Sinusbot instances not starting
barlap
Hello i have a problem , my sinusbot instances don't connect to server.
My vps running CentOS 7 x86_64 Minimal when i start the sinusbot in terminal it shows, i increased log level to 10:
I also tryed on debian and ubuntu, but the same problem persists
[icebot1@sinusbot sinusbot1]$ ./sinusbot
Version: 1.0.0-beta.3-735814e
2019/08/03 11:03:41 d1cafefb          INFO   Loading instances
2019/08/03 11:03:41 d1cafefb          INFO   Loading instance://4a12f7c5-48bf-4861-8f28-48436edb29b9
2019/08/03 11:03:41 d1cafefb 4a12f7c5 DEBUG  Spawning instance shortly due to missing configuration file.
2019/08/03 11:03:41 d1cafefb 4a12f7c5 DEBUG  Prespawn.
2019/08/03 11:03:41 d1cafefb 4a12f7c5 DEBUG  About to run.
2019/08/03 11:03:41 d1cafefb 4a12f7c5 INFO   Starting instance ts3server://ts.icegame.ro?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/08/03 11:03:41 d1cafefb 4a12f7c5 DEBUG  TS>/opt/sinusbot1/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
2019/08/03 11:03:41 d1cafefb 4a12f7c5 DEBUG  Closed.
2019/08/03 11:03:41 d1cafefb 4a12f7c5 INFO   TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/08/03 11:03:41 d1cafefb 4a12f7c5 DEBUG  executing script command
2019/08/03 11:03:41 d1cafefb 4a12f7c5 INFO   Initialization complete
2019/08/03 11:03:41 d1cafefb 4a12f7c5 INFO   Auto-Starting d1cafefb-7a60-4ef8-90ee-43f4ac21ebef/4a12f7c5-48bf-4861-8f28-48436edb29b9 in 500 ms...
2019/08/03 11:03:41 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/08/03 11:03:41 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/08/03 11:03:41 [GENERAL/YTDL   ] INFO   youtube-dl checking...
2019/08/03 11:03:41 d1cafefb 4a12f7c5 DEBUG  serialized function: true
2019/08/03 11:03:41 d1cafefb 4a12f7c5 DEBUG  registered callback for event chat
2019/08/03 11:03:41 d1cafefb 4a12f7c5 DEBUG  module registered as command
2019/08/03 11:03:41 d1cafefb 4a12f7c5 INFO   script command loaded
2019/08/03 11:03:42 d1cafefb 4a12f7c5 DEBUG  closing channels
2019/08/03 11:03:42 d1cafefb 4a12f7c5 DEBUG  About to run.
2019/08/03 11:03:42 d1cafefb 4a12f7c5 INFO   Starting instance ts3server://ts.icegame.ro?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/08/03 11:03:42 d1cafefb 4a12f7c5 WARN   Fail from voice reader: read unix @->@: use of closed network connection
2019/08/03 11:03:42 read unix @->@: use of closed network connection .  138
.  508
.  514
.  489
.  532
.  2197
2019/08/03 11:03:42 d1cafefb 4a12f7c5 WARN   Fail from voice reader: read unix @->@: read: bad file descriptor
2019/08/03 11:03:42 read unix @->@: read: bad file descriptor .  138
.  508
.  514
.  489
.  532
.  2197
2019/08/03 11:03:42 d1cafefb 4a12f7c5 DEBUG  TS>/opt/sinusbot1/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
2019/08/03 11:03:42 d1cafefb 4a12f7c5 DEBUG  Closed.
2019/08/03 11:03:42 d1cafefb 4a12f7c5 INFO   TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/08/03 11:03:42 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, support enabled
2019/08/03 11:03:42 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2019/08/03 11:03:42 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2019/08/03 11:03:42 [GENERAL/RADIO  ] INFO   Imported radio stations
2019/08/03 11:03:43 d1cafefb 4a12f7c5 DEBUG  closing channels
After i closed and restarted it it shows me this, the web interface is on but the bont don t connect
2019/08/03 11:04:25 d1cafefb          INFO   Loading instances
2019/08/03 11:04:25 d1cafefb          INFO   Loading instance://4a12f7c5-48bf-4861-8f28-48436edb29b9
2019/08/03 11:04:25 d1cafefb 4a12f7c5 DEBUG  Spawning instance shortly due to missing configuration file.
2019/08/03 11:04:25 d1cafefb 4a12f7c5 DEBUG  Prespawn.
2019/08/03 11:04:25 d1cafefb 4a12f7c5 DEBUG  About to run.
2019/08/03 11:04:25 d1cafefb 4a12f7c5 INFO   Starting instance ts3server://ts.icegame.ro?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/08/03 11:04:25 d1cafefb 4a12f7c5 DEBUG  TS>/opt/sinusbot1/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
2019/08/03 11:04:25 d1cafefb 4a12f7c5 DEBUG  Closed.
2019/08/03 11:04:25 d1cafefb 4a12f7c5 INFO   TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/08/03 11:04:25 d1cafefb 4a12f7c5 DEBUG  executing script command
2019/08/03 11:04:25 d1cafefb 4a12f7c5 INFO   Initialization complete
2019/08/03 11:04:25 d1cafefb 4a12f7c5 INFO   Auto-Starting d1cafefb-7a60-4ef8-90ee-43f4ac21ebef/4a12f7c5-48bf-4861-8f28-48436edb29b9 in 500 ms...
2019/08/03 11:04:25 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/08/03 11:04:25 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/08/03 11:04:25 [GENERAL/YTDL   ] INFO   youtube-dl checking...
2019/08/03 11:04:25 d1cafefb 4a12f7c5 DEBUG  serialized function: true
2019/08/03 11:04:25 d1cafefb 4a12f7c5 DEBUG  registered callback for event chat
2019/08/03 11:04:25 d1cafefb 4a12f7c5 DEBUG  module registered as command
2019/08/03 11:04:25 d1cafefb 4a12f7c5 INFO   script command loaded
2019/08/03 11:04:26 d1cafefb 4a12f7c5 DEBUG  Prespawn.
2019/08/03 11:04:26 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, support enabled
2019/08/03 11:04:26 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2019/08/03 11:04:26 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2019/08/03 11:04:26 d1cafefb 4a12f7c5 DEBUG  closing channels
2019/08/03 11:04:26 d1cafefb 4a12f7c5 DEBUG  About to run.
2019/08/03 11:04:26 d1cafefb 4a12f7c5 INFO   Starting instance ts3server://ts.icegame.ro?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/08/03 11:04:26 d1cafefb 4a12f7c5 INFO   TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/08/03 11:04:26 d1cafefb 4a12f7c5 DEBUG  eof from voice
2019/08/03 11:04:26 d1cafefb 4a12f7c5 DEBUG  Closed.
2019/08/03 11:04:26 [GENERAL/RADIO  ] INFO   Imported radio stations
2019/08/03 11:04:27 d1cafefb 4a12f7c5 DEBUG  closing channels
2019/08/03 11:04:27 d1cafefb 4a12f7c5 DEBUG  eof from voice
2019/08/03 11:04:51 d1cafefb 4a12f7c5 DEBUG  Prespawn.
2019/08/03 11:04:51 d1cafefb 4a12f7c5 DEBUG  About to run.
2019/08/03 11:04:51 d1cafefb 4a12f7c5 INFO   Starting instance ts3server://ts.icegame.ro?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/08/03 11:04:51 d1cafefb 4a12f7c5 INFO   TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/08/03 11:04:51 d1cafefb 4a12f7c5 DEBUG  Closed.
2019/08/03 11:04:52 d1cafefb 4a12f7c5 DEBUG  eof from voice
2019/08/03 11:04:52 d1cafefb 4a12f7c5 DEBUG  closing channels
2019/08/03 11:04:52 d1cafefb 4a12f7c5 DEBUG  eof from data
2019/08/03 11:04:55 d1cafefb 4a12f7c5 DEBUG  Storing configuration.
Himsel
barlap
i changed to debian 8 but i have and older kernel version (2.6) where i can get an older version of sinusbot?
