Sinusbot Start-up Problem
Newa Zusa
Okay, I don't know if I am stupid, but I have tried to start my Sinusbot up and once I power it up, there is a window from TS that opens and closes about accepting the TOS which I know I have accepted in the past for my Sinusbot. But, my problem is, I can't seem to get my Sinusbot to work. I have updated & re-installed both Teamspeak & Sinusbot correctly and it STILL does not want to work with me. Is there any proper way to make Sinusbot work with Teamspeak 3.2.3 or do I have to wait for Sinusbot to update?
Any help will be very nice & appreciated
Info on my Sinusbot:
Sinusbot Version: SinusBot 0.13.37-f37f203
TS Client: 3.2.3
Server Version: Version:3.5.0 on Linux
My OS: Win10 Pro 64-bit
PC Specs:
  1. Processor: Intel Core i5-3330 Quad Core @ 3.00 GHz, 3001 Mhz
  2. Graphics card: Intel HD Graphics
  3. Motherboard: Intel Corp. DH77EB
  4. Hard Drive(s): 256GB SSD, 1TB HD
  5. Installed memory(RAM): 8.00 GB of DDR3 (4 sticks)
Instance Log:
2019-02-22T05:48:54-07:00 TSClient quit.
2019-02-22T05:48:53-07:00 New connection status 0; Error 0
2019-02-22T05:48:53-07:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2019-02-22T05:48:52-07:00 New connection status 1; Error 0
2019-02-22T05:48:51-07:00 Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2019-02-22T05:48:49-07:00 Starting instance ts3server://216.105.171.14?port=10386&nickname=NZ%20Radios&password=&channel=&channelpassword=
2019-02-22T05:48:49-07:00 Could not create Notifications-Tabletable Notifications already exists
2019-02-22T05:48:49-07:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-02-22T05:48:49-07:00 Could not create Chat-Tabletable Chat already exists
2019-02-22T05:42:15-07:00 Initialization complete
Bot Log:
2019-02-22T05:42:17-07:00 LOGIN [admin] OK
2019-02-22T05:42:15-07:00 Loading instance://5d89a5f6-462f-4b72-9570-ab843cce465b
2019-02-22T05:42:15-07:00 Loading instances
Log Level in the config.ini was 3 (I set it up to 10 like what TwentyFour posted below)
Used Browser: I use Microsoft edge because that is what Sinusbot opened up when I use it and it has worked fine before on that browser
