Sinusbot Error
ResulFreakS
2018-12-30T14:36:18+03:00 TSClient quit.
2018-12-30T14:36:17+03:00 New connection status 0; Error 1797
2018-12-30T14:36:17+03:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018-12-30T14:36:12+03:00 New connection status 1; Error 0
2018-12-30T14:36:07+03:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2018-12-30T14:35:26+03:00 TSClient quit.
2018-12-30T14:35:22+03:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2018-12-30T14:35:20+03:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2018-12-30T14:35:20+03:00 You will see a client window pop up shortly and then disappear again. That is perfectly normal. To launch the bot, please use the webinterface.
