Sinusbot installation on android
Brian
Hi, I'm using "Linux Deploy" from the app store to emulate a Linux server*.
I'm have some issue with sinusbot installer can anyone help me?30333034
LetsBlade
Hey, it seems youre trying to install Sinusbot on a Kali Linux "VM" which does not have the APT "debconf".
Try to use another one like Debian or Ubuntu.
Since Androids CPU Architecture is ARM i dont believe that Sinusbot or the TeamSpeak Client will run on this CPU
the error you have above is probably a problem with your sources.list which can not be read somehow
This won't work. You'd have to use an amd64 version, which you cannot choose from your list.
