Script won't load
Aerora
I wrote a script by myself and I put it into the script folder. I restarted the bot but it won't load. I checked but I haven't found nothing: no errors, no warnings, nothing... What can I do?
My bot version: 0.14.3
My O.S. version: CentOS Linux (7)
Kamikaze
I wrote a script by myself and I put it into the script folder. I restarted the bot but it won't load. I checked and I haven't found nothing: no errors, no warnings, nothing... What can I do?
Set Loglevel = 10 , restart Sinusbot, post log
semi-inactive™
How about sending us the script that is likely to be at fault? :rolleyes:
Aerora
JavaScript:
registerPlugin({
    name 'Advanced ChaosGaming Welcome',
    version: '1.0'
    description: 'Gestisce i messaggi di join.'
    author: 'Aerora <[email protected]>'
    vars: [{
        title: 'Messaggio da inviare. (%u = nome utente)',
        type: 'string'
        title: 'Messaggio quando entra la seconda volta. (%u = nome utente)',
        type: 'string'
        title: 'Modalità di messaggio.',
        type: 'select',
        options: [
            'Chat privata', //0
            'Poke' //1
    var event = require('event');
    event.on('connect', function (connectionEvent) {
        var messaggyno = config.primoMessaggio;
        var messaggyno2 = config.secondoMessaggio;
        messaggyno = messaggyno.replace(/%u/g, connectionEvent.client.name());
        messaggyno2 = messaggyno2.replace(/%u/g, connectionEvent.client.name());
        if(connectionEvent.client.getTotalConnectionsCount() == 1){
            if(config.tipoMessaggio == 0){
                connectionEvent.client.chat(messaggyno);
            else{
                connectionEvent.client.poke(messaggyno2);
            connectionEvent.client.addToServerGroup('Utente');
        else{
            else{
Aerora
Where is the ,
Besides, scripts for this already exsist
It there a script that add a server group on the first join with a message changing? Could you send it to me?
Anyway, how can I fix this?
Error in script (event connect): TypeError: Cannot access member 'client' of undefined
at CGWelcome.js:28:42
Lala Sabathil
First, you should always write scripts in english.
Second: i try ot at home, i am in a train right now
semi-inactive™
The connect event does not have any parameters.
It doesn't do what you think it does. It's not fired when clients connect, only when the bot connects.
Client connection events are just "clientMove" events where fromChannel is null.
Aerora
Thanks, I'm going to edit it.
Kamikaze
JavaScript:
registerPlugin({
    version: '1.0',
    description: 'Gestisce i messaggi di join.',
    author: 'Aerora <[email protected]>',
    vars: [{
        type: 'string'
        type: 'string'
        type: 'select',
        options: [
            'Chat privata', //0
            'Poke' //1
    event.on('clientMove', function (connectionEvent) {
        if(connectionEvent.toChannel.id() == x) { // replace x with channel id of default channel
                else{
            else{
                else{
Aerora
JavaScript:
registerPlugin({
    version: '1.0',
    vars: [{
        type: 'string'
        type: 'string'
        type: 'select',
        options: [
            'Chat privata', //0
            'Poke' //1
                else{
            else{
                else{
Shouldn't be 'connectionEvent' instead of 'ev'?
Aerora
It sends only the message for the first join (even if the total connections are > 1) and then it doesn't do nothing more.
