won't fix Screen is terminating
abb
I saw that there's a similar thread but it didn't help me any further.
When I try to make a second panel of sinusbot in Putty I get the message 'screen is terminating' where usually I should get some sort of installing screen after I used the 'RunningAsRootIsEvilAndIKnowThat' command.
I used to be able to create 4-5 panels untill 1-2 weeks agoo but since a week only the first panel works and I can't install any more. Can someone help me out?
You are not allowed to have multiple installations of the bot.
This flag was disabled in a previous update due to security reasons, see FAQ for more.
Again, you are only allowed to run the bot more than once therefore we don't support this.
If you want to have more instances take a look at the FAQ.
