Script not loaded / crashed. Took too long: Timeout
TheTh0rus
Operating System: Windows
SinusBot Version: 0.9.21
TS3 Version: 3.1.4.2
i am running my bot primarily to execute scripts that change channel titles etc.
since i updated the bot doesnt work anymore. it still joins the server but the scripts dont work
error:
Looking for another possibility to make sports.
Send us the script^^ without we can't help you ;)
TheTh0rus
one script that causes that:
registerPlugin({
  version: '1.0',
  description: 'afk-stuff',
  author: 'TheTh0rus',
  vars: [],
},function(sinusbot, config, info) {
    var clientson = [];
    var clientsmid = [];
    var clientsoff = [];
  setInterval(function() { main(); }, 10000);
    sinusbot.on('poke', function(ev) {
            main();
        function main() {
            var clients = backend.getClients();
        clients.forEach(function(client) {
                if(client.isMuted() ||client.isDeaf() || client.isAway() && client.uniqueID().toString() !=  "J/KqievQaUg/fZqXghd7Xbu9Wos=" && client.uniqueID().toString() !=  "a6/P8jy3EBIzqJJdRcDYdagb7mc=") {
                    if(clientson.indexOf(client.databaseID()) === -1 && clientsmid.indexOf(client.databaseID()) === -1) {
                        clientson.push(client.databaseID());
                } else {
                    if(clientson.indexOf(client.databaseID()) !== -1 || clientsmid.indexOf(client.databaseID()) !== -1) {
                        clientsmid.splice(clientsmid.indexOf(client.databaseID()),1);
                        clientsoff.push(client.databaseID());
    setTimeout(function() {
        clientson.forEach(function(client) {
                clientson.splice(clientson.indexOf(client),1);
                clientsmid.push(client);
                sinusbot.addClientToServerGroup(client,4003);
                sinusbot.log(client);
        clientsoff.forEach(function(client) {
            clientsoff.splice(clientson.indexOf(client),1);
            sinusbot.removeClientFromServerGroup(client,4003);
        }, 5000);
its a script that gives muted users a rank that infinite idletime
semi-inactive™
Stop pushing this topic, at least one of your scripts is faulty, this is not an issue with the bot.
disable them one by one to find the faulty one(s)
semi-inactive™
instead of disabling try removing all scripts one by one from the scripts folder and reloading the bot
