m4r1vs
Hello, I just installed the SinusBot with the provided install script on my Debian 8 Server and everything seemed fine. Then after setting up the instance and starting it the bot connected to my server but almost immediately after that it timed out again.
My Server is running on version 3.3 and the bot is using the TeamSpeak Client 3.2.1. SinusBot is running on version 0.14.3-0e747fd.
I am not very familiar with this kind of stuff so any help is very much appreciated, thanks!
This is the instance log I get everytime:
2018-11-21T18:38:01+01:00 TSClient quit.
2018-11-21T18:38:01+01:00 Closed.
2018-11-21T18:38:01+01:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2018-11-21T18:38:01+01:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2018-11-21T18:38:01+01:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2018-11-21T18:38:00+01:00 TS>invalid utf8 string send to logging
2018-11-21T18:38:00+01:00 PRIVATE-CHAT [Jarvis]
2018-11-21T18:38:00+01:00 New connection status 4; Error 0
2018-11-21T18:38:00+01:00 TS |INFO |PermManager | |Loading permissions from cache
2018-11-21T18:38:00+01:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2018-11-21T18:38:00+01:00 New connection status 3; Error 0
2018-11-21T18:38:00+01:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2018-11-21T18:38:00+01:00 New connection status 2; Error 0
2018-11-21T18:38:00+01:00 TS |INFO |ClientUI |1 |Connect status: Connected
2018-11-21T18:38:00+01:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 4
2018-11-21T18:38:00+01:00 New connection status 1; Error 0
2018-11-21T18:38:00+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-11-21T18:38:00+01:00 TS |INFO |ClientUI |1 |Initiating connection: 185.26.156.12:64899
2018-11-21T18:38:00+01:00 New connection status 0; Error 1797
2018-11-21T18:38:00+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-11-21T18:38:00+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-11-21T18:37:56+01:00 TS |INFO |TSDNS | |No TSDNS found
2018-11-21T18:37:56+01:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully 185.26.156.12:41144
2018-11-21T18:37:56+01:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully 2a00:d0c0:200:0:b9:1a:9c0c:22a:41144
2018-11-21T18:37:55+01:00 TS |INFO | | |Statistics report: Not yet, next report on Wed Dec 5 12:12:18 2018
2018-11-21T18:37:55+01:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-11-21T18:37:55+01:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-11-21T18:37:55+01:00 New connection status 1; Error 0
2018-11-21T18:37:55+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-11-21T18:37:55+01:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-11-21T18:37:55+01:00 TS |INFO |ClientUI |1 |Initiating connection: [2a00:d0c0:200:0:b9:1a:9c:c]:64899
2018-11-21T18:37:55+01:00 TS |INFO |ClientUI |1 |Resolve successful: [2a00:d0c0:200:0:b9:1a:9c:c]:64899185.26.156.12:64899
2018-11-21T18:37:55+01:00 TS |INFO |ClientUI |1 |Lookup finished: ip=2a00:d0c0:200:0:b9:1a:9c:c port=64899 query=maniyt.de error=0
2018-11-21T18:37:55+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "m4r1vs.atria.uberspace.de" =(h: 2a00:d0c0:200:0:b9:1a:9c:c p:0), (h: 185.26.156.12 p:0)
2018-11-21T18:37:55+01:00 TS |INFO |TSDNS | |SRV DNS resolve successful, "_ts3._udp.maniyt.de" =(h: m4r1vs.atria.uberspace.de p:64899)
2018-11-21T18:37:54+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "maniyt.de" =(h: 2a00:d0c0:200:0:b9:1a:9c0c:22a p:0), (h: 185.26.156.12 p:0)
2018-11-21T18:37:54+01:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.maniyt.de" DNS server returned answer with no data
2018-11-21T18:37:54+01:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "maniyt.de" =(h: 2a00:d0c0:200:0:b9:1a:9c0c:22a p:0), (h: 185.26.156.12 p:0)
2018-11-21T18:37:54+01:00 TS |INFO |ClientUI |1 |Trying to resolve maniyt.de
2018-11-21T18:37:54+01:00 TS |INFO |ClientUI |1 |Connect to server: maniyt.de
2018-11-21T18:37:54+01:00 TS |INFO |ClientUI | |ts3server: maniyt.de?port=9987&nickname=Watson&password=&channel=&channelpassword=
2018-11-21T18:37:54+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/92dba953-b537-43cd-b7a3-ac5989c27435/64c353f7-b1dd-4353-9101-25d350b38756/settings.db
2018-11-21T18:37:54+01:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-11-21T18:37:54+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-11-21T18:37:54+01:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2018-11-21T18:37:54+01:00 TS |INFO | | |*** Time [INIT]: 207
2018-11-21T18:37:54+01:00 TS |INFO | | |*** Time [MAINWINDOW]: 207
2018-11-21T18:37:54+01:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2018-11-21T18:37:54+01:00 TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2018-11-21T18:37:54+01:00 TS |INFO | | |successfully downloaded revocation list for accounting
2018-11-21T18:37:54+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2018-11-21T18:37:54+01:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2018-11-21T18:37:54+01:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-11-21T18:37:54+01:00 TS |INFO |Addons | |Checking for addon updates...
2018-11-21T18:37:54+01:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2018-11-21T18:37:54+01:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-11-21T18:37:54+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2018-11-21T18:37:54+01:00 TS |INFO | | |Using hardware aes
2018-11-21T18:37:54+01:00 TS |INFO | | |SystemInformation: Linux 2.6.32-042stab127.2 #1 SMP Thu Jan 4 16:41:44 MSK 2018 x86_64 Binary: 64bit
2018-11-21T18:37:54+01:00 TS |INFO | | |TeamSpeak 3 Client 3.2.1 (2018-08-14 14:00:36)
2018-11-21T18:37:54+01:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/92dba953-b537-43cd-b7a3-ac5989c27435/64c353f7-b1dd-4353-9101-25d350b38756/crashdumps
2018-11-21T18:37:54+01:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/92dba953-b537-43cd-b7a3-ac5989c27435/64c353f7-b1dd-4353-9101-25d350b38756/crashdumps
2018-11-21T18:37:54+01:00 Starting instance ts3server://maniyt.de?port=9987&nickname=Watson&password=&channel=&channelpassword=
2018-11-21T18:37:54+01:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2018-11-21T18:37:54+01:00 Could not delete from FileTransferno such table: FileTransfer
2018-11-21T18:37:54+01:00 Could not create Notifications-Tabletable Notifications already exists
2018-11-21T18:37:54+01:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-11-21T18:37:54+01:00 Could not create Chat-Tabletable Chat already exists
2018-11-21T18:37:54+01:00 About to run.
2018-11-21T18:37:54+01:00 Prespawn.
2018-11-21T18:37:44+01:00 Initialization complete
