2019-07-27T22:47:32+02:00 Storing configuration.
2019-07-27T22:47:32+02:00 closing channels
2019-07-27T22:47:31+02:00 TSClient quit.
2019-07-27T22:47:31+02:00 Closed.
2019-07-27T22:47:31+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-07-27T22:47:31+02:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019-07-27T22:47:31+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-07-27T22:47:31+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-07-27T22:47:31+02:00 KILL [admin] OK
2019-07-27T22:47:26+02:00 script Reconnect loaded
2019-07-27T22:47:26+02:00 registered callback for event clientKicked
2019-07-27T22:47:26+02:00 serialized function: true
2019-07-27T22:47:26+02:00 registered callback for event disconnect
2019-07-27T22:47:26+02:00 script command loaded
2019-07-27T22:47:26+02:00 module registered as command
2019-07-27T22:47:26+02:00 registered callback for event chat
2019-07-27T22:47:26+02:00 executing script Reconnect
2019-07-27T22:47:26+02:00 executing script command
2019-07-27T22:47:26+02:00 unloading instance
2019-07-27T22:47:20+02:00 script command loaded
2019-07-27T22:47:20+02:00 module registered as command
2019-07-27T22:47:20+02:00 registered callback for event chat
2019-07-27T22:47:20+02:00 serialized function: true
2019-07-27T22:47:20+02:00 executing script command
2019-07-27T22:47:20+02:00 unloading instance
2019-07-27T22:42:32+02:00 Storing configuration.
2019-07-27T22:42:25+02:00 TS |INFO |LicenseViewer | |Downloaded license file for version 5 and language en
2019-07-27T22:42:25+02:00 TS |DEVELOP |Addon_Download_Manager| |Download completed: /tmp/clientquerypluginlinuxamd64_5d2d9a738ad98.ts3_plugin Addon_Uuid:943dd816-7ef2-48d7-82b8-d60c3b9b10b3 Version: 7
2019-07-27T22:42:25+02:00 TS |INFO |LicenseViewer | |Requesting remote license for version 5 and language en
2019-07-27T22:42:25+02:00 TS |INFO |LicenseViewer | |View license: version=5, language=en, require accept=1
2019-07-27T22:42:24+02:00 TS |INFO |Update | |Check license: version=5, min_version=4, my_license_version=0, my_license_min_version=0
2019-07-27T22:42:24+02:00 TS |INFO |Integrations | |Requesting integration icon download from https://ts3services.teamspeak.com/integration_icons/twitch/twitch.svg
2019-07-27T22:42:24+02:00 TS |INFO |Update | |Checking for updates...
2019-07-27T22:42:24+02:00 TS |INFO |ClientUI | |Checking for update
2019-07-27T22:42:24+02:00 TS |INFO |ClientUI | |Last update check was: Never
2019-07-27T22:42:24+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019-07-27T22:42:24+02:00 TS |DEVELOP |Addons | |Got addon download info for ClientQuery
2019-07-27T22:42:22+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/ab226f46-37cf-40de-815b-b43ae74008f8/e78ef467-f195-4d10-b06c-73e739d7a283/settings.db
2019-07-27T22:42:22+02:00 TS |INFO |ClientUI | |Qt version: 5.12.1
2019-07-27T22:42:22+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2019-07-27T22:42:22+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/default
2019-07-27T22:42:22+02:00 TS |INFO | | |*** Time [INIT]: 439
2019-07-27T22:42:22+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 439
2019-07-27T22:42:21+02:00 TS |INFO |SyncImpl | |Creating default config in local storage
2019-07-27T22:42:20+02:00 TS |INFO |Addon | |Not available for this platform.
2019-07-27T22:42:20+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019-07-27T22:42:20+02:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2019-07-27T22:42:20+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-07-27T22:42:20+02:00 TS |INFO |Addons | |Checking for addon updates...
2019-07-27T22:42:20+02:00 TS |INFO | | |successfully downloaded revocation list for accounting
2019-07-27T22:42:20+02:00 TS |DEVELOP |Addons | |Installation request for ClientQuery
2019-07-27T22:42:20+02:00 TS |DEVELOP |Addons | |Installation request for Gamepad and Joystick Hotkey Support
2019-07-27T22:42:20+02:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-07-27T22:42:20+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-07-27T22:42:20+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-07-27T22:42:20+02:00 TS |INFO | | |SystemInformation: Linux 4.4.0-157-generic #185-Ubuntu SMP Tue Jul 23 09:17:01 UTC 2019 x86_64 Binary: 64bit
2019-07-27T22:42:20+02:00 TS |INFO | | |TeamSpeak 3 Client 3.3.0 (2019-06-18 09:29:01)
2019-07-27T22:42:19+02:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/ab226f46-37cf-40de-815b-b43ae74008f8/e78ef467-f195-4d10-b06c-73e739d7a283/crashdumps
2019-07-27T22:42:19+02:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/ab226f46-37cf-40de-815b-b43ae74008f8/e78ef467-f195-4d10-b06c-73e739d7a283/crashdumps
2019-07-27T22:42:17+02:00 Starting instance ts3server://NeruxVace?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-27T22:42:17+02:00 About to run.
2019-07-27T22:42:17+02:00 Prespawn.
2019-07-27T22:35:32+02:00 Storing configuration.
2019-07-27T22:35:28+02:00 eof from voice
2019-07-27T22:35:28+02:00 closing channels
2019-07-27T22:35:27+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-27T22:35:27+02:00 Closed.
2019-07-27T22:35:27+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
2019-07-27T22:35:27+02:00 Starting instance ts3server://NeruxVace?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-27T22:35:27+02:00 About to run.
2019-07-27T22:35:27+02:00 Prespawn.
2019-07-27T22:35:24+02:00 BOT-CONFIG [admin] HOST CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2019-07-27T22:34:32+02:00 Storing configuration.
2019-07-27T22:34:04+02:00 closing channels
2019-07-27T22:34:03+02:00 eof from voice
2019-07-27T22:34:03+02:00 Closed.
2019-07-27T22:34:03+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-27T22:34:03+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-27T22:34:03+02:00 About to run.
2019-07-27T22:34:03+02:00 closing channels
2019-07-27T22:34:03+02:00 Prespawn.
2019-07-27T22:34:02+02:00 script command loaded
2019-07-27T22:34:02+02:00 module registered as command
2019-07-27T22:34:02+02:00 registered callback for event chat
2019-07-27T22:34:02+02:00 serialized function: true
2019-07-27T22:34:02+02:00 Auto-Starting ab226f46-37cf-40de-815b-b43ae74008f8/e78ef467-f195-4d10-b06c-73e739d7a283 in 500 ms...
2019-07-27T22:34:02+02:00 Initialization complete
2019-07-27T22:34:02+02:00 executing script command
2019-07-27T22:34:02+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-27T22:34:02+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
