LukasRabTV
#stayinghome
Betriebssystem: Linux Debian 8 64bit
SinusBot Version:
0.10.8-71ba94b
Problembeschreibung
ich wollte gerade den Sinusbot starten bekam aber folgenden Fehler :
a manual update is required
Was kann ich tun ? Habe mich auch gerde im Forum umgeguckt nach dem Fehler aber das Datum ist auf die Sekunde richtig auf meinen Server...
SinusBot Version:
0.10.8-71ba94b
Problembeschreibung
- Operating System: Debian GNU/Linux 8.9 (jessie)
- Load Average: 0.08 0.11 0.09
- Uptime: 0 days, 0 hours, 25 minutes, 6 seconds
- OS APT Last Update: 02.11.2017 16:22:46 CET +01:00:00
- HTTPS check with IPv4 mode: FAILED [Failed establishing connection to sinusbot.com]
CPU(s): 3
Thread(s) per core: 1
Core(s) per socket: 3
Socket(s): 1
Model name: Common KVM processor
CPU MHz: 3599.996
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 3.01 GB/6.83 GB in use (44%)
- SWAP: 0 B/511.99 MB in use (0%)
- DISK: 3.84 GB/42.20 GB in use (9%)
> libglib: 2.42.1-1+b1
- Binary: /opt/sinusbot/sinusbot (MD5 Hash: febce0ebdd2d2e9d7f69701bc5a7c339)
- Version: 0.10.8-71ba94b
- TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.0.18.2)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.10.20)
- Installed scripts: AutomaticServerGroupAssigner(1).js; Changecodec.js; Group-Distrubor(1).js; KeepOut.js; Lauftext__Ticker__APINewsticker_Support.js; ZTSupport_-_SupportChannel_With_ServerGroup_Support.js; advertising.js; alonemode.js; bookmark.js; countOnlineUsers.js; custom_commands.js; followme.js; mc_server_info.js; norecording.js; rememberChannel.js; support-channel manager_de.js; support-pp(1).js; welcome.js
- Report date: 02.11.2017 16:58:49 CET +01:00:00 (timezone: Etc/UTC)
- youtube-dl Version: 2017.10.20
- DiagScript version: 0.5.1
