Sinusbot not joining on startup
Dr.Plague
So a little information.
I use ubuntu 18.04 on a server which I reboot every night and automatically starts all the procceses and server with crontab -e.
Now this works for every server and program except for the sinusbot one
@reboot tmux new-session -d -s "sinusbot" /opt/sinusbot/sinusbot
This is what I use in the crontab but when I try to get into the tmux it says there are no sessions running..
But it's clearly running because I can access the webpage but when I press the power button to start the bot it shows the blue bar and then does nothing...
I am on sinusbot version
0.13.37-9791176
and this is my log
2018-07-25T19:39:20+02:00 Storing configuration.
2018-07-25T19:38:55+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2018-07-25T19:38:55+02:00 Closed.
2018-07-25T19:38:55+02:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2018-07-25T19:38:55+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2018-07-25T19:38:55+02:00 Starting instance ts3server://xx.xx.xx.xx?port=9987&nickname=xxx&password=xxxxxxchannelpassword=
2018-07-25T19:38:55+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2018-07-25T19:38:55+02:00 Could not delete from FileTransferno such table: FileTransfer
2018-07-25T19:38:55+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-07-25T19:38:55+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-07-25T19:38:55+02:00 Could not create Chat-Tabletable Chat already exists
2018-07-25T19:38:55+02:00 About to run.
2018-07-25T19:38:55+02:00 Prespawn.
2018-07-25T19:31:50+02:00 Storing configuration.
2018-07-25T19:31:21+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2018-07-25T19:31:21+02:00 Closed.
2018-07-25T19:31:21+02:00 TS>QXcbConnection: Could not connect to display unix/:40.0
2018-07-25T19:31:21+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2018-07-25T19:31:21+02:00 Starting instance ts3server://xx.xx.xx.xx?port=9987&nickname=xxxx&password=xxxxx&channelpassword=
2018-07-25T19:31:21+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2018-07-25T19:31:21+02:00 Could not delete from FileTransferno such table: FileTransfer
2018-07-25T19:31:21+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-07-25T19:31:21+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-07-25T19:31:21+02:00 Could not create Chat-Tabletable Chat already exists
2018-07-25T19:31:21+02:00 About to run.
2018-07-25T19:31:21+02:00 Prespawn.
2018-07-25T19:31:20+02:00 Storing configuration.
2018-07-25T19:31:16+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2018-07-25T19:31:15+02:00 Starting instance ts3server://xx.xx.xx.xx?port=9987&nickname=xxxx&password=xxxxx&channelpassword=
2018-07-25T19:31:15+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-07-25T19:31:15+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-07-25T19:31:15+02:00 Could not create Chat-Tabletable Chat already exists
2018-07-25T04:33:26+02:00 TSClient quit.
2018-07-25T04:33:21+02:00 Starting instance ts3server://xx.xx.xx.xx?port=9987&nickname=xxxx&password=xxxxx&channelpassword=
2018-07-25T04:33:20+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-07-25T04:33:20+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-07-25T04:33:20+02:00 Could not create Chat-Tabletable Chat already exists
2018-07-25T04:33:20+02:00 Auto-Starting xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx in 500 ms...
2018-07-25T04:33:20+02:00 Initialization complete
2018-07-25T04:33:20+02:00 Loading script volumeKeeper
2018-07-25T04:33:20+02:00 Loading script pm_to_all
2018-07-25T04:33:20+02:00 Changecodec:91 Change Channelcodec and Quality automaticly Loaded 1.4.1
2018-07-25T04:33:20+02:00 Loading script Changecodec
2018-07-25T04:33:20+02:00 Loading script AFK_Mover
2018-07-25T04:33:20+02:00 Loading script welcome
2018-07-25T04:33:20+02:00 Loading script ServerQuery
2018-07-25T04:33:20+02:00 Loading script norecording
2018-07-25T04:33:20+02:00 Loading script come
2018-07-25T04:33:20+02:00 Loading script adminStaffStatus0.9.9
If you require any other information ask me.
Thanks in advance !
