Sinusbot not connect in TeamSpeak Sever.
Moscky_
Hi, I try to connect the bot to the teamspeak server but it doesn't work, it tells me that it doesn't exist / has been banned / wrong ip.
 - Operating System: Ubuntu 20.04.3 LTS (OpenVZ)
 - Kernel: Linux 5.4.0 x86_64
 - Load Average: 0.12 0.04 0.05
 - Uptime: 24 days, 1 hours, 44 minutes, 37 seconds
 - OS Updates: 32 (updates available!)
 - OS APT Last Update: 01.03.2022 15:38:04 CET +01:00:00
 - Shell Locale: (not set)
    Architecture:        x86_64
    CPU(s):              1
    Thread(s) per core:  1
    Core(s) per socket:  1
    Socket(s):           1
    Model name:          Intel(R) Xeon(R) CPU E5-2683 v3 @ 2.00GHz
    CPU MHz:             2499.877
    Virtualization:      VT-x
    Hypervisor vendor:   Parallels
    Virtualization type: container
 - RAM: 507.96 MB/2.00 GB in use (24%)
 - DISK: 3.46 GB/19.55 GB in use (17%)
   - libglib: 2.64.6-1~ubuntu20.04.4
 - Status: running (PIDs: 349794 349793, User: sinusbot)
 - Binary Info: MD5 Hash: 000db57a7fc04074ea799d11281be28a, Perms: 755, User: si        nusbot
 - Version: 1.0.0-beta.16-ba60e37
   - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64        (Version 3.3.0)
   - YoutubeDLPath = /opt/sinusbot/yt-dlp (does exist, version: 2022.02.04)
 - Installed scripts: TecnoStaffNotify.js; TecnoTS3Gestor.js; TecnoTTS.js; YT-se        arch.js; Youtube_Search.js
    linux-vdso.so.1 (0x00007ffff6792000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f6c2c1b3000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f6c2be5b000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f6c2ba5a000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f6c2b0f5000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f6c2ae81000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f6c2ae74000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f6c2ad23000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f6c2ad00000        )
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f6c2ab1e0        00)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f6c2ab03000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f6c2a911000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f6c2a8f5000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f6c2a8e8000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f6c2c3cf000)
 - HTTPS check with IPv4 mode: SUCCESS [Connection established to www.sinusbot.c        om, CODE #200]
 - Time (local): 05.03.2022 18:37:13 CET +01:00:00
 - Timezone: Europe/Rome
 - TeamSpeak3 Version: 3.3.0
 - youtube-dl Version: 2022.02.04
Lala Sabathil
Make sure that ntp is installed.
Furthermore update your system, you have 32 updates.
If it doesn't work afterwards, please notify us.
