SinusBot Doesn't start
Maz.b
2016/04/07 17:06:46 8cea3ecb 8785530c INFO  Starting instance ts3server://46.243.156.8?port=9987&nickname=Yolo&password=&channel=&channelpassword=
2016/04/07 17:06:46 8cea3ecb 8785530c INFO  TSClient quit.
- Operating System: Debian GNU/Linux 8.4 (jessie)
- Load Average: 0.59 0.66 0.73
- Uptime: 68 days, 14 hours, 32 minutes, 28 seconds
- OS APT Last Update: 07.04.2016 15:29:34 CEST +02:00:00
  Architecture:  x86_64
  CPU(s):  8
  Thread(s) per core:  2
  Core(s) per socket:  4
  Socket(s):  1
  Model name:  Intel(R) Xeon(R) CPU  W3520  @ 2.67GHz
  CPU MHz:  2668.000
  Virtualization:  VT-x
- RAM: 3.73 GB/15.69 GB in use (23%)
- SWAP: 33.48 MB/1021.99 MB in use (3%)
- DISK: 772.60 GB/967.27 GB in use (79%)
- Report date: 07.04.2016 17:02:14 CEST +02:00:00 (timezone: Europe/Amsterdam)
- Binary: /opt/ts3bot/ts3bot (Hash: 3b2c7f99a3b0a358e7d328079c4fa8b8)
- Version:
  - TS3Path = /opt/ts3bot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.18.2)
  - YoutubeDLPath = not set (does exist anyway, version: 2014.08.05)
- DiagScript version: v0.4.1
http://94.23.207.50:8087
try copying libsoundbot_plugin.so from the folder "plugin" to "TeamSpeak3-Client-linux_amd64/plugins"
No, it shouldn't be a problem.
Raphraph
Pleasd open your config.ini, set the LogLevel = 10
And then paste the console output here :)
Maz.b
2016/04/11 01:31:34 8cea3ecb 22011197 DEBUG  Spawning instance shortly due to missing configuration file
2016/04/11 01:31:34 8cea3ecb 22011197 INFO  Loaded
2016/04/11 01:31:34 8cea3ecb 8785530c DEBUG  Spawning instance shortly due to missing configuration file
2016/04/11 01:31:34 8cea3ecb 8785530c INFO  Loaded
2016/04/11 01:31:34 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2016/04/11 01:31:34 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2016/04/11 01:31:34 8cea3ecb 22011197 INFO  Starting instance ts3server://46.243.156.8?port=9987&nickname=Yolo&password=&channel=&channelpassword=
2016/04/11 01:31:34 8cea3ecb 8785530c INFO  Starting instance ts3server://46.243.156.8?port=9987&nickname=Yolo&password=&channel=&channelpassword=
QXcbConnection: Could not connect to display :0.1
QXcbConnection: Could not connect to display :0.0
2016/04/11 01:31:34 8cea3ecb 8785530c INFO  TSClient quit.
2016/04/11 01:31:34 8cea3ecb 22011197 INFO  TSClient quit.
2016/04/11 01:31:34 RadioStation data loaded
2016/04/11 01:31:34 Imported radio stations
2016/04/11 01:31:39 8cea3ecb 22011197 WARN  Could not request shutdown
2016/04/11 01:31:39 8cea3ecb 8785530c WARN  Could not request shutdown
2016/04/11 01:32:04 8cea3ecb 22011197 DEBUG  Storing configuration.
2016/04/11 01:32:04 8cea3ecb 8785530c DEBUG  Storing configuration.
