Sinusbot startet nach Installation nicht
MrFreak
Betriebssystem: Debian 8 / Jessie
SinusBot Version: 0.9.21-87a90ce
TS3 Version: 3.0.19.4
Nach der Installation des Sinusbots habe ich versucht Sinusbot zu starten, doch nach ein paar Sekunden kommt nur noch die Meldung "Killed". Ich hoffe man kann mir helfen.
- Operating System: Debian GNU/Linux 8.9 (jessie) (OpenVZ)
- Kernel: Linux 2.6.32-042stab124.2 x86_64
- Load Average: 0.05 0.02 0.03
- Uptime: 0 days, 0 hours, 44 minutes, 44 seconds
- OS APT Last Update: 17.09.2017 12:57:10 CEST +02:00:00
- RAM:  B/1.00 GB in use (%)
- SWAP:  B/ B in use (%)
- DISK: 1.03 GB/98.96 GB in use (1%)
   > libglib: 2.42.1-1+b1
- Binary: /opt/sinusbot/sinusbot (MD5 Hash: f62c677c697c99ee7c4e624ae8822887)
- Version: 0.9.21-87a90ce
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.09.15)
- Report date: 17.09.2017 13:12:15 CEST +02:00:00 (timezone: Europe/Amsterdam)
- youtube-dl Version: 2017.09.15
- DiagScript version: 0.5.1
2017/09/17 13:03:46 X [MAIN] Starting up fake x-server...
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin sound.js
2017/09/17 13:03:47 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
Generating new bot instance with account 'admin' and password 'vZp7FPGh'
2017/09/17 13:03:47 Updating database to v1... 0
2017/09/17 13:03:47 Updating database to v2... 1
2017/09/17 13:03:47 Updating database to v3... 2
2017/09/17 13:03:47 Updating database to v4... 3
2017/09/17 13:03:47 Updating database to v5... 4
2017/09/17 13:03:47 Updating database to v6... 5
2017/09/17 13:03:47 Updating database to v7... 6
2017/09/17 13:03:47 bfeb03e9          INFO   Loading instances
2017/09/17 13:03:47 bfeb03e9          INFO   Creating default instance
2017/09/17 13:03:47 bfeb03e9 d76bb851 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017/09/17 13:03:47 bfeb03e9          INFO   Promoting instance to main instance
2017/09/17 13:03:47 X [MAIN] New connection
2017/09/17 13:03:47 bfeb03e9          INFO   Adding new user admin
2017/09/17 13:03:47 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2017/09/17 13:03:47 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2017/09/17 13:03:47 [GENERAL/YTDL   ] INFO   youtube-dl checking...
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |              |   |SystemInformation: Linux 2.6.32-042stab124.2 #1 SMP Fri Sep 1 20:42:18 MSK 2017 x86_64 Binary: 64bit
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |              |   |Using hardware aes
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |ERROR   |SoundBckndIntf|   |libasound.so.2: cannot open shared object file: No such file or directory
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |WARNING |SoundDevManager|   |Did not load any sound backends. No (usable) dynamic libraries found.
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |              |   |Loading plugin: libclientquery_plugin
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |              |   |Loading plugin: liblua_plugin
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |              |   |Loading plugin: libsoundbot_plugin
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |              |   |Loading plugin: libtest_plugin
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2017/09/17 13:03:48 X [MAIN] New connection
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 163
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |              |   |*** Time [INIT]: 163
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |ClientUI      |   |*** Time [SQLITE_CONVERTER]: 4
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |ClientUI      |   |Qt version: 5.5.1
2017/09/17 13:03:48 bfeb03e9 d76bb851 INFO   TS |INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data/ts3/bfeb03e9-495a-46ed-b233-1203bd63d4d9/d76bb851-b4d1-4434-9334-60fff7ee89e9/settings.db
Killed
- MrFreak
MrFreak
Bitteschön :)
-MrFreak
Nabend,
schick mir mal bitte den kompletten Output von
dmesg -k
und das Logfile
cat /var/log/syslog
Außerdem brauch ich mal den Output von (kann sein das dass Command nicht gefunden wird was durch aus korrekt ist)
sestatus -v
aa-status
nach 2-3 Start versuchen.
MrFreak
Bitteschön :) Nicht wundern passte nicht alles rein in einen Beitrag ^^
Sep 17 06:27:31 vps3443-tjkgx rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="196" x-info="http://www.rsyslog.com"] start
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-remount-fs.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started udev Coldplug all Devices.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Copy rules generated while the root was ro.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Load/Save Random Seed.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Mounted /run/shm.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Local File Systems.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Reached target Local File Systems.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Remote File Systems.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Reached target Remote File Systems.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Trigger Flushing of Journal to Persistent Storage...
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-journal-flush.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Create Volatile Files and Directories...
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-tmpfiles-setup.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting LSB: Raise network interfaces....
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/networking.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udev-trigger.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/udev-finish.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-random-seed.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx quotaon.sh[88]: quotaon: Cannot stat() mounted device /dev/simfs: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Create Volatile Files and Directories.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Network Time Synchronization.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting System Time Synchronized.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Reached target System Time Synchronized.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-update-utmp.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Trigger Flushing of Journal to Persistent Storage.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Check And Enable File System Quotas.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Update UTMP about System Boot/Shutdown.
Sep 17 06:27:31 vps3443-tjkgx networking[101]: Configuring network interfaces...done.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started LSB: Raise network interfaces..
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Network.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Reached target Network.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting System Initialization.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Reached target System Initialization.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Daily Cleanup of Temporary Directories.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Daily Cleanup of Temporary Directories.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Timers.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Reached target Timers.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Basic System.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Reached target Basic System.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting OpenBSD Secure Shell server...
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ssh.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started OpenBSD Secure Shell server.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Network Name Resolution...
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-resolved.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting /etc/rc.local Compatibility...
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rc-local.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Login Service.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting LSB: Start vzquota at the end of boot...
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/vzquota.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting LSB: modules.dep creation....
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/modules_dep.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting System Logging Service...
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rsyslog.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Starting Permit User Sessions...
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-user-sessions.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/quota.service: No such file or directory
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Permit User Sessions.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started System Logging Service.
Sep 17 06:27:31 vps3443-tjkgx sshd[191]: Could not load host key: /etc/ssh/ssh_host_rsa_key
Sep 17 06:27:31 vps3443-tjkgx sshd[191]: Could not load host key: /etc/ssh/ssh_host_dsa_key
Sep 17 06:27:31 vps3443-tjkgx sshd[191]: Could not load host key: /etc/ssh/ssh_host_ecdsa_key
Sep 17 06:27:31 vps3443-tjkgx sshd[191]: Could not load host key: /etc/ssh/ssh_host_ed25519_key
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started Network Name Resolution.
Sep 17 06:27:31 vps3443-tjkgx rsyslogd-2039: Could not open output pipe '/dev/xconsole': No such file or directory [try http://www.rsyslog.com/e/2039 ]
Sep 17 06:27:31 vps3443-tjkgx rsyslogd-2007: action 'action 17' suspended, next retry is Sun Sep 17 06:28:01 2017 [try http://www.rsyslog.com/e/2007 ]
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Started LSB: modules.dep creation..
Sep 17 06:27:31 vps3443-tjkgx vzquota[194]: quotaon: using //aquota.group on /dev/simfs [/]: Device or resource busy
Sep 17 06:27:31 vps3443-tjkgx vzquota[194]: quotaon: using //aquota.user on /dev/simfs [/]: Device or resource busy
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: vzquota.service: control process exited, code=exited status=2
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Failed to start LSB: Start vzquota at the end of boot.
Sep 17 06:27:31 vps3443-tjkgx systemd[1]: Unit vzquota.service entered failed state.
Sep 17 06:27:31 vps3443-tjkgx rc.local[193]: Generating public/private rsa key pair.
Sep 17 06:27:31 vps3443-tjkgx rc.local[193]: Your identification has been saved in /etc/ssh/ssh_host_rsa_key.
Sep 17 06:27:31 vps3443-tjkgx rc.local[193]: Your public key has been saved in /etc/ssh/ssh_host_rsa_key.pub.
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Starting Regular background program processing daemon...
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/cron.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Started Regular background program processing daemon.
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /user.slice: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/tmp.mount: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-null.swap: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/-.mount: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/run-shm.mount: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-networkd.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx cron[10096]: (CRON) INFO (pidfile fd = 3)
Sep 17 06:55:02 vps3443-tjkgx cron[10096]: (CRON) INFO (Running @reboot jobs)
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ssh.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-resolved.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rc-local.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/system-getty.slice: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/console-getty.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/modules_dep.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-setup-dgram-qlen.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rsyslog.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/quota.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-update-utmp.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udevd.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-sysctl.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-mqueue.mount: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udev-trigger.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/udev-finish.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-user-sessions.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-tmpfiles-setup.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-random-seed.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/networking.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-journald.service: No such file or directory
Sep 17 06:55:02 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-remount-fs.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Reloading.
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Starting Network is Online.
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Reached target Network is Online.
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Starting LSB: Start NTP daemon...
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ntp.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /user.slice: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/tmp.mount: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-null.swap: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/-.mount: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/run-shm.mount: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/cron.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-networkd.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ssh.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-resolved.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rc-local.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/system-getty.slice: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/console-getty.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/modules_dep.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-setup-dgram-qlen.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rsyslog.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/quota.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-update-utmp.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udevd.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-sysctl.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-mqueue.mount: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udev-trigger.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/udev-finish.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-user-sessions.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-tmpfiles-setup.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-random-seed.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/networking.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-journald.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-remount-fs.service: No such file or directory
Sep 17 06:55:03 vps3443-tjkgx ntpd[10194]: ntpd [email protected] Fri Jul 22 17:30:51 UTC 2016 (1)
Sep 17 06:55:03 vps3443-tjkgx systemd[1]: Started LSB: Start NTP daemon.
Sep 17 06:55:03 vps3443-tjkgx ntp[10188]: Starting NTP server: ntpd.
Sep 17 06:55:03 vps3443-tjkgx ntpd[10195]: proto: precision = 0.112 usec
Sep 17 06:55:03 vps3443-tjkgx ntpd[10195]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Sep 17 06:55:03 vps3443-tjkgx ntpd[10195]: Listen and drop on 1 v6wildcard :: UDP 123
Sep 17 06:55:03 vps3443-tjkgx ntpd[10195]: Listen normally on 2 lo 127.0.0.1 UDP 123
Sep 17 06:55:03 vps3443-tjkgx ntpd[10195]: Listen normally on 3 venet0 127.0.0.2 UDP 123
Sep 17 06:55:03 vps3443-tjkgx ntpd[10195]: Listen normally on 4 venet0:0 5.196.149.99 UDP 123
Sep 17 06:55:03 vps3443-tjkgx ntpd[10195]: Listen normally on 5 lo ::1 UDP 123
Sep 17 06:55:03 vps3443-tjkgx ntpd[10195]: peers refreshed
Sep 17 06:55:03 vps3443-tjkgx ntpd[10195]: Listening on routing socket on fd #22 for interface updates
Sep 17 06:55:03 vps3443-tjkgx ntpd[10195]: cap_set_proc() failed to drop root privileges: Operation not permitted
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Reloading.
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Starting LSB: exim Mail Transport Agent...
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/exim4.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /user.slice: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/tmp.mount: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-null.swap: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/-.mount: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/run-shm.mount: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/cron.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-networkd.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ssh.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-resolved.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rc-local.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/system-getty.slice: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/console-getty.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/modules_dep.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ntp.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-setup-dgram-qlen.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rsyslog.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/quota.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-update-utmp.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udevd.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-sysctl.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-mqueue.mount: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udev-trigger.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/udev-finish.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-user-sessions.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-tmpfiles-setup.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-random-seed.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/networking.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-journald.service: No such file or directory
Sep 17 06:55:04 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-remount-fs.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx exim4[10667]: Starting MTA: exim4.
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Started LSB: exim Mail Transport Agent.
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Reloading.
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Starting D-Bus System Message Bus Socket.
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Listening on D-Bus System Message Bus Socket.
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Starting D-Bus System Message Bus...
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dbus.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Started D-Bus System Message Bus.
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /user.slice: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/tmp.mount: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-null.swap: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/-.mount: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/run-shm.mount: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/cron.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-networkd.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ssh.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-resolved.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rc-local.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/system-getty.slice: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/console-getty.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/modules_dep.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/exim4.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ntp.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-setup-dgram-qlen.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rsyslog.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/quota.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-update-utmp.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udevd.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-sysctl.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-mqueue.mount: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udev-trigger.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/udev-finish.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-user-sessions.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-tmpfiles-setup.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-random-seed.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/networking.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-journald.service: No such file or directory
Sep 17 06:55:05 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-remount-fs.service: No such file or directory
Sep 17 06:55:30 vps3443-tjkgx systemd[1]: Reloading.
Sep 17 06:57:18 vps3443-tjkgx systemd[1]: Reloading.
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Starting Sinusbot, the Teamspeak 3 and Discord music bot....
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/sinusbot.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /user.slice: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/tmp.mount: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-null.swap: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/-.mount: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/run-shm.mount: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/cron.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-networkd.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ssh.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-resolved.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rc-local.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/system-getty.slice: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/console-getty.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/modules_dep.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/exim4.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ntp.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dbus.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-setup-dgram-qlen.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rsyslog.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/quota.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-update-utmp.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udevd.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-sysctl.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-mqueue.mount: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udev-trigger.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/udev-finish.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-user-sessions.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-tmpfiles-setup.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-random-seed.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/networking.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-journald.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-remount-fs.service: No such file or directory
Sep 17 06:57:21 vps3443-tjkgx systemd[1]: Started Sinusbot, the Teamspeak 3 and Discord music bot..
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: ___ ___ _  _ _   _ ___ ___  ___ _____  BETA
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: / __|_ _| \| | | | / __| _ )/ _ \_   _|
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: \__ \| || .` | |_| \__ \ _ \ (_) || |
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: |___/___|_|\_|\___/|___/___/\___/ |_|
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: Version: 0.9.21-87a90ce
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: (C) 2013-2017 Michael Friese. All rights reserved.
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 X [MAIN] Starting up fake x-server...
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin sound.js
Sep 17 06:57:22 vps3443-tjkgx sinusbot[13203]: 2017/09/17 12:57:22 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
Sep 17 06:57:22 vps3443-tjkgx systemd[1]: sinusbot.service: main process exited, code=killed, status=9/KILL
Sep 17 06:57:22 vps3443-tjkgx systemd[1]: Unit sinusbot.service entered failed state.
Sep 17 07:12:00 vps3443-tjkgx systemd[1]: Reloading.
Sep 17 07:17:01 vps3443-tjkgx CRON[14728]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Sep 17 08:17:01 vps3443-tjkgx CRON[14999]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Sep 17 09:17:01 vps3443-tjkgx CRON[15185]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Sep 17 10:17:01 vps3443-tjkgx CRON[15376]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Sep 17 11:17:01 vps3443-tjkgx CRON[15585]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Sep 17 11:52:30 vps3443-tjkgx systemd[1]: Reloading.
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Reloading.
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Starting LSB: Apache2 web server...
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/apache2.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /user.slice: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/tmp.mount: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-null.swap: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/-.mount: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/run-shm.mount: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/cron.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-networkd.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ssh.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-resolved.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rc-local.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/system-getty.slice: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/console-getty.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/modules_dep.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/exim4.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/ntp.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dbus.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-setup-dgram-qlen.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/rsyslog.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/quota.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-update-utmp.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udevd.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-sysctl.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/dev-mqueue.mount: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-udev-trigger.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/udev-finish.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-user-sessions.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-tmpfiles-setup.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-random-seed.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/networking.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-journald.service: No such file or directory
Sep 17 11:52:32 vps3443-tjkgx systemd[1]: Failed to reset devices.list on /system.slice/systemd-remount-fs.service: No such file or directory
Sep 17 11:52:33 vps3443-tjkgx apache2[16331]: Starting web server: apache2AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 5.196.149.99. Set the 'ServerName' directive globally to suppress this message
Sep 17 11:52:34 vps3443-tjkgx apache2[16331]: .
Sep 17 11:52:34 vps3443-tjkgx systemd[1]: Started LSB: Apache2 web server.
Sep 17 11:52:35 vps3443-tjkgx systemd[1]: Reloading.
Sep 17 12:17:01 vps3443-tjkgx CRON[16603]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Sep 17 13:17:01 vps3443-tjkgx CRON[16794]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
sestatus -v
aa-status
findet er auch nicht ^^
-MrFreak
Will sicher gehen das es in den Logs ist, deswegen 2-3 versuche. Der Syslog ist unaufällig soweit, magst den Output von dmesg -k noch rein packen? :)
Sobald ich dmesg -k eingebe passiert nix...?
Schade. :p Aber das ist nen Kernel Security feature das nicht root benutzer die Kernel Logs nicht sehen können.
Oben genanntes "Killed" deutet auch auf SELinux oder AppArmor hin, also müsstest du mal bei deinem Hoster nachfragen was die da so für Securityfeatures nutzen.
Also unterm strich: Das System ist relativ gut gehärtet.
