions to the bot, because it enables some features. And you cannot prevent the bot from using this "command".
