Sinus bot Verbindet nicht / Sinus bot doesn't connect
Burgstaller1027
Operating System: Linux 64bit
SinusBot Version: Installer Script
TS3 Client Version: Installer Script
TS3 Server Version: 3.0.13.4 auf Windows
Problem Beschreibung / Problem Description
Ich kann mit meinem Bot auf jeden x-billig Server Verbinden, nur auf einen nicht, und das Verstehe ich nicht. Der Bot besitzt die notwendige Sicherheitsstufe und der Bot wurde nicht gebannt. // I can connect to my bot on any x-cheap server, just on one, and I do not understand. The bot is the necessary security level and the bot has not been banned.
2017-04-25T19:25:38+02:00 TSClient quit.
2017-04-25T19:25:38+02:00 KILL [admin] OK
2017-04-25T19:25:37+02:00 New connection status 0; Error 0
2017-04-25T19:25:37+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2017-04-25T19:25:37+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-04-25T19:25:37+02:00 SinusBot joined the channel
2017-04-26T15:18:53+02:00 TSClient quit.
2017-04-26T15:18:52+02:00 New connection status 0; Error 0
2017-04-26T15:18:52+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or your client version is outdated (the server doesn't allow it anymore).
2017-04-26T15:18:52+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2017-04-26T15:18:52+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-04-26T15:18:52+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 3
2017-04-26T15:18:52+02:00 New connection status 1; Error 0
2017-04-26T15:18:52+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-04-26T15:18:52+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-04-26T15:18:52+02:00 TS |INFO |ClientUI |1 |Initiating connection: 164.132.204.217:9987 ts3.kbs-community.de
2017-04-26T15:18:52+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-04-26T15:18:52+02:00 TS |INFO |ClientUI |1 |Resolve successful: 164.132.204.217:9987
2017-04-26T15:18:52+02:00 TS |INFO |ClientUI |1 |Lookup finished: 164.132.204.217 9987 ts3.kbs-community.de 0 0
2017-04-26T15:18:49+02:00 TS |INFO |LicenseViewer | |Found cached license for version 1 and language en
2017-04-26T15:18:48+02:00 TS |INFO |LicenseViewer | |License language: en
2017-04-26T15:18:48+02:00 TS |INFO |Update | |Check license version: 1
2017-04-26T15:18:48+02:00 TS |INFO |Update | |Checking for updates...
2017-04-26T15:18:48+02:00 TS |INFO |TSDNS | |DNS resolve successful, "ts3.kbs-community.de"=164.132.204.217
2017-04-26T15:18:48+02:00 TS |INFO |ClientUI | |Checking for update
2017-04-26T15:18:48+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2017-04-26T15:18:48+02:00 TS |INFO |TSDNS | |No SRV TSDNS found at "_tsdns._tcp.kbs-community.de"
2017-04-26T15:18:48+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful for "_ts3._udp.ts3.kbs-community.de"
2017-04-26T15:18:48+02:00 TS |INFO |ClientUI |1 |Trying to resolve ts3.kbs-community.de
2017-04-26T15:18:48+02:00 TS |INFO |ClientUI |1 |Connect to server: ts3.kbs-community.de
2017-04-26T15:18:48+02:00 TS |INFO |ClientUI | |ts3server: ts3.kbs-community.de?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-04-26T15:18:48+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/97f7bb0d-a9a4-4c53-995c-dfa69a09ff9a/93d3f92f-0e15-46a2-92c2-a04b4e66651e/settings.db
2017-04-26T15:18:48+02:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-04-26T15:18:48+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-04-26T15:18:46+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-04-26T15:18:46+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-04-26T15:18:46+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-04-26T15:18:46+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-04-26T15:18:46+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-04-26T15:18:46+02:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-04-26T15:18:46+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2017-04-26T15:18:46+02:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2017-04-26T15:18:46+02:00 TS |INFO | | |Using hardware aes
2017-04-26T15:18:46+02:00 TS |INFO | | |SystemInformation: Linux 3.16.0-042stab120.16 #1 SMP Tue Dec 13 20:58:28 MSK 2016 x86_64 Binary: 64bit
2017-04-26T15:18:46+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-04-26T15:18:45+02:00 Starting instance ts3server://ts3.kbs-community.de?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-04-26T15:18:43+02:00 BOT-CONFIG [admin] HOST PORT CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2017-04-26T15:18:27+02:00 BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC IDENTITY OK
Guten Tag,
und wir verstehen dein Problem nicht, ohne _ ausführliche _ Logs.
Lies den Post "READ ME Before you post" und pack mal bitte die Server Adresse mit rein. ;)
Burgstaller1027
Hallo, ich denke das du folgende Logs meinst?:
TS³ IP: ts3.kbs-community.de
Setze mal auf die beiden Gründe.
@Diesmon, ich habe das eigentlich schon alles überprüft, und habe eigentlich nichts von diesen Dingen feststellen können.
Bin mir 99,99% sicher, dass das was Diesmon meint der Grund ist.
Wie hast du denn getestet, ob die Version vom server nicht mehr geduldet wird?
Burgstaller1027
@irgendwer , naja es kommt ein andere Sinusbot auch auf den TS³, deshalb denke ich, dass das an mir liegen muss? Oder liege ich da Falsch? Bzw. mein SinusBot welcher auf meinem PC laufen würde, kann auch auf den Server Verbinden, nur irgendwie nicht mein SinusBot welcher auf meinem Linux Server ist.
Der TS³ ist auf der Version: 3.0.13.4
Mein SinusBot ist auf der Version: 3.0.19.4
unterschiedliche TS client versionen?
Burgstaller1027
@irgendwer ,
Ja,
Aber ich glaube nicht, dass das daran liegen könnte? Oder liege ich da komplett Falsch?
ShadowFM
Was ist dem mit dem Part im Log?
Burgstaller1027
@ShadowFM , Ich habe bei der Installation das "Installer-Script" verwendet, und weis leider nicht wirklich was dieser Fehler bedeutet, bzw. wie ich mit diesem umgehen sollte. (Es ist mir klar, dass er etwas nicht findet, aber warum genau bei diesem Server?)
hast du auf linux eine andere ts version als auf windows? dann könnte es daran liegen.
Burgstaller1027
@irgendwer ,
Ich verwende ja das Starter-Script, in dem ist ja eine TS³ Version enthalten. Dort hat mein "Bot" in den Informationen folgendes stehen: "3.0.19.4 auf Linux"
Der Server auf den mein Bot nicht kommt besitzt folgende Version: 3.0.13.4 auf Windows
Einer der Server auf den mein Bot kommt besitzt folgende Version: 3.0.13.6 auf Windows
Das sind zwar unterschiedlicher Versionen zwischen meinem Linux Server und dem TS³, aber dann verstehe ich nicht warum mein Bot dann auf andere Server verbinden kann, welche ebenfalls nicht die gleiche Version besitzen...?
Was für einen Sicherheitslevel hat der bot denn? (siehe webinterface)
Ich glaube du missverstehst hier was, der letzte hinweis mit dem version mismatch sagt aus, das der Serveradmin festgelegt hat das nur client ab version x oder höher connecten dürfen. Da kannst du nix machen außer die version die der admin haben will zu nutzen
Burgstaller1027
@irgendwer , Sicherheitsstufe 32. // Server benötigt mindesten 26.
@Diesmon , Ich habe mich jetzt mal am Server umgeschaut, und glaube das ich nun eine Version gefunden habe, welche Funktionieren sollte. Jetzt die Frage, weiß jemand, wie man "Manuell" das "Installer-Script" Editieren kann, um dieses anschließen mit der "anderen" TS³ Version zu Installieren? Oder muss/sollte ich mich dafür an den Entwickler dieses Scripts wenden?
es gibt keine höhere version als 3.0.19.4 die mit dem sinusbot funktioniert atm
